IMAPCalcs is affecting WOT load calc. - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 01-15-2013, 08:32 PM   #1
UT_EvoX
UT_EvoX's Avatar
I'm posting this up in a public setting for the benefit of other tuners.
I've been chasing down a high RPM break up on my car and after several attempts at debugging my ignition system, I came to the realization that it may have something to do with load calculation, judging from the spikes I saw in my IDC graph.
I investigated further on the dyno and found that I get momentary dips in my load calculation which causes fueling to be disrupted and leads to minor misfires and break up in the upper RPM range (or at least must be contributing).
What I found is that each dip corresponds with a spike in IMAPCalcs up to 270-ish load when my MAP-calculated load is well over 300.
I have MAF calculation disabled above 3 V by having the MAF calibration values maxed out above that voltage in my MAF calibration map (i.e. hybrid speed density).
I've seen datalogs from hybrid or full speed density setups that do not have spiky load graphs at WOT, and was wondering what I've done wrong or what I can rectify to keep the IMAPCalcs (mind you, I have no idea what that value actually *is*) from affecting my MAP calculation.
Rich? Baka? Chet? Dino? Hollywood? Golden? tephra?
'08 Evo X GSR - self-built, self-tuned
MAP block - X-beam rods, Wiseco slugs, stock sleeves | Cossy MX1, BC springs
AGP turbo kit - PTE 6262 | Snow meth inj. | ETS IC + piping
Jack's upgraded trans + center diff | CM FX400 clutch
E85 VD: 700 WHP / 525 lb-ft | 608 WHP Mustang Dyno, 91 + meth
Build Thread - complete list of my build components and tuning experience and advice
Lead Calibrator - Ziptie Dynowerks, Utah
UT_EvoX is offline   Reply With Quote
Old 01-15-2013, 09:08 PM   #2
chetrickerman
[Music Mod]
[FS Mod]
[E-Tuner]
chetrickerman's Avatar
How much boost are you running?
< 3000 lb Evo 10 w/ full tank
Interested in Sakura Performance parts? shoot me a pm
RIP mlomker
PM me if you are interested in a E-Tune or Road tune
chetrickerman is online now   Reply With Quote
Old 01-15-2013, 09:14 PM   #3
UT_EvoX
UT_EvoX's Avatar
Over 9000.
This is happening worst in 4th gear during a quarter mile pull where I'm running 30 psi tapering to 29 on my 6262.
On a full pull, boost tapers from 34 psi to 29 psi.
Load is roughly 330-310.
Old 01-16-2013, 06:05 AM   #4
richardh
[Gearhead]
richardh's Avatar
Yeah, I know this. Tephra pointed me at it. I did some experimenting on my own RA... and recently rolled the tweak into the latest Ralliart Base Maps.
What's your ROM ID?
I'll post up the address of "Load multiplier end when TPS decreased by % (hysteresis)" for your ROM. You can change it from 0.4 to 0.8.
That should stop MAPCalcs and IMAPCalcs from bouncing around.
Rich
________________________________________
Lancer Ralliart. It's a computer game... with wheels!
richardh is offline   Reply With Quote
Old 01-16-2013, 10:17 AM   #5
drkramm
drkramm's Avatar
any love for 56890013 rich ?
drkramm is offline   Reply With Quote
Old 01-16-2013, 02:57 PM   #6
richardh
[Gearhead]
richardh's Avatar
UT_EvoX, you're on 52680122, aren't you.
Done. GoldenEvo.com is now updated to deliver this new item. It's updated for 52680015, 56890013, plus a bunch of Ralliart ROM IDs.
Once you've updated your XML, change "Load multiplier end when TPS decreased by % (hysteresis)" from 0.4 to 0.8. Let me know how it goes.
Cheers,
Rich
Old 01-16-2013, 03:03 PM   #7
UT_EvoX
UT_EvoX's Avatar
Rich, thank you sir. I'll be trying this out today!
I'll also see if it makes any difference on the dyno and report back. It's hard to get any high-speed pulls when it's 9 degrees F outside, so the dyno is my best friend right now.
Old 01-16-2013, 08:05 PM   #8
black e
black e's Avatar
Damn, I got left out
black e is offline   Reply With Quote
Old 01-16-2013, 09:27 PM   #9
drkramm
drkramm's Avatar
Cheers,
Rich
you rock.
thanks
Old 01-16-2013, 09:39 PM   #10
Kooldino
Dino
[Administrator]
[Approved Merchant]
Kooldino's Avatar
Originally Posted by UT_EvoX View Post
Over 9000.
Damn, son.
Ball Bearing FP Black strapped to a SpeedCircuit 2.2L engine. Life is good.
Like us on facebook - http://www.facebook.com/speedcircuit
Kooldino is offline   Reply With Quote
Boost Load Offset and Boost Target Engine Load HappyMint Evo X Tuning 6 12-08-2011 05:05 AM
Tire Size for EvoScan Power Calc qwertykerr ECUFlash / OpenECU 0 09-26-2011 02:04 AM
Noob question about Load/Target Load/Boost Offset Ozzyman Evo X Tuning 7 08-02-2011 03:59 AM
atr load tables maxed out at 340 load? 3dman1 Cobb AccessPort 44 02-21-2011 03:32 PM
Never at WOT??? cornercarver Evo X Tuning 11 01-12-2010 02:46 PM
