Unable to read vacuum or boost with AEM 35-8460 - Page 3 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 10-16-2018, 03:50 PM   #21
AiZ
AiZ's Avatar
Originally Posted by evo_of_anu View Post
Lol no, I bought it from someone I knew who got carried away on a few things... both of these replies are awesome. Thank you!!
It was inevitable I suppose.
For what's worth the EBCS - Wastegate routing is correct assuming the vacuum lines are connected to the correct ports on the wastegate. It's an external with dual ports I assume? So then that would be right.
From the picture though it looks like your EBCS has 4 ports, but it really should be three - what's going on with that? Is this vacuum line in yellow connected to anything or just leftover from the stock boost controller installation?
https://i.imgur.com/Te9w5bO.png
Do you think the BOV vacuum line actually originates in the intake manifold?
https://i.imgur.com/bjl2jCX.png
That's stock routing (rubber hose goes to hard line that ends behind the engine, then another rubber hose connects to BOV).
I've been looking all over for the correct vacuum routing for an EFR kit but wasn't able to find anything that was easy to follow.
2011 WW MR -
MHI 18k / ID 1300x / Walbro 450 / WTF Tuned Flex Fuel Kit / Cobb Hard Pipes / Tial QRJ / ETS Intake / ETS Recirc Downpipe / ETS HFC / Invidial Q300 / DrivenFab Recirculated AOS
Chris Carbee Tuned on Tephra v3, making 400 horsepower to all four wheels, because that's the only place power should ever be.
AiZ is offline   Reply With Quote Quick reply to this message
Old 10-16-2018, 06:01 PM   #22
CanEvo2012
Forum Addict
CanEvo2012's Avatar
Folks, the diagram is on the page 70:
http://www.evoxservicemanual.co.uk/P...0006300-17.pdf
Mods:
Old 10-16-2018, 06:07 PM   #23
evo_of_anu
Member
Yes, my Turbosmart wastegate is an external with dual ports. I definitely think it only has 3 ports.
Not sure why it looks that way, I think it's because that vacuum line is tapped into the main turbo line. There is some serious fuckiness that with some patience and observation can be resolved.
evo_of_anu is offline   Reply With Quote Quick reply to this message
Old 10-16-2018, 06:11 PM   #24
evo_of_anu
Member
This is god tier.
Thanks!
Old 10-16-2018, 06:31 PM   #25
CanEvo2012
Forum Addict
CanEvo2012's Avatar
This is god tier.
Thanks!
Check all the diagrams on that website - it's heaven for Evo X owners
Mods:
Old 10-16-2018, 09:26 PM   #26
AiZ
AiZ's Avatar
He does have a 6266 externally wastegated though so I think one of the barbs being Teed into the boost source is correct. But I have no first hand experience so it's the blind leading the blind
2011 WW MR -
Old 10-16-2018, 09:57 PM   #27
CanEvo2012
Forum Addict
CanEvo2012's Avatar
What's the difference, all that matters it is a waste gate, internal or external it needs a source of boost to act on it.
He also has single 3-port instead of stock-like 2 3-ports, so that should be adjusted for as well, but overall, as long as one understands the concept how system works, wiring it should be no issue.
Mods:
Old 10-17-2018, 01:14 AM   #28
turismolover22
turismolover22's Avatar
There are a couple problems I see here.
1, if the "paint" diagram you drew is correct, your BOV as well as your boost gauge are never referenced to boost, ever. So your BOV shouldn't be functioning properly. Your boost gauge wont either, so this would explain it.
2. It appears the other stock boost control solenoid has hoses attached to it. If they go to anything, this is 100% wrong. The stock system uses two solenoids to control the wastegate, and this is more or less its own system. When you upgrade to a 3 or 4 port boost controller, you disconnect the stock boost solenoid from vacuum. The plug is left connected as it allows the car to assume it functions, and thus not throw a code.
The Grimmspeed (and almost every 3 port/4 port controller) are typically sold as "normally open" valves. They way they work, is you have an input, and two outputs.
So input is your boost reference, turbo, manifold etc. Port 2 is typically connected to the wastegate can (if that is the normally open port). Port 3 is VTA (vent to atmosphere) or back to the intake.
When your car is seeking a target boost value, it closes the valve, allowing all boost from port 1 to be blocked like a wall. When it reaches target, its commanded to "open" by being turned off, and once your boost is down to a set level, it pulses the valve back on and off, closing off that wastegate side (which in turn bleeds out the vent port "3"), and bleeding boost off. More or less like you trying to pump a tire up with a fast leak. You push the pump down, the tire airs up, but then the pressure is bled off by the air leak. This back and forth motion is what controls the boost in a 3 port scenario.
Because the 3 port is "normally open" this means in the event of a failure, the path from port 1 (reference) to port 2 (wastegate can) is open, allowing the can to open up at spring pressure. This is a failsafe in effort to reduce a catastrophic overboost condition should the solenoid fail.
Personally I would leave it as is, and figure out how its been tuned before you go about messing with a bunch of stuff. With the stock solenoid appearing to still be a part of the system has me very curious as to how your boost control is actually functioning. With the system plumbed correctly it should not be a mess at all like what you have now. External wastegates, and "two port" internal wastegates have a secondary tuneable port on the other side of the can diaphragm. This allows you to run a lower wastegate spring to increase low boost control, but also allows you to apply pressure to that side of the diaphragm, so it can hold higher boost pressures.
Old 10-17-2018, 12:32 PM   #29
evo_of_anu
Member
It was on the stockish tune when I grabbed the car. I think it was in open-loop mode just so it could be driven.
I am going to just re-route the entire system.
Old 10-17-2018, 02:38 PM   #30
AiZ
AiZ's Avatar
Holy shit stock tune with a 6266?
Ok, at least you already said you're working with Chet, good luck and don't boost that car until things are straightened out
2011 WW MR -
Tags
aem 35-8460, gauge not reading, turbo
Aem gauge vacuum and ecu vacuum PredatorV2 Evo X General 2 09-21-2018 11:02 AM
Unable to read DTCs quicksilver7 ECUFlash / OpenECU 5 08-25-2013 03:09 PM
Unable to reach target boost in lower gears ChipperEvo Cobb AccessPort 4 07-23-2012 01:01 AM
Trouble Shooting Help (AEM analog AFR 35-8460)) ZeroCooll21 Evo X General 3 09-29-2011 11:48 AM
I install AEM tru boost only for read boost but read 10psi what is wrong ? yucel Evo X Turbo 4 09-12-2009 06:03 AM
