| Evo X Performance General discussion for performance topics that are unique to the Evo X. IF THE TOPIC IS COMMON WITH OTHER LANCERS, PLEASE POST IT IN: '08+ Lancer Common. |
#1 |
Whats the truth behind in tank fuel pump upgrades?
So I am at the point where I need more fuel on my 12 MR. I remember when I did this before on my 10 GSR it was just as much as a headache to figure out what path I want to go. Last time I had a Walbro 255 with the BLAQOPS kit. Had some issues with the housing return line cracking but I think that was just dumb luck and the guys at BLAQOPS were really helpful in trying to address the issue.
So now there is a DW300 pump on the market that was not around last time I did this that looks great. But I am hearing mixed reviews from reading on here about pumps over heating and going lean yada yada yada. So is this just paranoia or are the DW300 pumps really junk? I do not mind going back to the 255 Walbro (Still have a new one in the box) with a new BLAQOPS kit but if I can get more fuel out of the DW300 with the MAP kit to go with the 1300 injectors I have even better. Thoughts anyone?
I tune, You win. |
| Sponsored Links | |||
Advertisement | |||
#2 |
Oh and I do track the car on the road course 6-10 times a year so pump failure / going lean is a big deal to me and I do not have super high HP plans for the car. 375-400 max E85 and 91 when E85 is not available.
I tune, You win. |
#3 |
[Elite Merchant]
We have been seeing a lot of failures with those pumps when using E85 because of the higher water content than gasoline. I would suggest using the Walbro 485lph E85 pump. It's compatible with gasoline and E85 and flows more than enough for pretty much any setup. That being said, it is a good bit larger than the 255s or the DW300s so you will have some fabrication to do with the basket when you install it.
#4 | |
I tune, You win. |
#5 |
Forum Addict
Talk to MAP, they put my wally 400 in my tank, they can get you any parts needed and Nick there should be able to help with install I am sure or at least point you in the right direction.
MAP T4 TS 6266/ERL 2.2L 10:1 CR/E85 BakaUnchi Tuned
#8 | |
the only problem I find with the WB is the car takes a few seconds to start.
* FQ 330 GSR: 447whp * TRL Block brace * AMS Induction Kit * Turbo Technics Turbo S205B * JE Pistons 86.5mm * Ultimate Racing Turbo Elbow * GrimSpeed 3 PBS * BW I Beams * ARP head studs * ACL Race Bearings * Piper catback * Carbonetic Blade clutch * ARP Head studs * Fidanza Flywheel * Scorpion Decat. * C-TEC Tubular Manifold * Perrin 3.5" IC * Walbro 255 lph FP |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| MAPerformance *NEW* AEM 320LPH In-Tank Fuel Pump's - Get Yours Today For Only $99.98 | Maperformance | Elite Merchant Marketplace | 96 | Yesterday 11:08 PM |
| DeatschWerks 65c Compact In-Tank Fuel Pump | WeSellCarParts | WeSellCarParts.com | 0 | 05-08-2012 01:08 AM |
| TopSpeed Motorsports-Aeromotive 340LPH IN-TANK Pump!! | T|S|M | Merchant Marketplace | 66 | 11-27-2011 04:24 PM |
| Who is running meth? Where are you installing the tank/pump? | Freebs | Evo X Performance | 23 | 11-16-2009 01:21 AM |
| In tank and In line 255lph fuel pump suffice? | Excalibur | Evo X Turbo | 12 | 10-30-2009 08:51 PM |
