Roninz 2008 PB gsr engine rebuild - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Evo X > Evo X Build Journals
Evo X Build Journals Build journals specifically for the Evo X. One thread per build. Be sure to read the sticky.
Old 01-23-2013, 12:47 AM   #1
Roninz
Member
Hey Everyone, This thread is about the story of my engine build. Long story short, i was driving on the highway doing a pull from second gear to third than i heard a big boom.... Scared the shit outta me, drove out the highway and pull over in the garage and then started looking for oil or debris in the engine bay. So far good news no mess but car is running like a boxer engine, i figured spark plug. So i started pulling them one by one until i felt upon this
Then i figured trouble... installed a fresh spark plug and drove like a grandma to my local shop and we did a leak down test on cylinder 4.... 86% leak! So then we started shopping for new parts.
Engine Build
Darton mid sleeves
Cosworth headgasket
Cosworth themal intake gasket
Cosword bearings (main rod thrust)
Cosworth filler cap
Wiseco pistons kit
Manley h beams rod
Arp main and head studs
Tomei poncams
Hks spark plugs
Hks oil filter
Mishimoto magnetic drain plug
Pw Jdm spark plug cover
Fuel
Ams Fuel rail
DeatschWerks DW65c Fuel Pump
Injector dynamics 1000cc
Intake
UR licp
Ams Intake
Exhaust
Ams Widemouth Downpipe
Ark test pipe
Ark dts dual exit exhaust
Other
Ssp underpanel undertray
Aem wideband /pod
Let the build begin!
Engine Out
Spare parts
Transfer case
Transmission
There's your problem!
Turbo
Undressing engine
Naked 4B11T
Here is where my engine gonna sleep for a while
Cover out cams out
And TADA! beautiful broken stock #4 piston
Crankshaft
Head, pistons, crankshaft
Roninz is offline   Reply With Quote
Old 01-23-2013, 01:03 AM   #2
Roninz
Member
New parts coming in
rods, arp studs, fuel pump, cosworth themal and head gasket
ultimate racing licp
Ams intake and Downpipe Thanks to Sean From DSg Performance! and Special thanks to my daughter for opening the boxes!
So far block is sent to be cleaned and waiting for a few more parts
Put up 2 video on youtube first one is when my car got tuned 2 years ago numbers were 325hp and 330 torque at the wheels and second one is my daughter playing with my new Ams Downpipe
http://www.youtube.com/watch?v=SRm03...ature=youtu.be
http://www.youtube.com/watch?v=86dLR...ature=youtu.be
Old 01-23-2013, 01:03 AM   #3
Roninz
Member
Today, i decided to head to the shop and clean up a bit of my parts. Pulled out intercooler and put it in hot tank to clean up all the salt residue and cleaned up my uicp.
New injectors
New Manley Valve springs and titanium retainers
received my tomei cams and new oem valve seals as well but forgot to take pics.
Still waiting on the block being sleeve, and valve spring retainers... hopefully soon ! miss my car ...
Old 01-23-2013, 01:13 AM   #4
chetrickerman
[Music Mod]
[FS Mod]
[E-Tuner]
chetrickerman's Avatar
Ditch those Manley H-beams
< 3000 lb Evo 10 w/ full tank
Interested in Sakura Performance parts? shoot me a pm
RIP mlomker
PM me if you are interested in a E-Tune or Road tune
chetrickerman is offline   Reply With Quote
Old 01-23-2013, 01:28 AM   #5
Roninz
Member
Sleeved block is in!
20130226_185946 by Trinhpete@gmail.com, on Flickr
The work begins!
arp studs
20130304_105951 by Trinhpete@gmail.com, on Flickr
Crank is in
20130304_114957 by Trinhpete@gmail.com, on Flickr
Piston and rods
20130304_123055 by Trinhpete@gmail.com, on Flickr
Head with ferea std valves and manley valve spring and ti retainer
20130304_123258 by Trinhpete@gmail.com, on Flickr
stock piston and wiseco piston
20130226_191946 by Trinhpete@gmail.com, on Flickr
fitment issue with piston and oil squirter, we end up bending it a bit and all was well
20130304_130254 by Trinhpete@gmail.com, on Flickr
starting to look like an engine!
20130304_194431 by Trinhpete@gmail.com, on Flickr
head with tomei cams
20130304_155501 by Trinhpete@gmail.com, on Flickr
ready to have tranny bolt it in
20130305_151648 by Trinhpete@gmail.com, on Flickr
Car out of trailer ready for its transplant
20130305_161846 by Trinhpete@gmail.com, on Flickr
Old 01-23-2013, 01:28 AM   #6
Roninz
Member
Today was a good day! finished up all the piping install exhaust all the fluid car started on the first crank! Car really dirty been sitting inside a trailer for 2 months...
Big thanks to Federal performance ( Amazing Shop in montreal near Dorval, If any other Evo Around ill refer u !) for all the work and most of the parts and Special Thanks to Sean from Dsg for Specific parts that the shop couldnt get ! ur tha man Sean
engine is all prep
20130306_122520 by Trinhpete@gmail.com, on Flickr
underpanel
20130306_163229 by Trinhpete@gmail.com, on Flickr
Exhaust
20130305_203415 by Trinhpete@gmail.com, on Flickr
Old 01-23-2013, 01:31 AM   #7
Roninz
Member
why ? i mean im not gonna push out crazy numbers with the car it is my DD ill probly drop in a new tubular and turbo next year or so but nothing crazy
Old 01-23-2013, 07:15 PM   #8
nismo2evox
[Local Team Member]
nismo2evox's Avatar
The exact same thing happened to me. #4 spark plug went on the exact same cylinder and I lost compression. I think Mitsubishi must have a defect with their stock spark plugs.
Sorry to hear man. The good news is you will have a brand new beast going forward
nismo2evox is offline   Reply With Quote
Old 01-23-2013, 07:40 PM   #9
Roninz
Member
Hehe thanks a lot man!
Old 01-23-2013, 07:42 PM   #10
Funwad
Funwad's Avatar
Sub'd
Mine died last week (timing chain tensioner failed) so I'll be doing the exact same thing for the next few weeks.
Good luck with the build!
EDIT: are you planning on getting the diff pins replaced with the tranny out? Mine has 33k on the clock and god knows what the previous owner did to the car.
Funwad is offline   Reply With Quote
Forced engine rebuild...options? Eastern X Evo X Engine (4B11T) 54 09-05-2012 01:41 AM
Engine rebuild : opinions welcomed! dragon831 Evo X Engine (4B11T) 4 01-01-2012 07:56 PM
How much did YOU pay for engine rebuild? steven88 Evo X Performance 56 11-08-2010 09:32 PM
Evo X Engine Rebuild wilbdog Evo X Engine (4B11T) 46 05-17-2010 11:35 PM
Engine Rebuild Rogue Evo X Engine (4B11T) 55 05-14-2010 05:48 PM
