discreet data logger - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > '08+ Lancer Common > '08+ Lancer Common Electronics & Audio
'08+ Lancer Common Electronics & Audio General discussion for electronics & audio topics that are common among all 08+ Lancers.
Old 01-01-2013, 12:37 PM   #1
killamd
n00b
I'm looking for a small data logger that uses wifi or something that can be built in to the Evo X. I want it to monitor boost/temp/pressure/etc and with good data logging capabilities. (I don't want to have my dash full of pods, gauges etc)
I was originally looking at the AiM MyChron3 Gold but it doesn't really look like it can be built in to the dash. I would even go for something that has usb ports that I can plug in a ipad, monitor etc to. Anyone know of any hardware/software that is capable of this?
vincere est vivere
killamd is offline   Reply With Quote
Old 01-01-2013, 01:18 PM   #2
orthojoe
orthojoe's Avatar
Have you looked at AiM solo DL? That's what I use
Orthojoe
2013 Subaru BRZ limited WRB pearl 6MT
2011 Porsche Boxster Spyder Carrara White/PCCB 6MT
2008 RR Evo X MR - SOLD
orthojoe is offline   Reply With Quote
Old 01-01-2013, 03:50 PM   #3
byebye
[CEEvo Treasurer]
byebye's Avatar
I just picked up a bt obdII and I'm running torque pro on android. I haven't done any logging but read into it. It's pretty good so far but I just used the gauges(boost, throttle position).
It will log and it will use the phone's GPS and save your trip and show you how fast you were going at different points. It's pretty good.
It's not available for the Iphone, only android.
Kris
byebye is offline   Reply With Quote
Old 01-01-2013, 03:53 PM   #4
r34p3rex
[Local Team Member]
r34p3rex's Avatar
Tactrix cable seems to fit your needs, no? It logs everything to microSD Or you can plug it into a laptop and run some Evoscan
ams. downpipe | intake agp. uicp | licp | fmic dw. dw300 id. id1000 isc. n1 coilovers perrin. 3-port synapse. synchronic bov tomei. ti exhaust | ti test pipe
E85 ARMY. 345whp/375wtq dynodynamics.
388whp/394wtq virtualdyno
r34p3rex is offline   Reply With Quote
Old 01-01-2013, 10:55 PM   #5
mindovaanything
mindovaanything's Avatar
This is definitely the most cost effective and discreet solution if you want to log but don't want/need to view the info/gauges while driving. Search standalone datalogging tactrix and you will find a lot of great info on it. Could also check out the evodroid7 keep it stashed in the glovebox for discrete and put it on the suction cup mount if/when you want live viewing.
mindovaanything is offline   Reply With Quote
Old 01-02-2013, 12:41 AM   #6
killamd
n00b
Thanks for the input guys. I'll take a look at all those suggestions.
vincere est vivere
Old 01-02-2013, 01:35 AM   #7
killamd
n00b
How easy is it to monitor data (pressure, temperature, etc) with the Solo DL?
I was looking at the EvoScan GPS Navigator and I liked that one too; but, I didn't see any sort of lap timer/track capabilities like the Solo DL.
vincere est vivere
Old 01-02-2013, 02:29 AM   #8
orthojoe
orthojoe's Avatar
The other recommendations that were given to you are not for laptiming or track datalogging. Solo DL really is your best best.
You have to get the CAN line connector. It's one wire to tap into. Very easy. Very reliable. AiM software is initially difficult to figure out, but very powerful. Here's the link that shows you how to install the Solo DL through the CAN line, and what the CAN line will log for you:
http://www.aim-sportline.com/downloa...oX_101_eng.pdf
I messed around with Harry's laptimer and RaceChrono for a little bit. However, those options have reliability issues and the datalogging leaves much to be desired. I finally did some research, bit the bullet, and got the Solo DL. I've never looked back. I've been very happy with it.
Orthojoe
Old 01-02-2013, 02:32 AM   #9
orthojoe
orthojoe's Avatar
http://www.evoxforums.com/forums/sho...highlight=solo
Orthojoe
Old 01-02-2013, 05:32 PM   #10
killamd
n00b
The Solo DL looks very attractive but does it allow for monitoring of temp./press./etc. to the extent of EvoScan? If so, the choice is obvious.
vincere est vivere
Exhaust leak: raw data vs cpu data Five-seveN Evo X Tuning 1 12-14-2010 01:57 AM
(Data Request) - Looking for Green/Red Load data tsitalon1 Evo X Tuning 2 05-22-2010 11:05 PM
EVOXLogger - command line logger (Mode23) funks Evo X Tuning 14 10-25-2009 05:02 AM
REPORT: More Europeans prefer to go shaved for the discreet look testdummy Automotive News, Articles & Pics 1 10-12-2009 09:22 AM
Wideband guage/logger hookup Excalibur Evo X Performance 20 05-08-2009 02:27 AM
