iPhone GPS lap timer that actually works! - Page 2 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 09-16-2011, 07:38 PM   #11
chkmgnt59
chkmgnt59's Avatar
Originally Posted by Kooldino View Post
Do they make something like this for android?
Yes they do. It's called trackmaster by trackaroo. Also has an optional module which allows you to use external gps (I use qstarz 818xt)
It is awesome, does all the same things as harry's
Current:
997 Turbo - E85 Army Member (700+whp)
Previous:
997 GT3 - Tons of track mods (sold)
08 Evo GSR-724whp / 558wt (sold)
chkmgnt59 is offline   Reply With Quote Quick reply to this message
Old 03-08-2012, 07:43 PM   #12
GoodTimes
GoodTimes's Avatar
Bumping pu this thread, I just got my hands on a i phone 4s yesterday. I'm going to download the appt tonight was wondering if i still needed to get the Emprum GPS attachment for better results? I'm really looking forward to start logging.
Are you guys using lap time Pro or just the Normal lap timer
Matt.
GoodTimes is offline   Reply With Quote Quick reply to this message
Old 03-08-2012, 08:16 PM   #13
pdacton
pdacton's Avatar
Matt.
Yes, you do need the Emprum - the iPhone's internal GPS is only 1 Hz, which is not good enough for proper timing. Emprum is 5 Hz - still a little low, but anything better costs a lot more. I use the Pro version. I also tried the latest version of Harrys Lap Timer with my Kiwi Wifi at VIR last weekend, and got no dropouts at all - looks like the issues with the Kiwi wifi dropping the signal are gone.
pdacton is offline   Reply With Quote Quick reply to this message
Old 03-08-2012, 10:07 PM   #14
GoodTimes
GoodTimes's Avatar
So the 4s is still only 1Hz, What the heck is Kiwi wifi? Is that like a different app to gain data from your ecu?
Old 03-08-2012, 10:32 PM   #15
BlackXero
BlackXero's Avatar
I have the Bad Elf GPS for my flying applications. It was accurate at 36,000ft and ~470+ kts... I bet it would work wonders for a lap timer.
Have you heard of anyone using the Bad Elf for a lap timer?
EDIT: Just looked up the specs... let's just say it will get the job done.
"GPS Technical Specs:
Fast GPS lock times (45 seconds or less)
2.5 meter accuracy
60k feet maximum altitude
1000 MPH maximum speed
Up to 10Hz position update rate
66-channel MTK GPS chipset
SBAS/WAAS/EGNOS/MSAS"
BlackXero is offline   Reply With Quote Quick reply to this message
Old 03-08-2012, 11:29 PM   #16
pdacton
pdacton's Avatar
It's a OBDII reader that transmits the data via wifi to various iPhone and Android apps. Harrys Lap Timer reads it, and stores the data alongside the GPS data.
Old 03-09-2012, 05:42 AM   #17
orthojoe
orthojoe's Avatar
Matt, I've been doing the datalogger 'dance' for the past few months. I ditched my racechrono setup because I have having problems with dropping data, and the data analysis software was horrible. Then I switched to Harry's. You need the emprum GPS unit to get decent accuracy. Internal 1Hz updates at one reading per second. Not ideal. At 5Hz you get 5 points per second (every .2 seconds). If you get the Kiwi unit, don't cheap out like I did because the knockoff brands only pull data at 3Hz, whereas the real kiwi units get 6Hz. With the kiwi unit you can display/log rpm and throttle position, plus HLT can calculate gear position for you.
I ended up returning my HLT gear though. There are a few issues with HLT
1) wireless. update rates are slower and not as reliable
2) HLT will only export one lap of data at a time. If you want to overlay onto gopro video using something like trackvision or race render, you're stuck with one lap.
3) HLT interpolates data to make it look smoother than things really are. The best you are getting is 5hz with emprum, but Harry's interpolates the data to 30hz. Therefore there are 6 points of fake data for every one point of real data. The feature is nice to smooth out video, but he only interpolates if you use his data overlays on the iphone. The exported data is not interpolated.
4) HLT video overlay skips every other lap (next version is supposed to fix this issue)
5) HLT video overlay gauges not so great looking (green/red?)
6) data analysis software is very basic
HLT is great for the money, but I wanted something better. I think you can get accurate lap times with HLT, but the video and datalogging was lacking for me. I ponied up for an AiM Solo DL. I've got 20Hz through the CAN lines, 10Hz GPS, and everything is wired. Solo features a predictive laptimer. The data analysis software is much more useful than HLT. I've been reading this e-book, and it's very interesting stuff:
http://lapfaster.com/Portals/0/ebook...free_ebook.pdf
March 17th will be my trial run of the Solo DL. There are 6 of us running the AiM solo DL that day. Another nice benefit is being able to share data and even run virtual races.
Let's pray it doesn't rain next weekend.... I'm going nuts watching the weather forecast.
Orthojoe
2013 Subaru BRZ limited WRB pearl 6MT
2011 Porsche Boxster Spyder Carrara White/PCCB 6MT
2008 RR Evo X MR - SOLD
orthojoe is offline   Reply With Quote Quick reply to this message
Old 03-09-2012, 01:22 PM   #18
pdacton
pdacton's Avatar
That's funny - I've been reading the exact same e-book. Some really good info in there.
The only thing I disagree with is your point #2. You can export either individual laps, or an entire day's worth of laps (currently just the last day acquired, but the next version will allow selection of the day).
I'll post up some video I took at VIR last weekend using HLT, GoPro, and Dashware software to combine the two - you can see the kind of information it can give you. Hopefully have it done by tonight.
Good luck with the weather - funny how when you have a track day coming up you suddenly become obsessed with the Weather Channel!
Old 03-09-2012, 02:42 PM   #19
orthojoe
orthojoe's Avatar
Are you sure about that? Everytime I try to export an entire track day, you only get the lap times for the day, and not all of the actual data in .csv format. Am I doing something wrong?
Orthojoe
Old 03-09-2012, 02:55 PM   #20
newcomer81
newcomer81's Avatar
fwiw i checked the refresh rate on my galaxy nexus and it was 1hz as well.
BakaUnchi tune in progress
newcomer81 is offline   Reply With Quote Quick reply to this message
TeleNav GPS comes to iPhone 4... for a price testdummy Automotive News, Articles & Pics 0 03-23-2011 01:10 PM
What is the best lap timer in the market? cmsjunior Track 0 09-27-2010 01:09 AM
No gps but you have an iPhone? babybuddha831 Evo X Vanity 20 07-13-2010 06:00 PM
Should've bought a Garmin? Testing the iPhone 3G's GPS capabilities testdummy Automotive News, Articles & Pics 1 07-14-2008 06:19 PM
