| Evo X Turbo Discussion for turbo systems that are unique to the Evo X. IF THE TOPIC IS COMMON WITH OTHER LANCERS, PLEASE POST IT IN: '08+ Lancer Common. |
| Sponsored Links | |||
Advertisement | |||
#32 |
hotstix's 2.2/AMS 750R
I am waiting for the 1300 injectors to come out to retune mine with race gas, and get similar numbers. |
#33 |
[Local Team Member]
Whats the difference between .64 and .82 trim?
2011 EvoX GSR - AMS: SS Brake Lines, LICP w/ TiAL QR BOV, AEM Wideband and Boost Gauge, Tomei Expreme Exhaust, TWM STS w/ Cage Replacement, FIC 1100cc injectors, ETS 4" IC, 3port, Walbro 255lph, AEM FPR, Perrin RSB and Rear endlinks, SSP Underpanel, Enkei PF-01's, Varis Lip, AMS CMC, ACT HD 6 Puck and ACT Streetlite flywheelBuild Thread |
#34 |
I believe it is the turbine housing size .64 is smaller housing size it will spool a bit faster than .82 but will run out of breath top end because it doesn't flow enough air at top. On the other hand .82 is a bigger housing size it won't spool as fast as the .64. It has a decent spool and it would have stronger top end because of the bigger turbine housing. Correct me if I am wrong, still learning here too.
#35 |
[Local Team Member]
I was thinking the same thing. I would like to see a dyno graph of power/spool compairing the two.
#36 | |
#37 |
I was worried about spool with the .64 and I don't really know what the hell I was thinking.
2010 EVO X SE AMS 750r .64 housing open dump AMS Intercooler AMS Transcooler Kelford B cams and springs AMS 2.2 Shortblock Dodson Motorsports Clubman Clutch Kit ID1000 DW265 With STM fuel pump rewire AMS Regulator kit AMS Fuel rail Synapse DV Kozmic Tuned Coltspeed GT Shifter Flossy heavyweight Blox Racing front engine mount Zeitronix wideband boost TopSpeed pro 1 UR mini muffler Kozmic motorsports breather catch can setup STM small battery kit |
#38 |
Hollywood_X did this housing swap and has results. It's in his lighter, faster, more bulletproof thread if you search on here.
2010 WW Evo X GSR w/ SSS BAKA tuned - 422/347 (retune pending), MAP EF3 ported / antisurge, Full-race manifold, ID1000's, DW65C, MAP O2/DP, ARK testpipe, ARK N-II v2 catback, 3" intake, ETS 3.5" FMIC and IC pipes, Grimmspeed 3-port, Tial QR, Swift Spec-R's, Whiteline RCA Kit |
#39 | |
aka CatalystGod
[Racing Moderator] [Local Team Member] |
Re: AMS 750xp vs. Stock frame options?
. Hope you make excellent numbers and tell us all about it. ![]() Sent from my HTC6435LVW using AutoGuide.Com Free App |
#40 |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| AMS 2.4L, CNC Head, and 750XP on 93oct | dnetcrawler | Evo X Dyno | 13 | 10-29-2012 12:44 AM |
| Stock Frame Turbo Heat Shield options? | MAX SEAT TIME | Evo X Turbo | 13 | 09-29-2012 12:05 AM |
| Stock frame same as STI? | exolution | Evo X Turbo | 9 | 08-06-2012 01:37 AM |
| T3 > Stock Frame? (sub 500 awhp) | 1big1 | Evo X Turbo | 5 | 03-15-2012 09:58 PM |
| what fp stock frame turbo did you upgrade to? | BluEvoX88 | Evo X Turbo | 33 | 02-20-2011 01:04 AM |
