I know this might have been posted but I got a 14 evo with about 13k miles. My rear diff cracked about 5 months ago and my car has been sitting. All I have is the ams intake and access port ots tune. I was thinking of doing the 8/9 conversion. My axles are fine so can I just buy the mounting plate from the factory for the 8/9 and use my axles I have now. Also can anyone link a diy guide. And my last question is fluid I should fill the diff with. If anyone has any other options that may be better feel free to advise me
you cant use your stock rear axles with the 8/9 diff. You will have to get the Driveshaft shop conversion axles, OR buy a 2009+ Ralliart rear diff and axles.
The ralliart rear diff is exactly the same as the 8/9 diff
Do the ralliart diffs have the clutch plates arranged from the factory in the same order as the 8/9 diffs? I know on the 8/9 diffs you can rearrange the clutch plates in order to get more lock up with it and create more power oversteer and improve overall handling.
I had a rear diff fail on me, I bought a used one from ebay, and I am paranoid about diff failure, but if it happens should I look for a ralliart rear diff?
Does the ralliart rear diff maintains the yaw control?
I know this is an old thread but I need to know somethings if possible. Okay so I have the evo 8 rear diff already mounted with the conversion bracket. I was misinformed previously and was told that evo 8 axles will work which they didint. The axles basically just sheared of the splins on themselves because of the axle spline being to small. Now the real question is will oem raliart axles work for my application. Thank you guys in advance.
ok I hate to bring this up but I looked on the how to and there isn't a topic on it. I'm going to purchase a evo 9 rear diff, then order the mounting bracket directly from mitsubishi, changing my adapter from the 9 to the x so it can mount on my driveshaft or use the evo 8 bolts, what else is needed ???
Related Threads
1.9M posts
41K members
Since 2007
