| ECUFlash / OpenECU Subforum for discussion about ECUFlash / OpenECU software and tuning. |
#11 |
[Gearhead]
I take it you want more ROM IDs done?
Will flesh out goldenevo.com more tonight. Rich
________________________________________ Lancer Ralliart. It's a computer game... with wheels! ////////// |
| Sponsored Links | |||
Advertisement | |||
#12 | |
Do you suspect any of the other MAP paramaters will affect my load calculation as I described it? If you can get the rest of those ones for 5268xxx I would be more prepared to get my car on the dyno tonight and I'll let everybody know which fix solved my WOT MAP calculation issue.
'08 Evo X GSR - self-built, self-tuned
MAP block - X-beam rods, Wiseco slugs, stock sleeves | Cossy MX1, BC springs AGP turbo kit - PTE 6262 | Snow meth inj. | ETS IC + piping Jack's upgraded trans + center diff | CM FX400 clutch E85 VD: 700 WHP / 525 lb-ft | 608 WHP Mustang Dyno, 91 + meth Build Thread - complete list of my build components and tuning experience and advice Lead Calibrator - Ziptie Dynowerks, Utah |
#14 |
It worked wonderfully. No more jagged load calculation, no more jagged IDC. I seriously was seeing like 10 IMAPCalcs spikes in one 3rd gear pull.
#16 |
Well, it's a hysteresis table, but yes. I increased it from 0.4 to 0.8% and it worked spot on.
#17 | |
[Gearhead]
I didn't work this stuff out, by the way. Tephra was the one who pointed me at the "hysteresis" value, and suggested the tweak as a way to eliminate the dodgy load wobbles. Worked a treat. Now, let's back up a bit and answer a more basic question... asked by Kooldino a short while back... WTF is IMAPCalcs? As noted in older research into load calcs (not mine), the ECU tracks three inputs... 1. MAFCalcs - derived from MAF (MAF Scaling tables, etc.) 2. MAPCalcs - derived from MAP (3xMAP Tables, etc.) 3. IMAPCalcs - "interpolated" variant, derived from MAP. Fun fact A: The ECU chooses the "middle" of the three. Fun fact B: Item 3 should always be lower than 2. Now, items 2 and 3 are kind of joined by the same rubber band... there is an interpolation/ratio mechanism that acts on both. That ratio mechanism gets buggered around with by a TPS-based input. If throttle is nailed to the floor, MAPCalcs should be nice and steady, and IMAPCalcs should be zero. But... the ECU does weird stuff behind the scenes with its TPS, including some odd "decay" processing over time. TPS can jitter slightly, and the default "hysteresis" value makes the load calc extremely sensitive to TPS jitter. So... IMAPCalcs is the canary in the coal mine. If you get any TPS jitter, the MAPCalcs may step up and down a little bit... but IMAPCalcs will look like a horrible sawtooth nightmare. It's a huge red flag. If you see an IMAPCalcs sawtooth pattern, you have a TPS->load-calculation problem. And how do you log IMAPCalcs? Why, RAX Fast Logging, of course! ![]() Rich PS. Here are some before-and-after images. Ignore ( A ) and look at ( B ) BEFORE: ![]() AFTER:
#19 |
[Gearhead]
Guys, if you change that hysteresis value from 0.4 to 0.8 and still get IMAPCalcs spikes at WOT, feel free to try 1.2.
Rich
#20 |
X-phile
IMAPCalcs is affecting WOT load calc.
BakaUnchi Tune in Progress... ![]() MR EDM SST Current Mods- ID1000cc/DW265c/DV Synapse/Harman Intake/GS3Port/AMS HFC/Perrin CBE/ETS 3.5IC/ETS Titanium UICP/eTune in Progress Incoming:AMS DP Ceramic Coated/EF2 turbo + All Options /MAP P&P Ceramic Coated OEM Exhaust Manifold |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Boost Load Offset and Boost Target Engine Load | HappyMint | Evo X Tuning | 6 | 12-08-2011 05:05 AM |
| Tire Size for EvoScan Power Calc | qwertykerr | ECUFlash / OpenECU | 0 | 09-26-2011 02:04 AM |
| Noob question about Load/Target Load/Boost Offset | Ozzyman | Evo X Tuning | 7 | 08-02-2011 03:59 AM |
| atr load tables maxed out at 340 load? | 3dman1 | Cobb AccessPort | 44 | 02-21-2011 03:32 PM |
| Never at WOT??? | cornercarver | Evo X Tuning | 11 | 01-12-2010 02:46 PM |
