Evolution X Turn Signal / Tail Light LEDs! Plug & Play! See Bulb Model Options! - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Elite Merchants > Diode Dynamics
Old 10-27-2015, 09:20 PM   #1
Diode Dynamics
[Approved Merchant]
Diode Dynamics's Avatar
Arrow Evolution X Turn Signal / Tail Light LEDs! Plug & Play! See Bulb Model Options!
Mitsubishi Evo X LED Tail Light LEDs
(Evo shown as comparison)
From the factory, tail light bulbs are powered by standard incandescent lights that light up white in color, and cast light through your red or amber tail light lens. This results in a washed-out color.
Newer luxury vehicles are using LEDs for turn signals, because LEDs offer a crisp, instant on/off function, increased brightness, and true, vibrant color. By replacing the bulbs in your Evo X, you can achieve this modern look!
Brightness
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb compared to factory:
HP11: (310 lumens) Slightly higher brightness than OEM bulbs.
XP80: (510 lumens) Much brighter than OEM bulbs. These are bright!
Bulb Design:
HP11: Four side-firing 1.5W-rated Osram LED chips, and one 5W-rated LED chip on top, which is projected by a lens for maximum effective brightness. The bulb is housed in a machined aluminum casing, which provides superior heat diffusion for long life.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
Included in your order is TWO BULBS.
Front Turn Signal LEDs for 2005-2016 Mitsubishi Evolution (pair)
Rear Turn Signal LEDs for 2004-2016 Mitsubishi Evolution (pair)
Tail Light LEDs for 2004-2016 Mitsubishi Evolution (pair)
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
If you have any questions, please don't hesitate to post, PM, email[email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Diode Dynamics is offline   Reply With Quote Quick reply to this message
Old 02-23-2016, 04:39 PM   #2
LeesEvoX
LeesEvoX's Avatar
So do y'all have the flasher module like for the Genesis coupe to avoid the hyper blinking with the LED turn signals? or do we still have to wire in a resistor?
You guys should make a plug and play resistor package for us less electrically inclined folk lol.
2013 PB Evo X GSR- Kozmic Built 2.0l (stock Sleeves) Kelford 214-b cams/Brian Crower titanium springs & retainers/ Wiseco forged pistons/Manley TT forged Rods/ETS Tubular Manifold/ETS Intake W/ Custom 3.5" MAF/ETS 4" IC/ETS UICP/Synapse DV/ID2000's
and a GTX3576R
Tuned by Kozmic @ 500awhp & 365tq (E85)
Blown Ringlands, Its what makes Subaru, a Subaru
LeesEvoX is offline   Reply With Quote Quick reply to this message
Old 02-23-2016, 04:42 PM   #3
Roczkyy
Member
Roczkyy's Avatar
^ I agree
HeartlessCC
Roczkyy is offline   Reply With Quote Quick reply to this message
Old 02-23-2016, 04:44 PM   #4
LeesEvoX
LeesEvoX's Avatar
And y'all know I will buy that shiz lol. I've been buying LEDs from y'all for YEARSSS!!
and a GTX3576R
Old 02-23-2016, 04:48 PM   #5
Diode Dynamics
[Approved Merchant]
The EvoX's flasher relay is integrated into the BCM, unlike the easily replaceable flasher relay units that some vehicles (like the Genesis Coupe) have installed.
Resistors are the only solution to prevent the hyperflash with LED turn signals at the moment.
Nick C.
Old 02-23-2016, 04:52 PM   #6
LeesEvoX
LeesEvoX's Avatar
Nick C.
figured there would be a reason. the Gen coupe was easy, right under the steering wheel lol.
We can still get away with doing LED tail lights though right? As in without the resistor? since we don't have the whole "tail for turn" type.
and a GTX3576R
Old 02-23-2016, 04:58 PM   #7
Roczkyy
Member
Roczkyy's Avatar
Where do you guys recommend mounting the resistor in the rear?
HeartlessCC
Old 02-23-2016, 05:02 PM   #8
Diode Dynamics
[Approved Merchant]
Correct! Tail lights will not require resistors, only the turn signal locations.
The resistors can be mounted anywhere away from rubber or soft plastics. Ideally on a metal surface
Nick C.
Old 02-23-2016, 05:05 PM   #9
LeesEvoX
LeesEvoX's Avatar
Don't forget resistors tend to get hot when in use. so like Nick said. keep it away from rubber, plastics, or carpet.
and a GTX3576R
Old 02-23-2016, 05:22 PM   #10
Roczkyy
Member
Roczkyy's Avatar
That's kinda hard in trunk unless you remove the trunk liner behind the tail lights.
Plus its not like you can just stick it to the body on the inside.
HeartlessCC
Mitsubishi Evolution X License Plate LEDs! Plug & Play Install! Same-day shipping! Diode Dynamics Diode Dynamics 21 11-25-2019 05:41 PM
Mitsubishi Evo X Fog Light LED Bulbs! Several Bulb Options! New SLF Added! USA Made! Diode Dynamics Diode Dynamics 74 10-23-2019 10:16 PM
ID 1000cc Injectors Plug & Play Rohtech Completed Transactions 8 01-05-2014 12:53 AM
FS: ARK MFD2 - OBDII plug & play johnnyfast11 Completed Transactions 1 05-03-2013 10:56 PM
