Water pump inlet pipe o-ring - did I eff it up? - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 10-08-2012, 05:48 PM   #1
fastawdtsi
I got the head back in the car, and to play it safe, I added a touch of oil to the coolant inlet pipe o-ring, where the pipe slides in to the thermostat housing. It all went in good, no issues.
Then, like an idiot, I read the service manual AFTER I did the above and noticed the following:
Did I eff up? Why would that be such a huge "CAUTION"?
fastawdtsi is offline   Reply With Quote
Old 10-08-2012, 06:26 PM   #2
Pool Playen Bob
Pool Playen Bob's Avatar
Im like 99.9% sure your ok. I really doubt oil will eat it away or swell it. Even for that little bit you used. I use the shit out of vaseline around the shop i work at. Theres even applications where they ask for dish soap as lubricant on injectors. Pick your poison and install.
As long as you didn't roll the o-ring or cut it you shouldn't have an issue.
TJ
Pool Playen Bob is offline   Reply With Quote
Old 10-08-2012, 09:18 PM   #3
fastawdtsi
Thanks for the reassurance. :-)
Old 10-08-2012, 09:21 PM   #4
Yxd68
Yxd68's Avatar
As noted above, modern o-rings are impervious to almost everything. And it's not like you're lubing the o-rings on the oxy-acetylene torch regulators or your scuba tank where oil would be a bad thing.
I use isopropanol (rubbing alcohol) as lube for hoses, o-rings, etc. that need to be wet and slippery to install. Dries fast, smells great, leaves no residue.
Yxd68 is offline   Reply With Quote
wtb inlet pipe pmbaby24 Completed Transactions 5 02-01-2011 04:24 AM
F.s. Perrin Inlet Pipe!!! EVOXMAINE Completed Transactions 1 01-05-2010 05:05 PM
F/S Blitz Turbo Inlet pipe (suction Pipe) boostsaves Completed Transactions 19 05-28-2009 02:50 AM
Water pump w/ rubber impeller? Kooldino Evo X Engine (4B11T) 17 02-01-2008 03:01 AM
