A/C idle issues. Need my A/C!!! - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 10-30-2019, 08:08 PM   #1
MrCocoTaso
MrCocoTaso's Avatar
Exclamation A/C idle issues. Need my A/C!!!
Hello, newbie here. Iíve been on the forums searching for this issue but canít find it. If there is something out there, my feelings wonít be hurt, please send link. Well here goes....when the air conditioning is off, the car purrs like a kitten, absolutely no issues! Idle is at 1000-1100. However once the a/c is running, when I come to a stop or have the car in neutral she has a very erratic idle and then shuts off. Iíve read not having heat shield for the intake could send hot air, while the a/c is running, in that area and throw the MAF for loops. So I bought a MAP Rev 2 heat shield to aid in this issue. Installed it, took it out for a drive and the EXACT same thing is happening again! Again if there is a link please send.
Thanks
Ď15 GSR E85/MAP 2.2 Big Bore/LA sleeves/CP pistons/Ultimate duty Rods/GTX35R turbo/MAP cylinder head/MAP Billet timing chain tensioner/MAP oil pan/GSC Camshaft/Ferrea valve guides/dual valve springs & retainers/ARP head studs/MAP intake/AMS Downpipe/Tubular Manifold/Top speed Pro 1 exhaust/BPA 4.5Ē FMIC/ETS IC hardpipe/Cobb boost solenoid/Cobb BOV/FIC 2150CC Inj/Walbro 450 FP/AEM fuel pressure regulator/Ported intake manifold/Exedy twin plate/Driven FAB catch can/BC coilovers
MrCocoTaso is offline   Reply With Quote Quick reply to this message
Old 11-03-2019, 07:21 PM   #2
MrCocoTaso
MrCocoTaso's Avatar
Would re-learning idle help or not. Anyone?
Old 11-05-2019, 12:18 AM   #3
Quadrider10
Quadrider10's Avatar
Check for vacuum leaks maybe boost leaks, clean the MAF.
Quadrider10 is offline   Reply With Quote Quick reply to this message
Old 11-05-2019, 09:50 AM   #4
Sabrien4
+1
Sabrien4 is offline   Reply With Quote Quick reply to this message
Old 11-05-2019, 01:12 PM   #5
Stock idle is in the 700-800 range. I'm going to strongly suspect a vacuum leak somewhere past the throttle body. Did you do any work before it started? The car will still run halfway decently with a vacuum line disconnected but will do funky things under light load (like the AC coming on or tip-in light throttle)
Old 11-06-2019, 12:52 AM   #6
MrCocoTaso
MrCocoTaso's Avatar
Thanks. I’ll get on this.
Old 11-07-2019, 05:28 AM   #7
MrCocoTaso
MrCocoTaso's Avatar
Update...Checked the lines and found only these two (or one) not connected. Did a compression check, nothing less than 162 on all 4. Havenít done the throttle body clean yet. Being methodical is ok with me not in a big rush.
ID:	280472   Click image for larger version
Old 11-07-2019, 05:34 AM   #8
MrCocoTaso
MrCocoTaso's Avatar
Oh sorry I did clean the MAF.
Old 11-07-2019, 05:37 AM   #9
MrCocoTaso
MrCocoTaso's Avatar
Same outcome.
Old 11-08-2019, 04:30 PM   #10
Quadrider10
Check the fuel pressure regulator hose to see if it came off. It's under the engine cover on the left.
