Turbo swap with stock airbox? - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > '09+ Lancer Ralliart > '09+ Ralliart General
'09+ Ralliart General General discussion for '08+ Lancer Ralliart
Old 01-16-2013, 10:54 AM   #1
vermilioN
Member
I know its possible but could someone explain how you went about doing it (pictures would be appreciated)
vermilioN is offline   Reply With Quote
Old 01-17-2013, 12:58 AM   #2
vermilioN
Member
bump
Old 01-17-2013, 01:48 AM   #3
armysoldier1073
X-phile
armysoldier1073's Avatar
Not sure what your asking.
RICKERMAN TUNED, MAP EF 2.5 ( ported and coated), DW1000 cc injectors, DW65c fuel pump, AMS UICP / INTAKE, GS 3 PORT, MAP O2 ELIMINATOR DP, CP-E RESONATED CBE, RB ET500 PADS, PROSPORT HOOD DAMPERS, ACT HD 6puck w/ Streetlite flywheel, Magnus kit w/ EVO 9 CMC, GTWORKS Tarmac springs, ETS 3" FMIC / HFC, RS fog delete, Zietronic LCD to monitor WB / Boost, WhiteLine 27mm rear sway
armysoldier1073 is offline   Reply With Quote
Old 01-17-2013, 02:58 AM   #4
bigstakk
bigstakk's Avatar
All you would need is the Cobb fp turbo inlet pipe or the ATP 3' turbo inlet pipe to connect to the stock air box + drop in air filter...I'm going to use the stock airbox on upgraded turbo myself when I upgrade and going with the ATP pipe since it is metal...stock airbox is good till about 400-450whp...what did you have in mind?
2010 EVOLUTION X GSR / SSS / NAV / WW
RRE /// tuned w/ basic bolt-ons > 343whp/348wtq
Muellerized... stage 1 w/ Whiteline rck
Enkei raijin 18x9.5+15 w/ 255/40 Hankook v12s
bigstakk is offline   Reply With Quote
Old 01-17-2013, 03:16 AM   #5
morricus
morricus's Avatar
Are you keeping the stock airbox for CA emissions purposes? just curious.
2011 MR
ETS UICP, 3.5 IC
MAP EF3, ID1000s, Boomba Rail
AMS tune, SS lines, DP, Cat-back Single, FPR Kit
Kozmic K27 Surge Tank, SSP Cooler Kit, Undertray
Sakura 3' intake, Driven Mfg Catch Can
MOMO seats, ARP Wheel Studs
Racing Brake 2-piece rotor, calipers, XT970 pads
Grimmspeed 3pt, ported exh manifold
Whiteline RSB, endlinks, RCK, Caster kit, Frnt Bushings
Stance Pro Comp 2 Coilovers
Mishimoto X-line Radiator
Enkei RPF1, Konig Milligrams, Toyo RA-1/RR
Autopower roll-bar
morricus is offline   Reply With Quote
Old 01-17-2013, 03:33 AM   #6
Exyia
Exyia's Avatar
this is the ralliart section...
to answer the OP's question, you need to find someone to make a connector pipe. any decent shop at fabricating pipe can do it - just no shop has stepped up to make one for public production
Exyia's 2013 Build and Adventures!
Old 2012 Build Thread
Kozmic Motorsports
GTWorx / Race Comp Engineering
Forced Induction Development
Whiteline
Exyia is online now   Reply With Quote
Old 01-17-2013, 04:39 AM   #7
richardh
[Gearhead]
richardh's Avatar
sstevojr told me that RRE supplied him with the piping required to use factory Ralliart airbox with Evolution X turbo.
This is exactly how I intend to set up my X-swap... when I get around to it, lol.
Rich
________________________________________
Lancer Ralliart. It's a computer game... with wheels!
richardh is offline   Reply With Quote
Old 01-17-2013, 04:44 AM   #8
vermilioN
Member
So you can only do it with a fabricated inlet pipe?
Old 01-17-2013, 04:53 AM   #9
Exyia
Exyia's Avatar
the TD04 doesn't have a 90* inlet like the TD05. So it's like fitting puzzle pieces together from two different puzzles
it's really not the end of the world. ANY decent shop should be able to deal with it. a muffler shop could probably even do it - you just need to connect A and B somehow\
OR - you could relocate the battery to the trunk and use the OEM X intake piping
Kozmic Motorsports
Whiteline
Old 01-20-2013, 03:43 PM   #10
DocBoz
X-phile
DocBoz's Avatar
if you choose to relocate the battery i have the full oem x intake with k&n panel filter up for sale!
Originally Posted by AndreNeves View Post
Mother of god. This thread went full GTR. You never go full GTR.
Check out my for sale thread, Aftermarkets and OEM stuff!
http://www.evoxforums.com/forums/showthread.php?t=71040
<Rickerman Tuned>
DocBoz is offline   Reply With Quote
3" Turbo Inlet Suction Pipe To Factory AIRBOX RREVO Evo X General 10 06-04-2012 11:16 PM
Tuning help with Stock Airbox Calibrations Evo X Eva Evo X Tuning 2 04-05-2012 03:36 AM
stock airbox neng1987 Evo X Engine (4B11T) 9 04-09-2010 04:55 AM
