help please 2008 lancer gts - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > '08+ Lancer Common > '08+ Lancer Common General
'08+ Lancer Common General Discussion for everything that's common among ALL '08+ Lancers, including Evo, Ralliart, DE, ES, and GTS trims.
Old 05-24-2017, 02:32 PM   #1
tyron2013
n00b
tyron2013's Avatar
hi everyone yesterday i was using my car as usual later on when i was going home got in the car and the car will not start not even crank so i change the battery and still nothing the dash does come on the daylights do turn on the windshiled do come on the windows do come down and up but the door lock wont work the dome light wont work the radio wont work and the ac wont work plus the car wont start please help me.its a standard lancer 08 gts.
tyron2013 is offline   Reply With Quote Quick reply to this message
Old 05-24-2017, 03:19 PM   #2
twylyt
n00b
Check your fuses, both in the engine bay and under you driver side dash. This sounds like you blew one or a few of them.
twylyt is offline   Reply With Quote Quick reply to this message
Old 05-24-2017, 06:15 PM   #3
tyron2013
n00b
tyron2013's Avatar
i alredy did check the fuses and they seem fine.
Old 05-24-2017, 06:34 PM   #4
CanEvo2012
Forum Addict
CanEvo2012's Avatar
When you are just with the key in, but not in ON position, does radio work? As if you are sitting in parking lot waiting to someone and listening to radio?
Are there any clicks when you turn the key and car doesn't crank. There should be a distinct single click when you turn key into Start position and revert it back to ON position.
Mods:
Old 05-24-2017, 06:37 PM   #5
tyron2013
n00b
tyron2013's Avatar
no when i put the key in only the dash comes on when i turn the key to start the car theres like a click under de hood it clicks like 3 time and thats it the car wony start
Old 05-25-2017, 02:55 AM   #6
Jeremyyn
Jeremyyn's Avatar
So the powers there, but it wont start. could it be your starter?
Kaizen Tuned
E85/93
Jeremyyn is offline   Reply With Quote Quick reply to this message
Old 05-25-2017, 03:05 AM   #7
tyron2013
n00b
tyron2013's Avatar
theres no power going to the starter or ignition only thing that works is the dash the windows. everything else has no power.
Old 05-25-2017, 11:26 AM   #8
Isaque
Member
Isaque's Avatar
Is your car manual? Try jump starting it to see if it fires up! If you can jump start it, then most likely it's your starter...
08 Boosted Lancer GTS
RA Turbo
Evo X FMIC
RA Intake manifold/TB
Evo X Fuel Pump
Evo X Injectors
3" SS Turbo Back Exhaust
And More!
Isaque is offline   Reply With Quote Quick reply to this message
Old 05-25-2017, 04:34 PM   #9
twylyt
n00b
Agreed or it might be the starter relay. You can always bypass it. Just put 12v straight to the starter with the car in 'run' and see if it starts. That will tell you a lot.
2008 Lancer GTS 2.0L Turbo Build - 4B11 NA with RA/Evo setup Isaque '08+ Lancer Common General 45 12-14-2017 04:11 PM
My 2008 Lancer GTS CVT XxLaNcErGTSxX '08+ Lancer General 42 04-17-2011 03:27 PM
2008 Lancer GTS LancerGTS '08+ Lancer General 29 02-26-2008 10:37 PM
My 2008 Lancer GTS LancerGTS '08+ Lancer Common General 18 10-03-2007 06:44 AM
