Tune required for FMIC? - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Sponsored by:
Old 10-28-2012, 03:19 AM   #1
Silverton
Member
Silverton's Avatar
I'm thinking of adding a cat-back, UICP and an FMIC. Is a tune required for a 2013 MR?
Silverton is offline   Reply With Quote
Old 10-28-2012, 03:21 AM   #2
Snakes709
[Local Team Member]
yes, your boost will most likely be to high.
2011 EvoX GSR - AMS: SS Brake Lines, LICP w/ TiAL QR BOV, AEM Wideband and Boost Gauge, Tomei Expreme Exhaust, TWM STS w/ Cage Replacement, FIC 1100cc injectors, ETS 4" IC, 3port, Walbro 255lph, AEM FPR, Perrin RSB and Rear endlinks, SSP Underpanel, Enkei PF-01's, Varis Lip, AMS CMC, ACT HD 6 Puck and ACT Streetlite flywheel
Build Thread
Snakes709 is offline   Reply With Quote
Old 10-28-2012, 04:32 AM   #3
GGevo10
GGevo10's Avatar
I ran all 3 of those exact parts and those only for probably 7 mounts with no problems
2011 Gsr
Ams: fmic, uicp, intake, tune
Ets: V2 turboback with Hfc
GM 3-port
Cobb acessport
Aem:wideband, Boost
Comp clutch stage 2/ Magnus cmc
Muellerized Ohlins Dfv
Whiteline RCK
Ferodo 2500, SS lines
GGevo10 is offline   Reply With Quote
Old 10-28-2012, 05:29 AM   #4
Chaz17
Forum Addict
Chaz17's Avatar
Not required, but strongly suggested. You will not blow up your motor, but you will not be getting all you can out of the mods.
Originally Posted by Demi View Post
I knew I could take this thread gay. Knew it the moment I read it.
Its called Intent Driven Ricerery. Or IDR. Fully covered in great detail in my upcoming book. "50 Shades of Rice: The unabated putrefaction of the American auto culture".
Also available in audio book. Narrated by me, drunk, doing my best Christopher Walken impression.
Chaz17 is offline   Reply With Quote
Old 10-28-2012, 05:07 PM   #5
TheBlade
X-phile
TheBlade's Avatar
I did intake, UICP, LICP and an ETS 3.5" FMIC and CBE with no tune, never saw boost spikes.
In the research I did before doing that setup for awhile, I was seeing people with overboost problems also having a testpipe.
2011 Evo X GSR, WW, Sight & Sound + Sun & Leather
Tuned by WingzPerformance
K&N Intake - K&N UICP - ETS FMIC - ETS LICP - Rexspeed TP - GReddy Ti-C CBE - GS 3port EBCS - Swift Springs - Bilstein MR Struts
TheBlade is offline   Reply With Quote
Old 10-28-2012, 05:10 PM   #6
it's just a six
Member
Question
Is that because the wastegate flapper valve is too small & or the turbine housing wastegate hole needs to be inlarged?
I know on Syclones this is a problems also, mainly because the wastegate hole is too small.
it's just a six is offline   Reply With Quote
Old 10-28-2012, 05:10 PM   #7
Snakes709
[Local Team Member]
Heres what i did to my car....
K&N drop in filter + AMS DP + T1R Res TP = 23psi
AMS DP + T1R Res TP + UICP + AMS CAI = 26psi
AMS DP + T1R Res TP + UICP + AMS CAI + ETS 4" IC + LICP + Tomei Catback = 30psi
All that parts and no tune. Once i had all those parts on, any time i went WOT, which was only once, the CEL would come on and the car would start bucking like a horse. I then installed my injectors, 3port and fp red and got a tune.
Build Thread
Old 10-28-2012, 05:16 PM   #8
ZeroCooll21
[NEEvo VP]
ZeroCooll21's Avatar
This. Don't mess around with the car because you want to try an save money. do it right and the car will be right by you. You wont notice much gains until you get a tune. With those parts + tune it will be a completely different car.
Do you monitor your car? Just because you haven't had a problem, yet, doesn't mean its okay for the rest of the world to do it. Again the tune is where the real power comes. Monitor your car and make sure things are good.
RIP Lomker
ZeroCooll21 is offline   Reply With Quote
Old 10-28-2012, 05:18 PM   #9
TheBlade
X-phile
TheBlade's Avatar
I was just saying, I ran all the bolt-ons in front of the turbo, and ran stock dp, stock cat, and with a CBE and didn't see any overboosting.
The day I installed my TP I got my tune.
When it comes to details about the wastegate on the turbo, I couldn't tell you. I for one am not going to actually swap my turbo and downpipe when I do next year. The job is a royal PITA on the X, and I know with my temper, I'll likely break one of the studs. So, I've never physically laid eyes on the OE turbo yet, other than pictures. I just paid attention to people complaining of overboosting without a tune. Most of them had test-pipes.
--> Snakes post is a good example, he was running a testpipe when he saw higher than factory boost.
I was using Torque on my phone connected to my ODB2 adapter, and would datalog my trips to work. I had it alarm anytime I hit higher than 23psi. The highest I hit was 23.1psi one time.
My general advice though, Do your bolt-ons, and then get tuned anyway. The car really makes a big difference in power above 5500rpms with a tune. It feels amazing
Old 10-28-2012, 09:15 PM   #10
sellout
sellout's Avatar
I swapped to a panel filter and saw boost spiking to 24ish on my completely stock 2010. When I put on my synapse piping/intake/DV kit I saw spikes to 27 sometimes.
No two cars are the same, quite a few people get away with more than I did without seeing spikes. You need to have some method of changing things in the tune (open source/Cobb AP) before changing hard parts if you want to be safe.
I had a tactrix cable before I bought a panel filter. I wouldn't recommend any other way...
sellout is offline   Reply With Quote
ETS Mitsubishi Evolution X Intake - No Rescaling/Tune Required! ETS Michael Merchant Marketplace 6 11-03-2011 02:12 AM
2008 GSR Ivey Tune - FMIC, UICP, Turbo XS, HKS Panel ice1874193 Evo X Tuning 10 10-07-2011 10:25 PM
New Fuel Pump: Tune Required? hotdog Evo X Engine (4B11T) 21 04-15-2010 06:42 PM
Is a tune required after intake manifold upgrade? LVSBB6 Evo X Engine (4B11T) 24 06-18-2009 05:03 AM
Does FMIC mean a new tune? DP03 Evo X Tuning 4 05-16-2009 01:05 PM
