| ECUFlash / OpenECU Subforum for discussion about ECUFlash / OpenECU software and tuning. |
#1 |
ECU bricks on anything other than stock maps
Hey guys...so ive ran into a problem. Hoping i wont need a new ECU 2010 SE every time we try and flash a new map its bricking. Original base map ended up being bad so grabbed the 2010 MR stock map and works fine, just cant get a tune to stick at all. Flash completes without errors but car fails to start and have to bench it back to the stock map.
Since im running ams intercooler, uicp, ams turboback ehaust, and ams intake really not comfortable driving around on base maps. Any ideas? Thinking maybe a voltage spike during the flash?
2010 Phantom Black Evo SE #2 HP: 302 Torque: 332 @ 25psi boost -AMS: Black Intake w Bungs, Turbo Back Exhaust, FMIC, Black UPIC, Tranny Cooler w Fan -SSP: Tranny Filter -Hallman: Manual Boost Controller -Vanity: CF Vortex Generator, CF Wing, CF Front Grill, CF Foglight Surround, Tinted Windows, Blackout Side/Rear reflectors, NAVI, Wheels powder-coated black -Tuned by ES Tuned, Tucson AZ |
| Sponsored Links | |||
Advertisement | |||
#2 |
[Local Team Member]
I would say it has to do with the actual tune and not the actual loading of the map.
2011 EvoX GSR - AMS: SS Brake Lines, LICP w/ TiAL QR BOV, AEM Wideband and Boost Gauge, Tomei Expreme Exhaust, TWM STS w/ Cage Replacement, FIC 1100cc injectors, ETS 4" IC, 3port, Walbro 255lph, AEM FPR, Perrin RSB and Rear endlinks, SSP Underpanel, Enkei PF-01's, Varis Lip, AMS CMC, ACT HD 6 Puck and ACT Streetlite flywheelBuild Thread |
#3 |
Its possible, but Evan has done a bunch of 10s w/o problems. Everyone here has used him with great results.
#4 |
[Local Team Member]
Do you guys have the right defintion/Rom ID for your car?
#5 |
Fairly certain, loaded up the stock MR rom just fine. anything other than that is whats causing the bricking.
well, I should say stock, as the stock MAP went bad, had to pull a base MR off of here. Ill have him double check to ensure he isnt trying to tune a GSR MAP when loading in the tune, but culd you think of anything else? We think there might be a porblem with the ECU, though I hope not.
#6 |
[Local Team Member]
I cant see it being a issue with the ecu if it accepts the new stock map. It does fire up and drive with that map, correct?
#7 | |
X-phile
*experienced tuners chime in if that's a crap suggestion
2012 GSR H&R Springs - ETS Intake - ETS HFC - ETS V2 Quiet - Depot UICP - ETS 4in FMIC - ETS LICP - Innovate WB o2 - Grimmspeed EBCS - Clipse tune |
#8 |
Indeed, it does drives just fine with the stock MAP.
Essentially it goes like this: Loaded up stock MAP, plugged in ECO, started car just fine. Turn car off, turn key to start, load up tuned MAP, bricks ECU. (Trying to start car it cranks over and over but doesn't ignite, leaving on start turns on all fans, etc) Bench the ECU again, reload stock map, car works again. Brand new tactrix cable and open port as well, jsut came in today. Maybe the MAP we are trying to load is bad now, though he has used it for other MR's just fine. Maybe its a voltage surge when remapping when plugged into car?
#9 |
[Local Team Member]
can you copy/paste what the loading screen says on the laptop?
#10 |
At home now, but the screen was the successful one, gives the pop up saying Operation completed successfully, if done with ECU turn ignition off. Going to get back together thursday with him, just trying to come into it with any suggestions people might have to make things work. I know he will be calling up one of the guys at Cobb to talk to them and see if they have any advice.
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Help On Locking ECU Maps | Wicked White | ECUFlash / OpenECU | 19 | 03-02-2012 07:21 PM |
| Skyjack DUI - When you see it, you will sh*t bricks... | Clipse3GT | Off topic | 14 | 01-11-2011 06:32 AM |
| 1st time on dyno- Perrin Stg 1/Cobb stock maps | twistyking | Evo X Dyno | 4 | 12-01-2010 06:03 PM |
| 646whp on Stock Motor & Stock ECU | Gump | Evo X Performance | 43 | 03-04-2010 02:56 PM |
| Stock ECU Reflash | Khoupdaboss | Evo X General | 3 | 10-04-2008 05:55 PM |
