EcuFlash 1.44 - Page 3 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 01-02-2013, 05:38 PM   #21
Joeyrukkus
X-phile
Originally Posted by Yxd68 View Post
Can't imagine how that could ever work - there is no clock mechanism or battery in the dongle.
It would need to read date/time data in the OBD2 data stream - is there such a thing?
The update reads, "Driver synchronizes OP2 to system clock to allow log files to have correct time / date if OP2 remains plugged into the car"
I am thinking that for those of us that leave the tatrix plugged in it would just need an initial date and time (not sure if this comes from the laptop or car) then calculates a readable date/time from that point on as long as the unit has power.
P.s. there is a clock mechanism in the dongle just not in the way you are thinking of it. When you do stand alone logging it counts the seconds so you know how far apart the data points are. What it doesn't have is a way of counting time when the unit has no power and no way of knowing the initial date and time when it gets power. It wouldn't be that hard to give it a start date/time from a system clock when it's plugged into the car and calculate something readable from there.
2012 GSR
H&R Springs - ETS Intake - ETS HFC - ETS V2 Quiet - Depot UICP - ETS 4in FMIC - ETS LICP - Innovate WB o2 - Grimmspeed EBCS - Synapse DV - Clipse tune
Joeyrukkus is offline   Reply With Quote
Old 01-02-2013, 08:06 PM   #22
Joeyrukkus
X-phile
Looks like it worked good for me, still need to go check to make sure all the parameters are still logging correctly.
2012 GSR
Old 01-02-2013, 08:17 PM   #23
TravisF
Check the files and make sure the data was scaled correctly. Mine weren't when the date thing started working
TravisF is offline   Reply With Quote
Old 01-02-2013, 09:39 PM   #24
drkramm
drkramm's Avatar
get one of those battery powered phone chargers
drkramm is offline   Reply With Quote
Old 01-04-2013, 10:54 PM   #25
Kooldino
Dino
[Administrator]
[Approved Merchant]
Kooldino's Avatar
So just to be clear, this version should work with my current XMLs for the X?
Ball Bearing FP Black strapped to a SpeedCircuit 2.2L engine. Life is good.
Like us on facebook - http://www.facebook.com/speedcircuit
Kooldino is offline   Reply With Quote
Old 01-04-2013, 11:08 PM   #26
chetrickerman
[Music Mod]
[FS Mod]
[E-Tuner]
chetrickerman's Avatar
Yes
< 3000 lb Evo 10 w/ full tank
Interested in Sakura Performance parts? shoot me a pm
RIP mlomker
PM me if you are interested in a E-Tune or Road tune
chetrickerman is online now   Reply With Quote
Old 01-11-2013, 06:21 PM   #27
Joeyrukkus
X-phile
Mine appear to be working correctly. I'm not loggin a ton of stuff tho and I still need to do some driving around. Overall tho, super happy with this update. 24/7 logging FTW!
2012 GSR
Old 01-12-2013, 01:21 PM   #28
rpacheco
Member
I'm using it with no problems. Flashed maybe 3 times and also used the embedded DTC disable. Everything works fine, including stand alone logging.
rpacheco is offline   Reply With Quote
Old 01-13-2013, 01:39 AM   #29
crimson red
Member
crimson red's Avatar
EcuFlash has been updated to 1.44.3721.
Changes since 1.44.3719 version:
EcuFlash
--- features --
Update checker now looks at build numbers to notify you of incremental improvements that don't have a new minor version change
--- bug fixes ---
Fix bug where patches and some other metadata was not appearing in metadata view
crimson red - 08' Evo X GSR(JDM) - Golden tuned with RAX Patches
After parts : GrimmSpeed 3-port, TOMEI Outlet pipe & EXPREME Ti catback, ARC titanium UICP, AMS air intake & LICP with TiAL QR BOV, stock turbo.
Tire : DUNLOP direzza z1 star spec.
Favorite foods : susi, tofu, noodles.
Other Favorites : hot springs.
crimson red is offline   Reply With Quote
Old 01-13-2013, 03:30 AM   #30
ihatefwd
[Local Team Member]
ihatefwd's Avatar
Just updated mine and got some new stuff. Since I see mode 23 and it shows as enabled, does that mean I have mode 23? I tried using evo scan and it doesn't work with mode 23 selected.
2008 Evo X GSR Phantom Black SSS with navi
ihatefwd is online now   Reply With Quote
Ecuflash help. Ralliart26 ECUFlash / OpenECU 0 11-07-2011 04:30 PM
HELP! ECUflash Rik84 ECUFlash / OpenECU 26 01-20-2010 03:58 AM
ECUFLASH: Noob Questions Regarding ECUFLASH Clipse3GT ECUFlash / OpenECU 16 09-11-2009 04:02 PM
ecuflash neng1987 ECUFlash / OpenECU 2 09-06-2009 11:03 PM
ECUFlash and ECUFlash Maps Subforums verkion Evoxforums.com - Site Suggestions and Help 3 02-09-2009 04:26 AM
