Evo X Handling Package Review (ISC, Cobb & Whiteline) - Page 5 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Sponsored by:
Old 04-11-2013, 02:57 PM   #41
r34p3rex
[Local Team Member]
r34p3rex's Avatar
Any reason you didn't go with a matched spring rate F/R or slightly stiffer rear since the X has a multi arm setup with a lower motion ratio in the rear?
E85 ARMY\\\
Instagram:
r34p3rex is offline   Reply With Quote Quick reply to this message
Old 04-11-2013, 05:03 PM   #42
alsong2002
X-phile
any more depth comments?
hows the handling compare to stock
alsong2002 is offline   Reply With Quote Quick reply to this message
Old 04-15-2013, 06:18 PM   #43
alsong2002
X-phile
is the isc twin tube or mono tube designed?
Old 04-15-2013, 06:59 PM   #44
kcandiloro
[Local Team Member]
kcandiloro's Avatar
The rates I listed in the first post are off the ISC application guide spreadsheet so I assume that's what I got since I didn't specify a custom rate. I don't know what engineering processes lead them to those numbers but I assume there was some reasoning behind it. Honestly, I didn't work it through that heavily to determine an alternate rate setup.
I let WraithX drive the car this weekend (brave, I know). Maybe he will chime in with thoughts. He seemed to like it though. I'm kicking myself because I should have ridden in the back while he was driving so I could test out the ride back there.
Handling is superior to stock.
They call them "single cylinder design" so I assume that answers your question.
ಠ_ಠ
2008 MR Phantom Black
"A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster." - Jeremy Clarkson
kcandiloro is offline   Reply With Quote Quick reply to this message
Old 04-29-2013, 12:38 PM   #45
kcandiloro
[Local Team Member]
kcandiloro's Avatar
During the first two weeks on the car, the coils settled quite a bit. I adjusted them this past weekend to give me another 1/2" of ride height and it made a huge difference. Any ride quality issues I was having are totally gone. No creaking from the rear and no harsh bottoming out on modest potholes. The wheel gap is nice and even now and I am again quite happy with the setup.
Before:
After:
ಠ_ಠ
Old 04-29-2013, 01:23 PM   #46
Baller4u2nv
Baller4u2nv's Avatar
on the Before setup(before you raised it) How would you rate the suspension from 1-10? From a comfort standpoint, since you said it handles just like stock.
I ordered these and STILL WAITING from MAP,(almost a month) but i plan on going as low as you did.
Baller4u2nv is offline   Reply With Quote Quick reply to this message
Old 04-29-2013, 01:48 PM   #47
kcandiloro
[Local Team Member]
kcandiloro's Avatar
I would say right before I adjusted them, the comfort level was something like a 6/10. Most of the time it was ok, but they were bottoming out on some really mild bumps. Also it was throwing the geometry off with the swaybars and endlinks so I was getting weird noises from the rear end even after I had tightened everything up.
Right now I'd say they are back up to around an 8/10.
If you want to go as low as possible, I suggest doing something like the following:
Set them up on the initial installation so the ride height is 1/2" higher than you want.
Allow them to settle for 10-14 days with a good amount of driving time.
Readjust them in small increments, up or down as desired. If they start getting too harsh / bottoming out, raise them up a turn (which is like 1/16") until they perform the way you want. This might take a few adjustment cycles, but you'll get them at the best point for comfort and height.
Once they're set up and settled in, it's probably a good idea to get the wheels aligned.
ಠ_ಠ
Old 04-29-2013, 03:50 PM   #48
Deftorn
X-phile
Deftorn's Avatar
Fantastic write-up here. Great pictures of before and after. It looks great man. Amazing what a drop can do. I was showing my co-worker my car and she's like "you want to go even lower than this?" (stock still) ... while she has a mild understanding of cars due to her hubby, it's hard to explain how much better it looks without a huge gap. I should show her this thread
HKS Hi-power catback
ETS Intake // UICP // LICP
ARC mirror finish
Redline E-brake // Armrest // Shiftboot cover
Beatrush rear tow hook
FA 500 coilovers with swift springs
SSP 2p underpanel
Whiteline RSB // RCC kit // Camber/toe arm
Deftorn is offline   Reply With Quote Quick reply to this message
Old 04-29-2013, 06:03 PM   #49
Baller4u2nv
Thanks for the advice
Old 05-02-2013, 03:15 AM   #50
mrtelur
Member
sweet evo x ever
mrtelur is offline   Reply With Quote Quick reply to this message
Tags
cobb, coilover, isc, suspension, whiteline
GSR Handling Package PoorUniversityKid Evo X General 15 06-18-2012 04:48 PM
Review: [email protected] - PW:JDM, Cobb & Tanabe inside Darklol Merchant Feedback 15 05-23-2011 04:22 PM
B&D has ISC COILOVERS!!!! LOWEST PRICES! BOOSTandDESTROY.com Merchant Marketplace 5 05-07-2010 04:59 PM
B&D has SWIFT SPRINGS & WHITELINE SWAY BAR Suspension Package!! BOOSTandDESTROY.com Merchant Marketplace 19 05-03-2010 04:29 PM
Stock Bilstein + Eibach worth it on GSR? (Canadian Handling Package) castamir Evo X Wheels, Suspension & Brakes 14 02-12-2010 01:22 AM
