| Evo X General General discussion on the 2008+ Mitsubishi Lancer Evolution X |
#21 |
I wouldn't think you HAVE to remove the stock NAVI, but you wouldn't be able to tap into it. You can always get a mount and place a screen on the top of your dash on the left side, like where you would mount a stand alone GPS or something. Wouldn't look to bad I dont think.
Probably what I might end up doing. Still debating a bunch of things.
2010 Phantom Black Evo SE #2 HP: 302 Torque: 332 @ 25psi boost -AMS: Black Intake w Bungs, Turbo Back Exhaust, FMIC, Black UPIC, Tranny Cooler w Fan -SSP: Tranny Filter -Hallman: Manual Boost Controller -Vanity: CF Vortex Generator, CF Wing, CF Front Grill, CF Foglight Surround, Tinted Windows, Blackout Side/Rear reflectors, NAVI, Wheels powder-coated black -Tuned by ES Tuned, Tucson AZ |
| Sponsored Links | |||
Advertisement | |||
#22 |
Very interested!
2012 WW GSR Evo X - SSL -GT Worx Tarmac Springs -Works Short Shifter (Kracka's Ultimate Shifter Package) -GrimmSpeed Electronic Boost Control Solenoid 3-Port -ETS Intake, Recirculated O2 Eliminator Downpipe, Test Pipe, V2 Exhaust -Tuned by Dirk @ AWD Motorsports - 362/375 |
#25 | ||
[Local Team Member]
![]() The essentials (must have for every system): 1) Touchscreen - ~$200 2) SOME KIND OF COMPUTER (could be a Mac Mini, could be custom built, could be a stripped down netbook or laptop) - $300-600. Those two items will get you a barebones computer to use in your car. If you have a Rockford Fosgate system (and don't want to replace your amp), you will need a MITO-02 adapter to turn on the amp. This will also act as your audio interface between the computer and sound system (it has 4 RCA audio inputs: Front Left, Front Right, Rear Left, Rear Right). You will then need a Tactrix cable if you don't have one already (~$100-150) and a copy of Evoscan ($25). Evoscan will be able to monitor everything accessible to the stock ECU such as Boost, Coolant Temp, RPM, Fuel Trims, TPS, IAT, etc. If you're looking to do oil pressure, wideband, EGT, etc, I'd highly recommend investing in a Zeitronix ZT-2 system. This is a standalone data collection wideband unit. It comes with a wideband sensor - other sensors such as EGT, Oil Pressure Sensor, Fuel Pressure are available separately and plug right into the ZT-2 unit (it has 2 user inputs that can be used for any combination of pressure and temperature sensors) in addition to a EGT probe input. The ZT-2 unit is connected to your computer via a RS-232 serial cable (you will need a USB to RS-232 cable - ~$10). If you already have a wideband, check to see if it has a serial output. If it does, it can be used with Evoscan with little to no modding. Other options such as GPS ($30-70), Webcams ($10-80), DVD drives ($15-30), mediacard reader ($5-30), are up to you. If you want radio, look into a Visteon HD Radio receiver ($50-70) and a MJS HD Radio USB cable ($40). Adding all the bells and whistles will not be cheap, but it won't ever cost more than a top end navigation headunit But what headunit can run Evoscan? ![]() Quote:
As far as input goes, just use a wireless keyboard/mouse combo unit
ams. downpipe | intake agp. uicp | licp | fmic dw. dw300 id. id1000 isc. n1 coilovers perrin. 3-port synapse. synchronic bov tomei. ti exhaust | ti test pipe E85 ARMY. 345whp/375wtq dynodynamics. 388whp/394wtq virtualdyno ![]() |
#27 |
Hrm. Would really be interested in seeing how to setup the stock NAVI to use as display. The more stock looking I can keep the car (Besides the few slight visual accents already done) the better.
#28 |
[Local Team Member]
Oh you can just replace the narrowband with a wideband?
#29 |
From my understanding you remove the rear o2 completely. Then you tap into the yellow wire that runs to ecu with your wideband wiring. Then you can just log af from the ecu. There is a write up on the forum about it. My guess is you would just plug the rear o2 bung since you'd probably want to use something closer to the DP.
#30 | |
[Local Team Member]
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Interest in a Roll Bar? | Gates311 | Ryan Gates' Corner | 246 | Yesterday 07:11 AM |
| Generate interest | airborne703 | Evo X General | 2 | 04-09-2012 09:22 PM |
| AMS Mani Interest? | BigStevbowski | Evo X Performance | 20 | 03-22-2011 02:48 AM |
| any interest in this pod? | Rexpeed | Evo X General | 40 | 06-18-2010 12:36 AM |
