Filed under:
Technology,
Videos,
Crossover,
Ford
All automakers test for noise, vibration and harshness (or
NVH) during the development of new vehicles, but
Ford Motor Company uses a portable "environmental chamber" that it can take to a specific plant to pull production vehicles from the assembly line for testing. In the case of this video, the portable machine was at
Louisville Assembly Plant to test the
2013 Ford Escape during its early launch, but Ford also sent one to Mexico during the early build of the new
Ford Fusion.
These mobile testing facilities are housed inside of semi trailers, and in addition to having four posts that can be positioned under each wheel to simulate driving over various roads, the chambers can also vary in temperature from 20 degrees below zero Fahrenheit to 140 degrees Fahrenheit. All of this can be changed and controlled using computers. During the tests, technicians and engineers sit inside the vehicle and listen for any squeaks or rattles. The benefit of having such a device on hand rather than sending the car to Dearborn is that problems can be detected earlier and resolved sooner.
Check out the video
below to see how Ford's mobile quality control system works.
Continue reading Watch Ford test the Escape for NVH issues in a portable chamber
Watch Ford test the Escape for NVH issues in a portable chamber originally appeared on
Autoblog on Sat, 13 Oct 2012 15:01:00 EST. Please see our
terms for use of feeds.
Permalink |
Email this |
Comments
More...
