New to Evo X...Need some pointers!!! - Page 2 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 01-14-2013, 03:39 AM   #11
Witte
Witte's Avatar
Thanks Doc that was helpful. As for right now all I plan on doing for now is intake, exhuast, and a flash tune for performance so the Cobb would work if I can get a good enough deal on one. If not a buddy told me there is a Dyno in Witchita, KS that was pretty decent at tuning, but I would have to check them out first before considering that. As for my questions, the DP/CP is my biggest thing does it make a huge difference to put in a test pipe and replace everything or is simply replacing the stock DP sufficient untill I start upgrading things like turbo, injectors, etc.
AMS SRA/Cobb AP/ClutchMaster FX400/MAP TP/Borla CBE/Eibach Lowering Springs/AEM UEGO/GrimSpeed 3Port EBCS/E-Tune by chetrickerman 333 WHP/323 WTQ
Witte is offline   Reply With Quote
Old 01-14-2013, 03:41 AM   #12
DocBoz
X-phile
DocBoz's Avatar
the cat pipe will be better gains than a DP, and just watch the for sale forums for a used AP i bought mine new and it wasnt worth the $500 they cost, you can get them used $3-400 on here. i sold mine for like 350 i think
Originally Posted by AndreNeves View Post
Mother of god. This thread went full GTR. You never go full GTR.
Check out my for sale thread, Aftermarkets and OEM stuff!
http://www.evoxforums.com/forums/showthread.php?t=71040
<Rickerman Tuned>
DocBoz is offline   Reply With Quote
Old 01-14-2013, 03:45 AM   #13
Witte
Witte's Avatar
Is there a major difference between 1 piece DP's that replace both the DP&CP and replacing each one individually with a DP and a test pipe with a resonator or high flow cat? I would prefer just to replace it with a single pipe (less shit to come loose one day) than two different pipes, but if it makes a mechanical/performance difference then I will do whatever is better for the car.
Old 01-14-2013, 03:45 AM   #14
WraithX
Dr. Evo?
WraithX's Avatar
Sorry man was just joshing with you! Best of luck with the new wheels.
Couple things to note about the DP:
Takes 5 hours to do, get the AMS unit.
Don't skimp on cheap mods!
WRAYTH
Kaizen Tuning 2.0L Shortblock
|Manley H-Beams|Cosworth Bearings|AMS Spec JE Pistons|
|Forced Performance
RED Ball Bearing Turbocharger|
|Custom Tomei ProCams |Kaizen 'Sakura' Race Manifold|
STOP BEING DICKS TO PEOPLE UNDER 100 POSTS
WraithX is offline   Reply With Quote
Old 01-14-2013, 03:50 AM   #15
Witte
Witte's Avatar
Thanks Wraith I will check it out, the 5 hours part is the reason I would prefer to only take this apart one time and just do it all right the first time. Does the AMS unit replace the DP and the cat pipe or just the DP?
Old 01-14-2013, 05:44 AM   #16
WraithX
Dr. Evo?
WraithX's Avatar
Just replaces the 02 housing and downpipe. You'll need a testpipe to eliminate the cat.
WRAYTH
|Forced Performance
Old 01-14-2013, 02:13 PM   #17
r34p3rex
[Local Team Member]
r34p3rex's Avatar
Originally Posted by WraithX View Post
Sell it back.
What happened to "STOP BEING DICKS TO PEOPLE WITH UNDER 100 POSTS"?
ams. downpipe | intake agp. uicp | licp | fmic dw. dw300 id. id1000 isc. n1 coilovers perrin. 3-port synapse. synchronic bov tomei. ti exhaust | ti test pipe
E85 ARMY. 345whp/375wtq dynodynamics.
388whp/394wtq virtualdyno
r34p3rex is offline   Reply With Quote
Old 01-14-2013, 02:17 PM   #18
Liquidlink
Liquidlink's Avatar
Took me/us about 9 hours ... :cry: ...
and +1 to not consider cheap mods evarrr!
Liquidlink is offline   Reply With Quote
Old 01-14-2013, 02:41 PM   #19
Witte
Witte's Avatar
Any other brands of DP people recommend? Price is a bit steep, but if its the best one for my car then so be it. As for a TP I will just get whatever brand matches the DP I get, then hook up the Borla cat back pipes.
Sent from my iPhone using AutoGuide.com Free App
Old 01-14-2013, 02:46 PM   #20
r34p3rex
[Local Team Member]
r34p3rex's Avatar
IMO, the only downpipes worth getting and installing are the AMS and the Tomei.. unless you want a O2 dump.. then get the ETS O2 eliminator pipe
Autocross help and pointers GundamPilot Evo X General 15 08-16-2012 05:04 AM
Pointers on trailing my Evo cross country? V8eatr Evo X General 32 03-29-2011 09:02 PM
Installed new front seats - my pointers segfault Evo X General 26 12-06-2010 12:38 PM
