Intro GB - SC Fuel Pressure Regulator kit - Page 8 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Merchant Marketplace > Merchant Marketplace
Merchant Marketplace A place for our Approved Merchants to start threads and discuss sales, products, and services.
Old 04-11-2012, 04:33 AM   #71
Kooldino
Dino
[Approved Merchant]
[Local Team Member]
Kooldino's Avatar
We've never had an issue, but we also go a bit overboard with the teflon tape...lay it on thick.
Kooldino is offline   Reply With Quote Quick reply to this message
Old 04-11-2012, 04:43 AM   #72
insane_DOHC
insane_DOHC's Avatar
I think that was my problem. I put the teflon tape on pretty thin.
insane_DOHC is offline   Reply With Quote Quick reply to this message
Old 04-11-2012, 04:47 AM   #73
Capone
X-phile
Capone's Avatar
i wrapped it the first 1 once, 2nd time 2 times and it still leaked.
how many times should i load it on there?
Wicked White EVO X GSR:
HKS GTII 7650R 405hp/352tq @28psi
Understeer is when you hit the wall with the front of the car.
Oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Capone is offline   Reply With Quote Quick reply to this message
Old 04-11-2012, 02:48 PM   #74
Kooldino
Dino
[Approved Merchant]
[Local Team Member]
Kooldino's Avatar
Try four. Hell, just go as thick as you can while still allowing it to fully thread in.
Old 04-12-2012, 03:51 AM   #75
Capone
X-phile
Capone's Avatar
got the leak to stop by using a copper crush washer and i wrapped it 4 times.
i never ever want to do that again.. i hate fuel systems!
Old 04-12-2012, 04:32 AM   #76
Capone
X-phile
Capone's Avatar
Fuck me my day keeps getting better...
My Colt Speed engine cover wont fit now because the 90 degree bend gets in the way.
Old 04-12-2012, 06:04 AM   #77
Kooldino
Dino
[Approved Merchant]
[Local Team Member]
Kooldino's Avatar
How much extra clearance do you need?
If you get a boomba rail, I can send you a 180* fitting that has a much lower profile...
Old 04-12-2012, 08:12 AM   #78
Clipse3GT
[Gearhead]
Clipse3GT's Avatar
Teflon tape will melt away with gasoline.
Use the Yellow Gas tape from Home Depot. Found at the plumbing section. It is rated for Gasoline.
List:
-Clipse3GT Tune -SC Built 2.0 -FP RED -COBB Hardpipes, SFI, Sway Bars -Cosworth MX1 -MDR Inlet -MAP P&P INT. & Full Race EXT.-ETS 4" FMIC -AMS DP, Fuel Rail, MM -T1R Exhaust -MXP TP -FORGE WGA -APS TV BOV -xMR Catch Cans -Walboro 255 -Fuelab FPR -FIC 1100cc -GM 3 Port -Techna-Fit SS Lines -TWM SS/Cage Shifter -WORKS Bushings -Ohlin DFV Coilovers -Whiteline Kit -VEI Gauges -Rally Armor -PERRIN Ant. -Advan RS
Clipse3GT is offline   Reply With Quote Quick reply to this message
Old 04-12-2012, 04:39 PM   #79
Capone
X-phile
Capone's Avatar
Dino, i need about an inch
Clipse ill go get some yellow Teflon tape if it starts to leak again.
Old 05-20-2012, 10:50 PM   #80
91gsx
91gsx's Avatar
Finally got around to installing mine this weekend. Got all of the leaks sealed. I installed the largest (gold I believe) orifice. Currently I just have the oem fuel pump installed & the car idles around 900/1000 rpm.
My issue is base pressure at 45ish psi. Adjusting the fpr does nothing & disconnecting the vac line does absolutely nothing. No matter what, it stays at 45psi.
Anyone have an idea as to what could be causing this other than malfunctioning afpr?
Any help is much appreciated.
91gsx is offline   Reply With Quote Quick reply to this message
Tags
aem, fpr, fuel pressure regulator, speedcircuit
Fuel pressure regulator? m7mad.a Evo X Performance 22 02-04-2017 02:20 AM
Fuel Pressure Regulator stealthevox Evo X Performance 13 02-27-2016 07:25 PM
GI: SC Fuel Pressure Regulator Kit Kooldino Evo X General 29 02-22-2012 12:11 AM
Fuel Pressure Regulator fishstix Evo X Performance 81 10-30-2011 11:43 PM
*AMS Product Release* AMS Mitsubishi Lancer Evolution X Fuel Pressure Regulator Kit AMS Merchant Marketplace 4 03-11-2010 07:21 AM
