2011 gsr cranks wont start. has fuel no spark!?! HELP PLZ!!! - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 04-24-2013, 08:46 PM   #1
sclou
n00b
so i just installed a freshly rebuilt engine, attempt to do first start up & can crank on it all day but will not start. after hours of diagnosing, figure out getting fuel but no spark. im just about at the end of trying & testing everything short of replacing the ecu. ive tried 2 different crank sensors, both cam sensors, second set of coils & plugs....checked all grounds & timed spot on. additionally verified that all the sensors i just mentioned have voltage, ground continuity & continuity from their connector to the specified pin at ecu connector. all this to no avail still crank crank crank no start. oh also compression test read out in the 130psi+/- range Please any ideas seriously appreciated
sclou is offline   Reply With Quote Quick reply to this message
Old 04-24-2013, 11:01 PM   #2
Kooldino
Dino
[Approved Merchant]
[Local Team Member]
Kooldino's Avatar
https://www.evoxforums.com/forums/sho...t=57136&page=1
But if the timing chain is new, it doesn't make sense.
Kooldino is offline   Reply With Quote Quick reply to this message
Old 04-25-2013, 01:20 AM   #3
fudgie
Go back to basics.....check all fuses and check your engine grounds under load with a test light. Do you just have fuel pressure or have you confirmed that your injectors are actually being pulsed? It's odd to have a firing injector if there is something wrong in the primary ignition circuit. Have you scanned for trouble codes?. Do you have voltage at the coils?
fudgie is offline   Reply With Quote Quick reply to this message
Old 04-25-2013, 01:31 AM   #4
Kooldino
Dino
[Approved Merchant]
[Local Team Member]
Kooldino's Avatar
CEL P0340. Injectors confirmed firing.
Old 04-25-2013, 01:58 AM   #5
EvoX2NR
EvoX2NR's Avatar
The make sure that the plug you put on the AC compressor is the right one. There is another one that it can be confused with that can cause this issue
Slowpoke Tuning
EvoX2NR is offline   Reply With Quote Quick reply to this message
Old 04-25-2013, 02:04 AM   #6
hollywood_X
[E-Tuner]
hollywood_X's Avatar
I've been guilty of that when I put the engine in Joeys car, he found the issue and got it started.
When thats the problem though the car won't crank at all, this one is cranking.
Old 04-25-2013, 02:49 AM   #7
Frogstofall
Frogstofall's Avatar
I remember reading someone's build thread and they had this problem. It turned out he either forgot to hook up a couple grounding straps or had them hooked to the wrong spot. I can't remember but I know it had to do with some grounding straps.
'08 OB GSR SSS
Frogstofall is offline   Reply With Quote Quick reply to this message
Old 04-25-2013, 03:16 AM   #8
Kooldino
Dino
[Approved Merchant]
[Local Team Member]
Kooldino's Avatar
Grounding straps? Just ground wires?
Old 04-25-2013, 03:24 AM   #9
Frogstofall
Yeah I didn't mean to call them straps. There's a series of them that connect to the chassis in various spots according to his thread.
'08 OB GSR SSS
Old 04-25-2013, 07:31 PM   #10
Kooldino
Dino
[Approved Merchant]
[Local Team Member]
Kooldino's Avatar
They all seem to be installed..
Car wont start. vastevo Evo X General 31 05-18-2014 03:51 AM
help! my car wont start. petejay2232 '08+ Lancer Common General 9 12-28-2012 07:08 AM
car cranks but wont turn over....help! 4b11ftw Evo X General 23 10-31-2012 09:59 PM
Car wont start! WWEvo Evo X General 18 04-18-2011 02:34 PM
Evo x wont start...? knifetheglitter Evo X General 10 09-27-2009 04:41 PM
