IMAPCalcs is affecting WOT load calc. - Page 3 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 01-17-2013, 01:24 PM   #21
jyamona
hey Rich, can you find this table for 55570006 too?
2010 WW Evo X GSR w/ SSS
BAKA tuned - 422/347 (retune pending), MAP EF3 ported / antisurge, Full-race manifold, ID1000's, DW65C, MAP O2/DP, ARK testpipe, ARK N-II v2 catback,
3" intake, ETS 3.5" FMIC and IC pipes, Grimmspeed 3-port, Tial QR, Swift Spec-R's, Whiteline RCA Kit
jyamona is offline   Reply With Quote
Old 01-17-2013, 02:18 PM   #22
richardh
[Gearhead]
richardh's Avatar
Done. I've also done a load more - all the RAX Patch supported ROMs, as far as I can see.
Rich
________________________________________
Lancer Ralliart. It's a computer game... with wheels!
richardh is offline   Reply With Quote
Old 01-17-2013, 03:03 PM   #23
jyamona
Rich
you're the man!
Old 01-17-2013, 04:57 PM   #24
UT_EvoX
UT_EvoX's Avatar
Guys, if you change that hysteresis value from 0.4 to 0.8 and still get IMAPCalcs spikes at WOT, feel free to try 1.2.
Rich
I got a very small IMAPCalcs spike to 25 this morning, but only 1 and it didn't seem to affect my actual fueling.
Thanks again for helping with this.
'08 Evo X GSR - self-built, self-tuned
MAP block - X-beam rods, Wiseco slugs, stock sleeves | Cossy MX1, BC springs
AGP turbo kit - PTE 6262 | Snow meth inj. | ETS IC + piping
Jack's upgraded trans + center diff | CM FX400 clutch
E85 VD: 700 WHP / 525 lb-ft | 608 WHP Mustang Dyno, 91 + meth
Build Thread - complete list of my build components and tuning experience and advice
Lead Calibrator - Ziptie Dynowerks, Utah
UT_EvoX is offline   Reply With Quote
Old 01-17-2013, 07:05 PM   #25
sstevojr
X-phile
sstevojr's Avatar
Great info Rich!
Question,
It seems to me with a spot-on MAP calc (which all of us "extremist" types do) that IMAP serves no purpose but to bungle a well sorted fuel/timing Load map?
And 2, if I understand the hystersis table it allows for .4% TPS variation before applying an IMAP value (so we want to allow for 0.8 or 1.2% deviation to make it less sensitive)?
X-Swap Ralliart Sportback
For the best game in So-Cal, it comes down to one name
R /// R /// E
The greatest gift to an engine: Continuously Variable Valving
Next level sh!t: Continuously Variable Geometry (we all need dreams)
sstevojr is online now   Reply With Quote
Old 01-17-2013, 08:31 PM   #26
Murlo26
Forum Addict
Murlo26's Avatar
Very interesting. Finally some stimulating posts.
Maybe I'll check this out in spring when I work on the fast logging stuff.
MAP T4 TS 6266/ERL 2.2L 10:1 CR/E85
BakaUnchi Tuned
Murlo26 is offline   Reply With Quote
Old 01-18-2013, 03:00 PM   #27
Kooldino
Dino
[Administrator]
[Approved Merchant]
Kooldino's Avatar
Originally Posted by sstevojr View Post
Great info Rich!
Question,
And 2, if I understand the hystersis table it allows for .04% TPS variation before applying an IMAP value (so we want to allow for 0.8 or 1.2% deviation to make it less sensitive)?
If that's the case, then would there be any real disadvantage to increasing it to .8% by default?
Ball Bearing FP Black strapped to a SpeedCircuit 2.2L engine. Life is good.
Like us on facebook - http://www.facebook.com/speedcircuit
Kooldino is offline   Reply With Quote
Old 01-18-2013, 03:21 PM   #28
jyamona
I don't think so, no.
Old 01-18-2013, 04:25 PM   #29
UT_EvoX
UT_EvoX's Avatar
After logging for a day now, I would never recommend setting this value to anything but > 0.8%
I have no idea why it was set to 0.4% from the factory.
Old 01-18-2013, 04:50 PM   #30
sstevojr
X-phile
sstevojr's Avatar
I would "guess" that the factory setting was so sensitive because of the gap between MAP and MAF. It's probably used to prevent what they would consider as "extreme" load calc swings.
Since most of us remove/narrow the load gap, it sounds like an unneeded safety feature at this point (much like the SST's " overboost exceedance" table); making it less sensitive would "seem" like a good idea for those who have a well sorted MAP/MAF relationship.
R /// R /// E
Boost Load Offset and Boost Target Engine Load HappyMint Evo X Tuning 6 12-08-2011 05:05 AM
Tire Size for EvoScan Power Calc qwertykerr ECUFlash / OpenECU 0 09-26-2011 02:04 AM
Noob question about Load/Target Load/Boost Offset Ozzyman Evo X Tuning 7 08-02-2011 03:59 AM
atr load tables maxed out at 340 load? 3dman1 Cobb AccessPort 44 02-21-2011 03:32 PM
Never at WOT??? cornercarver Evo X Tuning 11 01-12-2010 02:46 PM
