Question about Deceleration - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Sponsored by:
Old 01-16-2013, 10:07 PM   #1
tina
Banned
Sometimes (very rarely) when I let off the gas pedal, around either 3k or 2k RPMs, the RPMs don't go down and stick at the location they were at when I took my foot off the gas. Not sure what's going on just curious as to what's causing it and if it's something I need to worry about.
Thanks for any answers, greatly appreciate it!
tina is offline   Reply With Quote
Old 01-16-2013, 10:09 PM   #2
GSXRiderK6
X-phile
GSXRiderK6's Avatar
Most likely this is happening when you first start driving the car, correct? If so, it's just because your car is not fully warmed up.
GSXRiderK6 is offline   Reply With Quote
Old 01-16-2013, 10:09 PM   #3
Imbranu
Imbranu's Avatar
Almost sounds like a rev hang. Not sure if our cars have that with the factory tune or not but that's honestly what it sounds like
AMS FMIC, ETS UICP/Intake, U R licp, Buschur Racing Exhaust, Forge Manual Boost Control, Cobb AP, Perrin 2" shorty antenna,Works Short Shifter, Blox 490 Shift Knob, ETS 02 eliminator dp, AEM AFR Gauge, AEM boost gauge, Rexspeed dual pillar pod , Turbo XS HFC, Spec Stage 2+, APR Splitter,Synapse BOV
Bought but not put on yet: JB FP Red, MAP tubular manifold, Perrin 3 Port
Imbranu is offline   Reply With Quote
Old 01-16-2013, 10:17 PM   #4
KoreanEvo
X-phile
KoreanEvo's Avatar
its called rev hang and nobody seems to know how to fix this issue. people seem to think it has something to do with emissions.
the only solution is to tap your clutch. usually (not every time) this will disengage the fuel.
Steven
AEM intake
AEM UEGO
ebay tp
CNT exhaust
Depot uicp
Tuned by Dr. Phil
supporter of KTM
280whp/290wtq on dyno dynamics
next up: gs 3port/ fmic/ re-tune
KoreanEvo is offline   Reply With Quote
Old 01-16-2013, 10:21 PM   #5
MikeM
MikeM's Avatar
Mine has done the same thing like 3 times since I owned the car
Tomei/ETS/Works/Wedssport/Eibach/Work/Michelin
Rainbow/JL/Fi/Pioneer
I know the pieces fit.
MikeM is offline   Reply With Quote
Old 01-16-2013, 10:25 PM   #6
harris_9
harris_9's Avatar
I experienced this when I test drove the car originally.. But I don't remember it ever happening again after. I wouldn't worry.
harris_9 is offline   Reply With Quote
Old 01-16-2013, 10:42 PM   #7
UT GG EVO X
UT GG EVO X's Avatar
Are you still on the stock clutch and flywheel?
UT GG EVO X is offline   Reply With Quote
Old 01-16-2013, 11:16 PM   #8
tina
Banned
Thanks for all the prompt responses! Yes I'm still on the stock clutch and flywheel, and it was after driving on the freeway for a good 20 minutes so I don't think it was an issue with it being too cold.
I did recently install a catback (no test pipe yet), and the issue seemed to start after that. This is the first time it's happened to me, and it only happened twice on the way home and was remedied by braking so I'm not that worried.
I just wanted to verify that it wasn't something serious like the car running lean and rods about to blow through the head!
A little off topic...but I'm about to order the ETS short ram intake, and I know it "says" that it's safe to use on the stock tune, and I've done research and people seem to confirm this to a certain extent...but is it "truly" safe to use on the stock tune?
Old 01-16-2013, 11:31 PM   #9
bryan08x
X-phile
bryan08x's Avatar
Sounds like normal evo x rev hang to me, mines been doing.it since forever
2004 WRX-----Parted out
2008 GSR----- Rally Red
bryan08x is offline   Reply With Quote
Old 01-17-2013, 02:06 AM   #10
UT GG EVO X
Yes the ets intake is "safe" to run on stock tune because it still utilizes the stock 2.5" MAF unit unlike the ams intake which replaces the unit entirely for a 3" MAF. You'll be fine but I do recommend getting a wideband and boost gauge ASAP if you don't already.
Shudder under deceleration on MR? Help stephze Evo X General 5 12-15-2012 11:52 PM
Rapid deceleration causes serious dive dhatw Evo X General 10 11-04-2012 02:16 PM
stupid spacer question question FL4TLINE Evo X Wheels, Suspension & Brakes 2 04-23-2012 04:20 AM
Class action suit alleges BMW N54 turbo engine unsafe, causes Unintended Deceleration testdummy Automotive News, Articles & Pics 4 10-13-2010 12:19 AM
Noob question and exhaust question! the boat Evo X General 11 05-29-2008 04:08 AM
