Modification plans and ideas / start to finish what to do and in what order - Page 28 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Sponsored by:
Old 01-14-2017, 12:51 PM   #271
rgane5327
Member
looking for some ideas. my current setup is, custom catback, invidia down/test pipe, cobb intake, grimspeed 3 port, upper and lower ic piping, depo 3.5" intercooler, ams fpr, walboro 450, id 1000. what should i do next?? cams, manifold, turbo?? something else??
Growing MOD List:
ETS intake, invidia down/test pipe, Custom turbo back, Grimmspeed 3 port, walboro 450 fuel pump, id1000, depo 3.5" intercooler, ur upper and lower intercooler piping. EF3 variant turbo, map tubular manifold. obx fuel rail. map fuel pressure regulator kit.
rgane5327 is offline   Reply With Quote Quick reply to this message
Old 01-14-2017, 03:23 PM   #272
[email protected]
[Approved Merchant]
reco@speedcircuit's Avatar
What are you power goals? If you're looking for reliable streetability on a daily set-up, an MHI 18K would be a very good choice. We currently have an MHI car in the shop with a little bit more than yourself (cams and flex fuel) which is an AMAZING set-up for the money.
reco@speedcircuit is offline   Reply With Quote Quick reply to this message
Old 03-09-2017, 01:35 AM   #273
MyRariEvo
n00b
I would do turbo next. No need in upgrading your cams if you are still on the stock block..because when the motor goes you are going to want to run some bigger cams regardless. If I were you the next move would be a turbo, that being said ...choose your power goals as [email protected] mentioned and then pick a turbo. Only thing I am going to say is you may have went a little small on the injector side depending on what turbo you decide to go with.
MyRariEvo is offline   Reply With Quote Quick reply to this message
Old 05-16-2017, 08:20 PM   #274
Adrenolin
n00b
My wife gave me her 2013 Ralliart back in December when she found out she was pregnant. She wanted a Juke (idk why lol). It was fun then, but I wanted it to be a little more fun. Lol
So far
EBC Red Stuff Brakes/Slotted Rotor
Fortune Auto 500 Coilovers
Whiteline Rear Sway Bar
Cobb 3-Port Boost Control Solenoid
MHI TF06 18K Turbo -Port/Polished
Go Fast Bits Blow-Off Valve (20% VTA)
Ultimate Racing Turboback Exhaust
3" Long Downpipe
3" Hi-Flow Cat
3" Muffler/Resonator Delete
5" Titanium Tips
Custom 3" Short Ram Intake
Ultimate Racing 4.5" FMIC
Ultimate Racing 2.75" U/LICP
MAP Evo X Cast Exhaust Manifold
Walboro 255 Fuel Pump
ID 1050x Injectors
SSP Stage 2 Street Clutch
Boost, AFR, & Voltage Gauges
FLASH TCU Super-SPORT
Stinger Stealth Radar System
Next plans:
I'll probably be replacing the injectors for ID1300x and adding an additional fuel pump to get flex tuned.
Beehives and GSC S1 Cams
Carbon Fiber Drive Shaft
2.3L Stroker
? x (8.75 2)^2 x 9.6 x 4 = 2309cc
87.5mm bore w/ darton sleeves
96mm crankshaft
Unsure of the rods/pistons at this point, but open to suggestions?
Adrenolin is offline   Reply With Quote Quick reply to this message
Old 06-10-2017, 01:17 PM   #275
Teamdomokun
n00b
Such a great post. Great read
Teamdomokun is offline   Reply With Quote Quick reply to this message
Old 06-21-2017, 03:45 PM   #276
alby on boost
n00b
Awesome thanks for the post
alby on boost is offline   Reply With Quote Quick reply to this message
Old 07-23-2017, 01:32 AM   #277
Rmurray603
n00b
Has been a super informative write up. I plan on PMing you, but need my post count up apparently.
Rmurray603 is offline   Reply With Quote Quick reply to this message
Old 06-07-2018, 04:43 PM   #278
Justin M.
n00b
Justin M. is offline   Reply With Quote Quick reply to this message
Old 12-16-2018, 11:09 PM   #279
TSX101
Member
TSX101's Avatar
Thank you for this. And all your other topics. Incredibly helpful.
TSX101 is offline   Reply With Quote Quick reply to this message
Old 12-20-2018, 06:03 PM   #280
StatusLEDs
Member
StatusLEDs's Avatar
I still think wideband and boost gauge should be the very first modifications to any turbocharged vehicle.
StatusLEDs is offline   Reply With Quote Quick reply to this message
Stock EVO X BPV Modification Clipse3GT Evo X Turbo 34 04-23-2012 02:51 AM
Best finish for Octane Blue paint... davidiii Evo X Wheels, Suspension & Brakes 66 08-10-2009 01:34 AM
Seibon matte finish CF hood installed! xbox4414 Evo X Vanity 34 04-19-2009 03:41 AM
Evo X Modification Poll Meero Evo X Performance 50 09-26-2008 05:58 PM
1st Modification to my evo x Bluevo-x Evo X Performance 18 08-16-2008 12:18 AM
