Evo X Vibration/Noise Driver Side Wheel Wheel - Page 2 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 09-14-2018, 12:34 AM   #11
Kire
n00b
I’ll try to give that a shot and report my findings. Would a bad output bearing or bent input shaft on the transmission cause that type of noise? The reason I stated I suspected it to be suspension related is that the noise completely goes away when I turn left. Similar to a bad wheel bearing when the load is shifted. I’m just hoping I didn’t break any transmission or t case components. The car shifts fine and I don’t feel any issues in the gears.
Originally Posted by CanEvo2012 View Post
Suspension would certainly not cause cyclical sound that is speed dependent. I recommend doing what you did, but put jack stands under control arms to load the suspension.
If you left the wheels hanging, there is a chance that angle would not be the same.
Another point is may be check you wheels mating surface on that side. May be there is some debris and when lugnuts were torques, the wheels is crooked? What about lugnuts - are they tight?
Mods:
ETS Intake|ETS V2 Exhaust|ETS Test Pipe|ETS Upper Intercooler Pipe|Grimmspeed 3 Port Boost Controller|330hp|331wtq||Tuned by UMS Tuning
________________________________________________________________________________ __________________________________
Kire is offline   Reply With Quote Quick reply to this message
Old 09-14-2018, 08:10 PM   #12
CanEvo2012
Forum Addict
CanEvo2012's Avatar
If sounds goes away when you turn, it's unlikely to be a transmission because it's fixed in place. Most likely a bearing or axle. How do you know bearing is ok?
Mods:
Old 09-16-2018, 09:56 PM   #13
Kire
n00b
Do the earlier cotter pin style axles work on later models? I know a guy that’s selling his used set from a 2008 GSR but I’m not sure if they would work on my 2014.
Mods:
Old 09-17-2018, 08:45 PM   #14
CanEvo2012
Forum Addict
CanEvo2012's Avatar
No idea mate. I had no idea that axles were upgraded since 2008 on our cars. Is that what happened? I knew timing chain and relays were updated, but axles???
Mods:
Old 09-18-2018, 02:16 AM   #15
Cyp
Cyp's Avatar
It will work. As long as he supplies the nut that takes a cotter pin
Originally Posted by Demi
" every chip that tears itself off the side is the car shedding weight trying to go faster. Its a feature."
Cyp is offline   Reply With Quote Quick reply to this message
Tags
evo 10, evo x, noise, vibration, wheel
Strange Knocking Noise from Driver's Side Wheel Johnny Rocket Evo X General 9 04-20-2015 05:13 PM
Clunk noise front driver side when braking and turning (slow speed) vivac2 Evo X Wheels, Suspension & Brakes 29 07-01-2013 10:19 PM
2009 Ralliart, rattle, banging vibration noise Saunders1986 '09+ Ralliart General 0 06-14-2013 05:36 AM
Front Driver's Side Vibration FlyEagles15 Evo X General 11 01-15-2013 03:45 AM
steering wheel vibration and low offset wheel and Whiteline RCA + coilover raytrix Evo X Wheels, Suspension & Brakes 26 06-09-2010 07:23 AM
