Unable to read vacuum or boost with AEM 35-8460 - Page 6 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 10-22-2018, 06:22 PM   #51
evo_of_anu
Member
My gauge is behaving similar to what you are describing. I have been driving it delicately and since I do not need to daily it since I have one, it doesn't get driven much to begin with.
Not trying to further complicate what I hope is a simple issue.
'14 Evo X GSR
PTE 6266
Mazworx Built 2.0 Longblock
Sheptrans Stage 2 Trans
Sheptrans Stage 2 TCase
ID1000 Fuel Injectors
3.5" MAPerformance Air Intake
Walbro 450
Radium Fuel Rail, Pulse Damper, & AFPR
Exedy Twin Disc Clutch
ACT Streetlite Flywheel
Turbosmart Compgate 40(open dump)
Radium PCV Catch Can
Forge Type RS Recirc BOV
ETS 2.5" UICP & LICP
4" ETS Intercooler
MAPerformance T3 Exhaust Manifold
Grimmspeed 3-port EBCS
564HP/409 tq @ 27 PSI - tuned by Mike Adkins(M-Tuned)
evo_of_anu is offline   Reply With Quote Quick reply to this message
Old 10-22-2018, 08:01 PM   #52
AiZ
AiZ's Avatar
Originally Posted by evo_of_anu View Post
I'm in the Cape Coral /Fort Myers area. Yeah I see how that makes sense. And yes. That code was just from sitting at idle after I made the vacuum line changes.
Damn, I'm on the other side of the state. If you were close by I'd come and see if I could give you a hand.
2011 WW MR -
MHI 18k / ID 1300x / Walbro 450 / WTF Tuned Flex Fuel Kit / Cobb Hard Pipes / Tial QRJ / ETS Intake / ETS Recirc Downpipe / ETS HFC / Invidial Q300 / DrivenFab Recirculated AOS
Chris Carbee Tuned on Tephra v3, making 400 horsepower to all four wheels, because that's the only place power should ever be.
AiZ is offline   Reply With Quote Quick reply to this message
Old 10-22-2018, 09:28 PM   #53
evo_of_anu
Member
Damn, indeed. That would be pretty clutch right now. No pun intended.
Old 10-22-2018, 09:33 PM   #54
CanEvo2012
Forum Addict
CanEvo2012's Avatar
Yeah, at idle it usually reads -21in/hg, moderate boost can go as high as 0 PSI( which means it offsets the vacuum of the cylinders with extra boost from the compressor.
But to get into boost you need to give it some gas.
But to test codes, route everything back and see if codes pop up again - may be coincidence? What exactly are the codes though?
Mods:
Old 10-23-2018, 12:31 AM   #55
evo_of_anu
Member
It's a P0300 code. Random/Multiple Cylinder Misfire. I did not have that code before I adjusted the routing. Looking at it now, inspecting my injectors and plugs.
'14 Evo X GSR
PTE 6266
Walbro 450
4" ETS Intercooler
Old 10-23-2018, 09:12 PM   #56
turismolover22
X-phile
turismolover22's Avatar
Just to make sure the gauge even reads correctly, why don't you borrow a hand pressure pump and apply pressure to the gauge sensor nipple?
Old 10-27-2018, 01:02 AM   #57
evo_of_anu
Member
It works! Thank you all for your insight and advice in getting this figured out.
Old 10-27-2018, 01:16 AM   #58
AiZ
AiZ's Avatar
Sweet, so it's building boost and not misfiring anymore?
2011 WW MR -
Old 10-27-2018, 06:47 PM   #59
evo_of_anu
Member
There's still some misfiring but I just picked up some new plugs since I checked out the current ones and they are fucking roasted. Will post an update after tonight's tune up.
Tags
aem 35-8460, gauge not reading, turbo
Aem gauge vacuum and ecu vacuum PredatorV2 Evo X General 2 09-21-2018 11:02 AM
Unable to read DTCs quicksilver7 ECUFlash / OpenECU 5 08-25-2013 03:09 PM
Unable to reach target boost in lower gears ChipperEvo Cobb AccessPort 4 07-23-2012 01:01 AM
Trouble Shooting Help (AEM analog AFR 35-8460)) ZeroCooll21 Evo X General 3 09-29-2011 11:48 AM
I install AEM tru boost only for read boost but read 10psi what is wrong ? yucel Evo X Turbo 4 09-12-2009 06:03 AM
