Mitsubishi Evolution X License Plate LEDs! Plug & Play Install! Same-day shipping! - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Elite Merchants > Diode Dynamics
Old 11-19-2014, 04:16 PM   #1
Diode Dynamics
[Approved Merchant]
Diode Dynamics's Avatar
Lightbulb Mitsubishi Evolution X License Plate LEDs! Plug & Play Install! Same-day shipping!
Mitsubishi Evolution License Plate LEDs
License plate bulbs are used to illuminate the rear license plate on your Evo. From the factory, the bulbs are incandescent, lighting up in a yellowish color.
Newer luxury cars use LED modules to illuminate the license plate with modern, cool white light. By changing your license plate bulbs to LED, you can easily add this luxury look to your Evo X!
The installation is 100% plug-and-play, just replace your factory bulb.
With low price and easy install, this is one of the best, easiest modifications you can do to improve how your Evo looks at night.
Brightness:
Diode Dynamics offers several bulb options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
SMD2: Slightly higher brightness than OEM bulbs. (24 lumens)
HP3: Much brighter than OEM bulbs. These are bright! (56 lumens)
HP5: Nearly triple the brightness of stock OEM bulbs! (92 lumens)
Bulb Design
SMD2: Compact design, with two 5050-size Epistar SMD chips, driven at high power for maximum effective brightness. Outputs at 180 degrees.
HP3: One high-power SMD under a diffusing lens for truly even output (no hotspots). Constant current design and air-cooled base for superior reliability. Features dual contact pins and nonpolar function for easy installation.
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all vehicles.
Included in your order is TWO BULBS (to fit your EvoX).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
2004-2016 Mitsubishi Evolution License Plate LEDs
194 LED Bulb Models
If you have any questions, please don't hesitate to post, PM, or Email [email protected]
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Customer Reviews
"Diode is awesome, so are all of the guys, and gals! That's work there. Easy install, give the back end of the car a nice exotic look. I have used Diode on my Genesis coupe, STI and now my Evo X. And will continue to buy all of there products. (Posted on May 6, 2013)" -LeesEvoX
"Amazing product, easy installment. Did it was a basic screw-driver/plug-n-play style. The quality is great, way better than expected! Second vehicle i've bought lights for and i plan to continue using Diode Dynamics. Thanks! (Posted on February 25, 2013)" -Aaron
Diode Dynamics is offline   Reply With Quote Quick reply to this message
Old 12-02-2014, 04:42 AM   #2
eling99
Can I get the free shipping code? Thanks
Hit me up if you need AMSOIL Products!!!
Advan RGII-Gold
ARC Intercooler
Blox Type R knob
Cobb 3" Turbo Inlet, AP, Tuned 367hp/364t
cp-E Gauge Pod
Depo Racing Wideband Gauge
Defi White Racer Boost Gauge
DW 65c fuel pump
ETS uicp
FIC 1100cc
Full Race Manifold w/Swaintech
Forced Performance Green
Greddy SE Exhaust
Grimmspeed 3 ebcs
Perrin 2" Antenna
Maperformance 3" dp w/Swaintech
T1R Red stich shift boot
TurboXS HFC
Works Rear Sway Bar, Ride Springs
eling99 is offline   Reply With Quote Quick reply to this message
Old 12-02-2014, 03:53 PM   #3
Diode Dynamics
[Approved Merchant]
Please send us a PM for the free-shipping code
Thank you!
Nick C.
Old 02-13-2015, 07:10 PM   #4
orange09ralliart
orange09ralliart's Avatar
Here you go officer, let me help you get a better look at my plate!
Evo X fmic/ Evo X bov/ UR uicp/ UR licp/ K&N drop-in/ UR hfc/ CPE cbe/ Cobb AP/ H&R springs/ 235/40/18 Continental DW/ 18/8" Tenzo Cuzco V1
And stretched tires are for cock hunting. Dont be that guy.
OrangeRA has this color because his RA is so fast it turns to Roto blur when his car goes by.
"The Few, The Proud, The Rotor Glows"
orange09ralliart is offline   Reply With Quote Quick reply to this message
Old 02-13-2015, 07:15 PM   #5
Diode Dynamics
[Approved Merchant]
Or it could go like this:
"Hmm, that Evo has a really visible license plate. As an officer of the law, I appreciate that and surely this person has nothing to hide.
We also have a variety brightness levels to fit your needs
Nick C.
Old 02-13-2015, 08:18 PM   #6
orange09ralliart
Hahahahah, I like it!
Old 02-13-2015, 08:21 PM   #7
Diode Dynamics
[Approved Merchant]
Personally, I recommend the license plate LEDs because of the color change:
Cool white looks 10000x better than the stock incandescent bulbs
Nick C.
Old 10-05-2015, 08:46 PM   #8
Em1sleeper
Member
These look great
2010 EVO X GSR
Em1sleeper is offline   Reply With Quote Quick reply to this message
Old 10-05-2015, 08:58 PM   #9
Diode Dynamics
[Approved Merchant]
Originally Posted by Em1sleeper View Post
These look great
Thanks!
Nick C.
Old 01-22-2016, 10:29 PM   #10
BonafideMonkey22
n00b
BonafideMonkey22's Avatar
Very nice!
BonafideMonkey22 is offline   Reply With Quote Quick reply to this message
License Plates LEDS Black Mamba Evo X Vanity 8 03-11-2013 09:15 PM
FS: Super bright interior LEDs Pure White steven88 Completed Transactions 11 11-18-2011 07:21 PM
Any clean looking bright license plate light? kkmoslehpour Evo X General 2 05-10-2010 05:05 PM
F/S carbon fiber license plate frames and oe f license plate hanger bradze Completed Transactions 10 11-08-2009 11:41 PM
