HOWTO: Enable Readiness for OBDII inspection after removing your o2 sensor - Page 2 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 03-26-2010, 09:44 PM   #11
weebles
[Local Team Member]
weebles's Avatar
Originally Posted by xPRimNT View Post
I'm so glad I don't have emissions. But even if I did, this would fix it up!
(^ Nice picture, by the way. AltMaps running strong! )
Heh was wondering what that was all about
BMW 135i - 3'' Vrsf catless downpipes - Agency Power resonated midpipes - ETS intercooler - BMS Dual cone intake - BMS charge pipe - BMS Meth kit - JB4 G5 ISO + Opensource backend flash - 437whp 496wtq
weebles is offline   Reply With Quote Quick reply to this message
Old 03-27-2010, 02:28 AM   #12
flagg77
[Local Team Member]
flagg77's Avatar
Sweet!
Works SSK // AMS Under Hood Shifter Bushings // TWM A6 Leopard
Defi Boost Gauge // UEGO WB
Synapse DV // HKS IC Pipes // CP-E HFC // ETS V2 Catback
ECUFlash Tune
flagg77 is offline   Reply With Quote Quick reply to this message
Old 03-28-2010, 09:14 PM   #13
criptballer
if this works for me i might jizz all over the inside of my car.
criptballer is offline   Reply With Quote Quick reply to this message
Old 03-29-2010, 12:29 AM   #14
flagg77
[Local Team Member]
flagg77's Avatar
http://www.ehow.com/video_1330_clean-cars-interior.html
ECUFlash Tune
Old 03-30-2010, 04:24 AM   #15
criptballer
ok so i did it all, however, i don't know if or which bits we are suppose to turn on or off. so which ones do we change?
Old 03-30-2010, 12:06 PM   #16
xPRimNT
[Local Team Member]
xPRimNT's Avatar
I'm not sure, I've never had to do anything emission related.
I imagine that for this, you make the changes for the non-continuous monitoring, and then for the things on the right that have "failed" (Equal 0), you turn them to 1.
That being said, I haven't tried it or anything. Perhaps goofy can chime in.
xPRimNT is offline   Reply With Quote Quick reply to this message
Old 03-30-2010, 12:37 PM   #17
goofygrin
Doesn't live on Mercury
once you make the changes in the three patch "tables" you'll see that the two display tables change to all 0's and 1's (available, readiness respectively).
goofygrin is offline   Reply With Quote Quick reply to this message
Old 03-30-2010, 12:51 PM   #18
Kooldino
Dino
[Approved Merchant]
[Local Team Member]
Kooldino's Avatar
Originally Posted by goofygrin View Post
With this patch, my scanner shows either "Ready" or "N/A" for all the tests. Before this patch Cat and O2HTR showed "Not Ready" so it would not pass inspection.
Doesn't it need to show "ready" to pass inspection?
Kooldino is offline   Reply With Quote Quick reply to this message
Old 03-30-2010, 01:08 PM   #19
xPRimNT
[Local Team Member]
xPRimNT's Avatar
Awesome, thanks goofy. So those other tables are just for "confirming" the changes, you don't have to make them directly to the table.
Yes and no. EGR should show N/A, everything else should be ready, IIRC.
Old 03-30-2010, 02:58 PM   #20
criptballer
thanks goofygrin! i'll make the changes today and hopefully come back with positive results!
SST OBDII Codes & Info saytheb SST 34 06-11-2019 02:23 PM
blitz sbc temp sensor and pressure sensor can slot in zeitronix zt2? superlemonevo Evo X General 1 04-10-2010 04:17 PM
Removing Rear 02 Sensor Completely hotdog Evo X Engine (4B11T) 7 02-24-2010 05:43 PM
Inspection dminor04 Evo X General 8 02-24-2010 04:28 PM
P0135 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) evodicted Evo X Engine (4B11T) 3 03-28-2009 12:11 PM
