Hit 33 psi Today. Problem? - Page 3 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 01-23-2014, 11:08 PM   #21
ww13x
Originally Posted by CanEvo2012 View Post
You know, I might be terribly wrong here, but really, I don't use my gauges at all.
When I was etuned through tactrix, I used them somewhat, but again ,everything happens so quick that you can't even glance at them to see what's where.
Now I just look at my CEL flashing when knock is there, but other than that, the gauges are just there...
How do you guys manage to even monitor anything? (Oil temp and pressure probably works, but boost and AFR is just so quickly changing, that it's impossible to register anything in your brain)
*Edit, my bad, actually boost gauge is useful because mine has alarm in case I overboost and that's what I watch out for.
I don't have gauges so I can't answer your question. But even with what you said, having the gauges can't hurt... Boost already helped you and who knows maybe your AFR gauge will save you one day when you happen to take a glance and see AFRs leaner than you'd like them to be? I'm just saying though.. For OPs sake
ww13x is offline   Reply With Quote Quick reply to this message
Old 01-23-2014, 11:28 PM   #22
XRATEDX
X-phile
XRATEDX's Avatar
i have the aem failsafe so 2 in 1. easy to look at. plus my tune is pretty consistent so the gauge doesnt change that much. plus mine are mounted on the dash(i hate it) and it makes it harder but i still manage to look at them fine.
ERL Sleeved block
Wiseco Forged Pistons
Manly turbo tuff I beam rods
AGP kit with 6262
XRATEDX is offline   Reply With Quote Quick reply to this message
Old 01-23-2014, 11:30 PM   #23
CanEvo2012
Forum Addict
CanEvo2012's Avatar
My tune is spot on... 11.1 throughout most of the pull, but when I go WOT I don't look at the gauge - it's a suicide. Unless I am in 5th gear.
Mods:
Old 01-24-2014, 12:43 AM   #24
absentglare
X-phile
Originally Posted by 2011EvoXMR View Post
Call me stupid but I trusted Cobb when they said gauges are nice but werent 100% necessary at the time. Two years later and I dont "need" gauges to tell me Im over boosting. I am cautious and concerned that I dont light up like a space shuttle but there isnt anything I could about anything currently located where I am. No dyno's, no tuners, nothing.
You installed gauges before an exhaust? Please tell me more about your extensive modifications.
Calm down man i'm just giving you a hard time.
Gauges aren't necessary most of the time, hopefully all of the time. Kinda like seatbelts. Doesn't mean i'm about to cruise around without it.
Can't watch them all the time, but it's nice to have it always available for a glance.
absentglare is offline   Reply With Quote Quick reply to this message
Old 01-24-2014, 12:53 AM   #25
EVOL ME
X-phile
EVOL ME's Avatar
Please help me with this one. When you say 11.1 throughout, it doesn't flutter or fluctuate? What gauge if you don't mind me asking and digital or analog?
EVOL ME is offline   Reply With Quote Quick reply to this message
Old 01-24-2014, 01:00 AM   #26
bellacotim
X-phile
bellacotim's Avatar
What's the dig on him not having a boost gauge? Cobb's boost value is exactly what's sent by the MAP sensor of the car. And Cobb logs. As far as I'm concerned, that's better than most boost gauges out there.
bellacotim is offline   Reply With Quote Quick reply to this message
Old 01-24-2014, 02:29 AM   #27
X-se
X-se's Avatar
Would this be an easy fix with a manual boost controller and just turning it down or is it beyond that? Right now I just have a 3 port EBCS, not adjustable.
Is your pro tune locked? If not there're plenty of e-tuners could maybe adjust the WG duty cycle so it doesn't hit so hard with colder temps.
2010 Evo SE Octane Blue
BakaUnchi tuned
X-se is offline   Reply With Quote Quick reply to this message
Old 01-24-2014, 03:05 AM   #28
SDCHAMP619
SDCHAMP619's Avatar
AFR gauge... While driving like a normal DD you notice that your AFR is not 14.7... It's at 16... Bet it stops you from WOT and you log your car to find out why your going lean... Or you go WOT and you glance over and you should be sub 12 but your 12.5... No knock light but again bet you let off and start asking questions... All things that can help to find issues before they become really really bad... Or how about at idle ur at 11.6 and your running a cat...
To me AFR is more important then the boost... Maybe you don't look at it every mile u drive but I bet you glance every once an awhile and will know your car better then u did without it.
<---CLICK HERE
TeamMitsu San Diego
5150-RACING.COM
2012 Phantom Black GSR:
2013 Cosmic Blue MR(Wife's Car/DD)
SDCHAMP619 is offline   Reply With Quote Quick reply to this message
Old 01-24-2014, 03:07 AM   #29
SDCHAMP619
SDCHAMP619's Avatar
So this morning I was on my way to work and got stuck behind 3 cars and bike. No problem, got boost. On a straight and with a clear road ahead I hit the pedal to pass. Felt pretty quick so I glanced at my V3 Accessport and saw that I hit 33 psi of boost at 98% throttle. It was about a 35 mph punch.
Problem is, my tune is supposed to be at 28 psi. Can this damage the turbo or worse, the engine?
Things to note: I was custom tuned by COBB with a 400s kit, FP Green, yada yada yada. My tune was done on a hot day. Cooler weather now = higher boost right? I'll admit I got ahead of myself and did the big upgrades before I learned what I was actually doing and Im still in the learning process. Please be constructive if Im dumb.
33 PSI was BTACK working at COBB when u got tuned?
<---CLICK HERE
TeamMitsu San Diego
5150-RACING.COM
Old 01-24-2014, 03:34 AM   #30
bellacotim
X-phile
bellacotim's Avatar
Post a log. 3rd gear, WOT, 2000 - 7000 RPM. Log Boost, Load, RPM, Fine WGDC, WGDC_Correction, Ign. Timing, Knock, Accelerator %.
Tags
boost, cobb, cobb tuning, fp green, tuned
Hit a big puddle today and had a loud buzzing/vibrating from rear? Freebs Evo X General 4 08-13-2011 02:19 PM
Hit my 700whp goal today! EvoX2NR Evo X Dyno 66 03-15-2011 01:11 AM
Evo X Got Hit & Ran today.. -Gone- Evo X General 26 04-21-2010 11:52 PM
I hit a wall today coming off an off ramp. lehuynh1981 Evo X General 21 12-21-2008 12:01 AM
