steering/suspension questions - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 01-27-2013, 01:05 AM   #1
EvoX8168
Member
EvoX8168's Avatar
I have owned my Evo X for close to 4 years. Believe it or not, it is the most reliable car I have owned. I'd like to improve the following two areas for a DD:
1. Compared with my last two cars (a BMW and a Corvette), Evo X inspires less confidence on winding road. There is an S-shaped off-ramp/on-ramp connecting two freeways in my area. I am not pushing the Evo X to its limit. But the car just feel less controlled. My last two cars felt much more sure footed.
2. Again, compared with my last two cars, the Evo X feels more jittery on a rough street. Ironically, the Evo X feels more floaty on freeway.
Let me know how I can address these two issues. Thanks.
Mods for my '08 Evo X MR:
HKS drop-in, Cobb turbo inlet hose, AMS UICP, boost pill, GST dyno tuned
Car evolution:
Mustang LX -> Firebird Formula -> Corvette LT1 -> BMW 740i Sports -> Evo X MR
EvoX8168 is offline   Reply With Quote
Old 01-27-2013, 07:50 AM   #2
stEVOlution Z
[Local Team Member]
stEVOlution Z's Avatar
tires, proper alignment
stEVOlution Z is offline   Reply With Quote
Old 01-27-2013, 07:51 AM   #3
GSXRiderK6
X-phile
GSXRiderK6's Avatar
What tire pressure are you running?
GSXRiderK6 is online now   Reply With Quote
Old 01-27-2013, 08:29 AM   #4
EvoX8168
Member
EvoX8168's Avatar
I run 33psi all around. In addition to the OE Yokohama ADVAN A13C tires, I have tried Continental DW and Hankook V12 evo tires. I can tell the difference in the steering feel among these tires. But my main issue is the rear of the car does not seem to stay put. All three tires have such problem.
When I make a sharp turn, the rear strikes me that it wants to continue the sway. This makes me think the car is less sure footed. So I stop pushing the car further and slow down. This is what I mean that it does not inspire confidence.
Should I increase the negative chamber of the rear tires? I remember that my BMW had almost zero chamber for the front but very pronounced negative chamber for the rear tires.
Thanks.
Car evolution:
Old 01-27-2013, 03:00 PM   #5
Exyia
Exyia's Avatar
just get alignment numbers and come back and post
ANY handling thread needs to start with tires and alignment spec, otherwise it's just a page full of unnecessary posts
some/most shops should offer you a free alignment check to upsell you on an alignment
Exyia's 2013 Build and Adventures!
Old 2012 Build Thread
Kozmic Motorsports
GTWorx / Race Comp Engineering
Forced Induction Development
Whiteline
Exyia is offline   Reply With Quote
Old 01-27-2013, 11:49 PM   #6
boarderofsnow86
Member
The sears by me has one of those alignment checkers on the floor. It takes them like 5 minutes to do it. I guess it allows them to be able to show you your alignment whenever you bring a car in to them. They did show me my numbers for free though.
boarderofsnow86 is offline   Reply With Quote
Old 01-28-2013, 04:40 AM   #7
EvoX8168
Member
EvoX8168's Avatar
Thanks all for the comments. I should just go get an alignment for my Evo X. My car drives straight and has no uneven tire wears. But I can visually tell that the four wheels have different camber levels.
I have read through the alignment specs thread. I plan to do zero toe for the front and negative toe (0.12) for the rear. But for camber, what should I do?
(A) -1 front and rear
(B) -1.5 front and rear
(C) -1.5 front and -1 rear
(D) -1 front and -1.5 rear
Does 0.5 degree make any difference at all?
Finally, would you take your car to Sears Auto for alignment? I live close to one....
Thanks again!
Car evolution:
Old 01-28-2013, 04:46 PM   #8
Exyia
Exyia's Avatar
Thanks again!
I recommend:
Front Toe: 0.00
Front Camber: 2.00 - 2.50
Rear Toe: 0.00
Rear Camber: 1.50 - 2.00
Caster: won't be adjustable on stock top-hats
Front camber will probably be limited at -2.0 if you're stock
I really dislike using toe in/out on this car. There are so many other ways to adjust stability/balance than dealing with slight toe scrub
The car comes alive at -2.0 (or more) camber up front. I wouldn't go any less, and the tire wear difference is practically nothing (only starts to come into affect at past -2.5)
The rear is practically perfect at -2.0 with a 27mm Swaybar (so you would need even more without one, but I'd advise against that). A lot of owners want to be conservative and go -1.5; I don't agree since the tire wear difference really isn't noticeable. Or if your rear bolts are worn out, I would stop at -1.5 and consider getting Lower Control Arms (Kozmic has the cheapest and most effective ones) to get to -2.0
I would just watch the Sear's people work on the car - see if they have any idea what they're doing or just turning shit till they see green on the computer. I know not everyone is privileged enough to have a performance-oriented alignment shop
Kozmic Motorsports
Whiteline
Old 01-28-2013, 05:51 PM   #9
mac11wildcat
[Local Team Member]
eyxia where did you get yours done? im going to be needing an alignment after my spring install.
TWM|Torque|Works|AMS|HKS|Lou's|Grimspeed|UR|SSP|TiaL|Tomei
mac11wildcat is offline   Reply With Quote
Old 01-28-2013, 06:35 PM   #10
EvoX8168
Member
EvoX8168's Avatar
Thanks Eyxia. My Evo X is a DD and I don't autocross. Do you still recommend the same settings?
Car evolution:
Engineer builds lifelike slot cars with steering and suspension [w/video] testdummy Automotive News, Articles & Pics 0 10-31-2012 04:40 PM
Steering wheel adjustment/broken steering wheel angle sensor nespi13 Evo X General 0 03-19-2012 08:14 AM
questions regarding wheels, suspension and brakes. Dreidrei Evo X Wheels, Suspension & Brakes 0 06-08-2010 08:11 PM
suspension bushings and repalcement arms for X suspension blacksheep Evo X Wheels, Suspension & Brakes 9 05-14-2010 08:38 PM
some suspension parts questions jackfrog Evo X Wheels, Suspension & Brakes 0 02-04-2010 02:51 AM
