| Evo X Performance General discussion for performance topics that are unique to the Evo X. IF THE TOPIC IS COMMON WITH OTHER LANCERS, PLEASE POST IT IN: '08+ Lancer Common. |
#11 |
X-phile
My kit cost me about $450 for the tank and in tank 044 pump and mounting hardware. The fuel lines (hard, flex) and fittings were another story. I run e-85 100% of the time so I wanted ultra-flex lines to be worry free in the future. Expensive as hell. Lines and fittings along with the micron filter cost me another $700-$800! I have a write up on my setup if you're interested.
| Sponsored Links | |||
Advertisement | |||
#12 | |
2011 MR ETS UICP, 3.5 IC MAP EF3, ID1000s, Boomba Rail AMS tune, SS lines, DP, Cat-back Single, FPR Kit Kozmic K27 Surge Tank, SSP Cooler Kit, Undertray Sakura 3' intake, Driven Mfg Catch Can MOMO seats, ARP Wheel Studs Racing Brake 2-piece rotor, calipers, XT970 pads Grimmspeed 3pt, ported exh manifold Whiteline RSB, endlinks, RCK, Caster kit, Frnt Bushings Stance Pro Comp 2 Coilovers Mishimoto X-line Radiator Enkei RPF1, Konig Milligrams, Toyo RA-1/RR Autopower roll-bar |
#13 |
X-phile
http://www.evoxforums.com/forums/showthread.php?t=64130
Ultraflex 650 lines -8AN These are almost $40 per foot! 034 motorsports surge tank and it holds a bosch 044 pump submerged inside the tank. You can check out their website and see how it works. Last edited by Doubl-0; 11-21-2012 at 07:56 PM. |
#14 |
Dang sir,that is sweet. I love it. I still think I'm gonna try to Radium, mainly because the pump-in-tank design interests me. But well done!
#15 |
X-phile
I could have went a cheaper route with the lines but I didn't want to go half ass since I was already crossin that line and in the surge tank territory anyway so I said hell with it.
Thanks and good luck with your choice. |
#16 |
Hmm, lets continue this discussion because I'm very interested in this. So basically the wally 255 is probably the best bet for 93, but I don't want to have to upgrade the pump later so the question is if I got a bigger pump in the surge tank I assume I will also need a bigger pump in my car also? Could I get like say an Aeromotive 340 or Wally 400 which should be good for decent power on E-85 and run it on 93 from my surge tank and keep my wally 255 in my fuel tank, then later on upgrade my fuel tank pump (if required)?
![]() Jacks Built TC SUPER CHEAP For Sale! http://www.evoxforums.com/forums/sho...d.php?t=106425 Sponsored by Hoover Mitsubishi My Blog: http://mancemotorsports.com Build thread with lots of vids: My Dumb (don't read me) build thread BB FP Red. 438whp / 377wtq Self-Tuned. RIP Possum 6/22/2012 Killed by an Evo in the pursuit of horsepower. |
#17 | |
#18 |
Great find and thanks for posting! Looking at the video on their website, it looks to ME like the only difference between this setup and my EvoD surge tank is that the inline fuel pump is mounted INSIDE the surge tank, and not on the outside like mine. I would guess that the advantages of this would be less noise and better cooling of the pump? I still think you will have the same issues with higher baseline fuel pressure, though.
Orthojoe 2013 Subaru BRZ limited WRB pearl 6MT 2011 Porsche Boxster Spyder Carrara White/PCCB 6MT 2008 RR Evo X MR - SOLD |
#19 |
[Music Mod]
[FS Mod] [E-Tuner] |
Beeble can provide some great input, he has one of Radium's surge tanks
![]() < 3000 lb Evo 10 w/ full tank Interested in Sakura Performance parts? shoot me a pm RIP mlomker PM me if you are interested in a E-Tune or Road tune |
#20 |
^ he sure does
![]() mine has twin walbro 255s in it (the internal pump option) things to note : - the 255s are LOUD with this mounted in the trunk. much like external 044s would be. - fuel pressure with both running at the same time is huge, like 70-80psi at idle. my recommendation would be : - run the pumps sequentially, either via hobbs switch, or use the Hotstix/Beeble method of Load-triggered secondary pump. you only want one pump running at idle/cruise. - or get say the walbro 400 E85 option, and run that pump using the stock fuel pump wiring. so you have low/high voltage. and run the pump in the oem tank on constant voltage (it only needs to be small, oem pump is fine for almost any application or DW65c) - or use a quiet pump (eg DW300) for your always-on pump, and a cheaper 255 for your secondary pump. does it work - yes it works great. no surge while racing whatsoever. that's on 14kg springs, 265 soft semislick rubber, even on long sweeping left handers. it's small-ish it looks great it's very well made it doesn't leak so my current setup is.... DW65c in main fuel tank on stock wiring. return drilled to 3mm. Primary 255 in EST always on, full voltage via external relay Secondary 255 in EST turns on when Load hits 160, triggered by ecu via relay. i have a fuel pressure gauge in my car. as it comes on boost and the secondary pump kicks in, fuel pressure will jump from say 55psi to 80psi in a flash. you need to tune around that but it's not hard. while driving you're almost always above 20psi, or below 10psi really. it's rare to have situations where the seconadary pump is flicking on and off all the time (and f***ing with your fuel pressure big time) my base pressure will go down to 35psi. i run 45psi base. i can run the oem fuel tank dry, no pickup issues. ![]() ![]() ^^^ the lines aren't routed that way now, they go through the vent on the left there. but you get the idea.
X MR - MAP 2.2/GSC S2/mongrel GTX3576/FIC1100/ETS cooler/UR catback/Arogosta coilies/Whiteline sway Tuning help for your Evo or RA? PM me!
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| in-tank surge tank fabrication attempt underway... | prowakeskater | Evo X Performance | 61 | 11-11-2012 01:53 PM |
| oil can and surge tank | chrisgibson333 | Evo X Engine (4B11T) | 5 | 06-19-2012 10:41 AM |
| Surge Tank-E85 | hotstix | Evo X Engine (4B11T) | 56 | 05-24-2012 12:50 AM |
| Surge Tank Gurus... | hotstix | Evo X Engine (4B11T) | 0 | 11-04-2011 06:12 AM |
| New Blitz intake surge tank | jmayevox | Evo X Performance | 5 | 05-28-2009 11:16 PM |
