FS: Carputer and Accesssories - Page 5 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Non-Merchant Marketplace > For Sale (car parts)
For Sale (car parts) Post your for sale threads here. For all threads not linking to an ebay item, a photo of your item along with a hand written sign with your username is required. Only Verified Members can start new threads.
Old 01-18-2013, 04:59 PM   #41
EvoXMRSleeper
EvoXMRSleeper's Avatar
Bump
Sponsored, built and tuned by Performance Race Solutions
Built Motor with AMS 750r Turbo Kit
MR to GSR tranny conversion completed!
Carputer Sale
EvoXMRSleeper is offline   Reply With Quote
Old 01-21-2013, 12:26 AM   #42
EvoXMRSleeper
Bump
Old 01-23-2013, 10:28 PM   #43
EvoXMRSleeper
Bump
Sent from AutoGuide.com App
Carputer Sale
Old 02-09-2013, 06:53 PM   #44
EvoXMRSleeper
Bump
Carputer Sale
Last edited by EvoXMRSleeper; 02-14-2013 at 10:45 PM. Reason: Items separated for sale.
Old 02-14-2013, 10:45 PM   #45
EvoXMRSleeper
Bump. Items separated for individual sell.
Carputer Sale
Old 02-17-2013, 06:14 PM   #46
EvoXMRSleeper
Bump
Old 02-17-2013, 07:01 PM   #47
1stEVO
X-phile
1stEVO's Avatar
I have been keeping my eye on this for a little while. Couple questions that I have:
-for the 12v power, would you need to have a surge protection or would you route this like you route this like an amp.
-I have an aftermarket amp already, so with having that this would be more plug and play? Could you take a picture of the back with all of the connections/ports?
-Is the carputer the same size in length?
2008 Mitsubishi Lancer Evolution GSR w/ SSS
I hooked up my accelerator pedal in my car to my brake lights. I hit the gas, people behind me stop, and I'm gone!
1stEVO is offline   Reply With Quote
Old 02-17-2013, 07:24 PM   #48
EvoXMRSleeper
1. The power supply consumes 160W max, so it should not require any additional capacitors. The processor chip is also only 35W, which was purchased due to it's low power consumption.
2. Attached above is a photo of the back of the radio. You would run a connection from the 3.5mm green outlet.
3. The motherboard, processor, power supply, and hard drive are mounted inside of the double din casing. It measures 8.5 inches in depth.
Carputer Sale
Old 02-17-2013, 07:49 PM   #49
1stEVO
X-phile
1stEVO's Avatar
Thanks man!
ok dumb question possibly, powering, there are 3 wires. Obviously Red goes to positive, I would guess that black goes to ground, but white, would that also be ground? Or would you run black all the way to negative.
Also how do you think it will be with cooling or staying cool? I know my double din has a tiny fan in it. With it being a computer I would assume it is going be running even hotter.
Old 02-17-2013, 07:56 PM   #50
EvoXMRSleeper
Thanks man!
White goes to ignition. I would keep the ground as short as possible, so somewhere up near the center console.
I am not really sure with the cooling. I have not seen too many issues with the guys who have ran the computer in the dash. I have a small fan that could be mounted on the back plane if cooling became an issue.
Carputer Sale
EVO X CarPuter SupremeX '08+ Lancer Common Electronics & Audio 42 07-19-2012 02:56 PM
Carputer danielskshin Completed Transactions 18 05-19-2010 09:39 PM
for all the guys with the carputer G REMOTE ! sfdjflip '08+ Lancer Common Electronics & Audio 1 09-27-2009 05:26 AM
Carputer ..... boy36 '08+ Lancer Common Electronics & Audio 8 01-07-2009 03:24 AM
