Best Looking Tire Size - Page 3 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 01-16-2013, 09:24 AM   #21
armysoldier1073
X-phile
armysoldier1073's Avatar
Also know that not all tires run true to size. Decide what tire you want to run, then find out if they run small, big or true to size then figure the appropriate one.
RICKERMAN TUNED, MAP EF 2.5 ( ported and coated), DW1000 cc injectors, DW65c fuel pump, AMS UICP / INTAKE, GS 3 PORT, MAP O2 ELIMINATOR DP, CP-E RESONATED CBE, RB ET500 PADS, PROSPORT HOOD DAMPERS, ACT HD 6puck w/ Streetlite flywheel, Magnus kit w/ EVO 9 CMC, GTWORKS Tarmac springs, ETS 3" FMIC / HFC, RS fog delete, Zietronic LCD to monitor WB / Boost, WhiteLine 27mm rear sway
armysoldier1073 is offline   Reply With Quote
Old 01-16-2013, 09:41 AM   #22
Shaybird
Shaybird's Avatar
Thanks for the heads up!
Shaybird is offline   Reply With Quote
Old 01-16-2013, 09:44 AM   #23
drkramm
drkramm's Avatar
yea star specs run wide .... had no rubbing on my wrx with hankook tires switched to star specs and bam had to run .5 degree more negative camber
drkramm is offline   Reply With Quote
Old 01-16-2013, 09:50 AM   #24
Shaybird
Shaybird's Avatar
Do we have a thread on which tires actually match advertised specs and which ones size differently?
Old 01-16-2013, 08:57 PM   #25
Demi
Demi's Avatar
Wish we did. Im a big fan of coils for this and a number of reasons over springs. Coil provide a real upgrade, and you can adjust to clear your wheel. I rubbed on 265s on springs. Fucked up a nice set of tires the first time two buddies rode in the back.
Originally Posted by Locust View Post
  1. Demi's gonna Demi.
Newbie thread: http://www.evoxforums.com/forums/showthread.php?t=69576 READ IT.
Build thread:
http://www.evoxforums.com/forums/showthread.php?t=63832
Demi is offline   Reply With Quote
Old 01-16-2013, 09:19 PM   #26
trick3d
Forum Addict
trick3d's Avatar
unless you will be operating within a few mm of clearance most of us can tell you which models run large or not.
Ex: star spec 245/40 will be just a bit smaller than say a 265 RS'3.
Federal runs the same way.
2010 Stock Evo X SE
Mods: RS Fog Delete, Unicorn Blood Injection.
trick3d is offline   Reply With Quote
Old 01-16-2013, 10:02 PM   #27
Natek
X-phile
Natek's Avatar
Do Michelin PSS run large or small?
FP Red BB, MAP Ported Ex Manifold, AMS Downpipe, Perrin CBE, Depo Testpipe, AMS Intake, Depo FMIC, Depo LICP, ETS UICP, Grimmspeed EBC, Synapse Dv, TWM Shifter & Cage, AEM Boost Gauge, AEM Wideband, Cobb AP, Blaqops Walbro 255, FIC 1100's, MAP Fpr, DSG Gauge Pod, H&R Springs, Work Kiwami 18x9.5 +20, Michelin PSS 265/35/18, Hollywood Tuned
Natek is offline   Reply With Quote
Old 01-16-2013, 10:51 PM   #28
MikeM
MikeM's Avatar
guy i know has v12 275s on his x. I have PSS on mine i think mine look wider. Tire rack says the for a 275/35 the PSS have a 10" footprint where the v12 is the same size have a 9.5" footprint
Tomei/ETS/Works/Wedssport/Eibach/Work/Michelin
Rainbow/JL/Fi/Pioneer
I know the pieces fit.
MikeM is offline   Reply With Quote
Old 01-16-2013, 11:03 PM   #29
trick3d
Forum Addict
trick3d's Avatar
My 265/35 PSS are at least a few mm larger than my RS-3's in the same size.
2010 Stock Evo X SE
Tire Size 1stEVO Evo X Wheels, Suspension & Brakes 9 10-16-2012 03:22 AM
Spare tire safe to pair with non stock tire size? ryanhaggerty Evo X General 1 11-13-2010 02:00 PM
Help, tire size? Brown211 Evo X Wheels, Suspension & Brakes 4 09-26-2010 03:56 AM
tire size help dakoop Evo X Wheels, Suspension & Brakes 6 04-13-2010 03:28 PM
Tire size Calgarylancer1 Evo X Wheels, Suspension & Brakes 1 03-23-2010 10:49 AM
