Official Abbreviation Glossary Thread - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 12-20-2009, 09:49 PM   #1
boostin20
Drunken Redneck
boostin20's Avatar
For the novice evo enthusiasts on this site, here is a list of abbreviations you could possibly see on these forums. Mods, this isn't cut and paste; I spent several hours on this, and would appreciate it being stickied.
A
ABS= Antilock Braking System
A/F or AFR= Air/Fuel Ratio
A/R= (Area/Radius) describes a geometric characteristic of all compressor and turbine housings
ABSV= Air Bypass Solenoid Valve
ACD= Active Center Differential
ALCL= Assembly Line Communications Link
ALDL= Assembly Line Data Link
AP- AccessPort; tuning solution by Cobb Tuning
APS= Absolute Pressure Sensor or Atmospheric Pressure Sensor
ASC= Active Stability Control
ASDM= Airbag System Diagnostic Module
ATDC= After Top Dead Center
ATF= Automatic Transmission Fluid
ATS= Air Temperature Sensor
AYC= Active Yaw Control
AWD= All Wheel Drive
AWHP= All Wheel Horsepower
B
B+ = Battery Positive Voltage
BARO= Barometric Pressure
BAT= Battery
BHP= Brake Horsepower
BOV= Blow Off Valve
BSFC= Brake Specific Fuel Consumption (fuel flow rate required to generate each Horsepower).
BTDC = Before Top Dead Center
BW= Borg Warner (i.e. BW s256 turbo)
C
CAI= Cold Air Intake
Camber= Positive- top of the wheel is farther out (away from axle) than the bottom; Negative- bottom of the wheel is farther out than the top.
CAN= Controller Area Network
CANP= Canister Purge Solenoid Valve
Caster= angular displacement from the vertical axis of the suspension
CAT= Catalytic Converter
CBE= Cat Back Exhaust
CCV= Closed Crankcase Ventilation
CEL= Check Engine Light
CeO2- Alumina OxideCerum Oxide- CeO2 + Platinum, Paladium, and Rhodium make up catalytic active material in catalytic converters.
CKP= Crankshaft Position Sensor
CMP= Camshaft Position Sensor
CO= Carbon Monoxide
CO2= Carbon Dioxide
COP= Coil On Plug ignition
CTS= Coolant Temperature Sensor
D
DD= Daily Driver
DEFI= Digital Electronic Fuel Injection
DFS= Deceleration Fuel Shutoff
DIS= Direct Ignition System/ Distributorless Ignition System
DLC= Data Link Connector
DOHC= Double Overhead Camshaft
DP= Downpipe (get your head out of the gutter)
DRIVE CYCLE= Specific sequesnce of startup, warmup, and driving tasks that tests all OBD-II functions.
DTC= Diagnostic Trouble Code
DVOM= Digital Volt Ohm Meter
E
E-85= 85% ethanol and 15% gasoline; alternative fuel as defined by the U.S. Department of Energy
EBCM= Electronic Brake Control Module
EBCS- Electronic Boost Control Solenoid
ECT= Engine Coolant Temperature
ECU= Engine Control Unit
EFI= Electronic Fuel Injection
EGO= Exhaust Gas Oxygen Sensor (commonly referred to as o2 sensor)
EGR= Exhaust Gas Recirculation
EGT= Exhaust Gas Temperature; read in Celcius or Fahrenheit
ET**= A way of measure a rim’s offset. ET35 means a rim’s center line is 35mm off of the mounting surface’s (hub’s) centerline.
EVAP= Evaporative Emission System
EWG= External Wastegate
F
FMIC= Front Mount Intercooler
FtLb= Foot Pound
FP= Forced Performance (i.e. FP red)
FPR= Fuel Pressure Regulator
FTL= For The Loss
FTMFL= For The Mother F**kin Loss
FTMFW= For The Mother F**kin Win
FTW= For The Win
FWD= Front-Wheel Drive
FWHP= Flywheel Horsepower (also commonly known as crank horsepower).
G
GND= Ground
GVW= Gross Vehicle Weight
H
H = Hydrocarbon
HEI= High Energy Ignition
HFC= High Flow Catalytic Converter
HO2S= Heated Oxygen Sensor
Hp= Horsepower
HWG= High Wastegate Duty Cycle
I
IAC= Idle Air Control
IAT= Intake Air Temperature
IC= Intercooler
ID= Inside Diameter
IGN= Ignition
IIRC= If I Remember Correctly
IWG= Internal Wastegate
K
KOEO= Key On, Engine Off
KOER= Key On, Engine Running
kPa= Kilopascals
KS= Knock Sensor
boostin20 is offline   Reply With Quote Quick reply to this message
Old 12-20-2009, 09:49 PM   #2
boostin20
Drunken Redneck
boostin20's Avatar
L
LCD= Liquid Crystal Display
LED= Light Emitting Diode
LHD= Left-Hand Drive
LICP= Lower Intercooler Pipe
LTFT= Long Term Fuel Trim- learned value over time which changes gradually in response to conditions such as fuel oxygen content, air leaks, variation in fuel pressure, altitude and so on. This information is used during warm up and wide open throttle conditions.
LWG= Low Wastegate Duty Cycle
M
MAF= Mass Air Flow
MAP= Manifold Absolute Pressure Sensor
MAT= Manifold Air Temperature
MBC- Manual Boost Controller
MC- Master Cylinder
MIL= Malfunction Indicator Light
MIVEC= Mitsubishi Innovative Valve timing Electronic Control System
MPG= Miles Per Gallon
MPH= Miles Per Hour
ms= Millisecond
mV= Millivolts
N
NA= Normally Aspirated; non- forced induction engine
NARROWBAND= o2 sensor constructed partially of zirconium which generates its own voltage at 450mV. 450mV=14.7:1 AFR. Sensor switches below 450mV indicating lean condition, and above 450mV indicating rich condition. That makes the narrowband inferior for AFR monitoring purposes since actual AFR above or below 450mV is only output from sensor as lean/rich, and not an actual AFR (ie, 11.2:1).
Nm= Newton Meters
NOX= Oxides of Nitrogen
O
O2S= Oxygen Sensor
OBD I= Onboard Diagnostics One
OBD II= Onboard Diagnostics Two
OD= Outside Diameter
OE= Original Equipment
OEM= Original Equipment Manufacturer
OHC= Overhead Camshaft
OHV= Overhead Valve
P
P/N= Part Number
PARAMETERS= Readings on scan tools representing functions measured by OBD-II and proprietary readings
PCM= Powertrain Control Module
PCV= Positive Crankcase Ventilation
PID= Parameter ID
PPM= Parts Per Million
PROM= Program Read Only Memory (chip)
PSI= Pounds Per Square Inch
PTB- Partial Throttle Boost
PTC= Pending Trouble Code
PWR= Power to Weight Ratio
R
RAM= Random Access Memory
RECIRC= Blow-off valve is discharged into intake
RHD= Right-Hand Drive
ROM= Read Only Memory
RON= Rated Octane Number
RPM= Revolutions Per Minute
RWD= Rear-Wheel Drive
S
SAWC= Super All Wheel Control
SC= Supercharged
SES= Service Engine Soon (light)
SOHC= Single Over Head Camshaft
SRS= Supplemental Restraint System (air bag)
STFT= Short Term Fuel Trim- instantaneous correction value determined from o2 sensor readings. Under normal conditions, it cycles rapidly around 0% correction value and is only functional during closed loop operation.
SRI= Short Ram Intake
SSQV= Super Sequential Blow off Valve
SSS= Sight, Sound, Spoiler; a package option of the '08+ GSR and MR. Includes HID headlights, 650w Rockford Fosgate stereo system, and taller spoiler.
SST= Sportronic Shift Transmission
STOICHIOMETRIC= correct amount of air and fuel to produce a chemically complete combustion event. (Fuel type dependant; ex: gas-14.7:1, meth- 6.4:1)
T
TACH= Tachometer
TB= Throttle Body
TBE= Turbo Back Exhaust
TC= Turbocharged
TCC= Torque Converter Clutch
TCM= Transmission or Transaxle Control Module
TDC= Top Dead Center
Toe= Positive toe- front of tire pointing towards centerline of car; Negative toe- front of tire pointing away from centerline of vehicle.
TP= Test Pipe
TPMS= Tire Pressure Monitoring System
TPS= Throttle Position Sensor
Tq= Torque
TRIM= relationship between the inducer and exducer of both turbine and compressor wheels; expressed as an area ratio.
U
UEGO= Universal Exhaust Gas Oxygen Sensor
UICP= Upper Intercooler Pipe
V
VIN = Vehicle Identification Number
VSS = Vehicle Speed Sensor
VTA- Vent to Atmosphere
W
WGA- Wastegate Actuator
WCM- Wireless Control Module; located in center console near the shifter
WDC- Wastegate Duty Cycle
WIDEBAND= o2 sensor capable of switching way above or below 14.7:1 (AFR), which is important for ecu to better control AFRs on newer low emission vehicles; also know as an aftermarket kit with wideband o2 and gauge.
WOT= Wide Open Throttle
Old 12-20-2009, 09:54 PM   #3
boostin20
Drunken Redneck
boostin20's Avatar
This is a working progress. If there's anything you think I missed, or need clarification on, let me know.
Old 12-20-2009, 10:56 PM   #4
braddddddd991
braddddddd991's Avatar
AWD
braddddddd991 is offline   Reply With Quote Quick reply to this message
Old 12-20-2009, 10:57 PM   #5
pdacton
pdacton's Avatar
Thumbs up
Very nice - thanks! That's a lot of work.
pdacton is offline   Reply With Quote Quick reply to this message
Old 12-20-2009, 11:02 PM   #6
crimson49er
crimson49er's Avatar
thanks!
crimson49er is offline   Reply With Quote Quick reply to this message
Old 12-20-2009, 11:03 PM   #7
pdacton
pdacton's Avatar
Can someone sticky this?
Old 12-20-2009, 11:08 PM   #8
Rik84
Rik84's Avatar
I wish this was up 6 months ago when I had no idea what was going on! It would have saved a lot of wikipedia time... lol
Boostin, thanks for this, it's great work.
Rik84 is offline   Reply With Quote Quick reply to this message
Old 12-21-2009, 02:42 AM   #9
cartard
wow, thanks!
cartard is offline   Reply With Quote Quick reply to this message
Old 12-21-2009, 09:57 AM   #10
on2it
Dr. Evo?
on2it's Avatar
good work!
Current|HKS UICP|HKS Filter|HKS racing suction pipe kit|Modified Stock Exhaust|EcuTek FQ360 tune|ETS 3.5FMIC|Swift Springs|ACT ME-HDSS|ACT Streetlite Flywheel|
Installing
|FIC 1100cc injectors|K27 Surgetank kit+ Bosch044|
To Come
|BB FPGreen|Kelford Cams|Perrin3port|Perrin Bov|Tomei FPRegulator |Tomei FP guage|
on2it is offline   Reply With Quote Quick reply to this message
Official Spotted Thread Ultimateone Connecticut, Massachusetts, & Rhode Island 237 09-29-2014 12:59 PM
Official Spotted Thread 4832 North & South Carolina 8 03-04-2012 01:35 PM
Official 805 Thread Revolution X Mountain / Pacific US 26 10-28-2009 11:43 PM
Official Animal Thread! MRcaptain Off topic 43 10-17-2009 10:01 PM
Official Evo X Livery Thread FLK Evo X Vanity 28 07-18-2009 03:15 AM
