SmokeSolid's EVO X Engine Build + All BoltOns + Upgraded Engine Internals & Turbo - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Evo X > Evo X Build Journals
Evo X Build Journals Build journals specifically for the Evo X. One thread per build. Be sure to read the sticky.
Old 12-28-2017, 02:05 AM   #1
SmokeSolid
Member
Hi guys,
After 29k miles we opened the engine.
We found it in mint condition so I decided to do a stock build.
No need to sleeve for what I am looking for.
Forged internals for a bit more reliable power basically.
This build is to finish up the engine on my current DD 415whp (V.DynoJet) remotley tuned by Hollywood X some years ago using COBB AC.
MODS
Currently has:
-MAP EF2.0 with TurboSmart External WasteGate 10k miles on it.
-ETS 3.5 Intercooler
-FIC 1100cc
-3Port GrimSpeed
-Walbro 255
-AMS UICP
-AMS LICP
-AMS Big Mouth DownPipe
-AMS Cold Air Intake
-Custom Catless Straight pipe to muffler.
-Legamax HKS Exhaust
-KWv3 Suspension
-Cusco Bars
-JDM CustomHeader
-Toyo Proxes R888
-Wideband: AEM Failsafe
What's New:
-Wiseco Pistons 9.2 : 1
-RalliArt/HKS Connecting Rods: RA/RA111304S1
-Tomei PonCam Type-R Camshafts Intake/Exhaust: 260 - 250 Lift: 10.3 - 9.5
-ARP Rod Bolts
-ARP Head Stud Kit
-ARP Main Bolt Kit
-ACL Rod
-ACL Main
-ACL Thrust
-Oil Pump Oem
-Timing Chain Full Kit
-Oil Chain Full Kit
-Valves: OEM
-Valves Springs Tomei (single)
-Valve Guides OEM
-Valve Titanium Retainer
-Full OEM Gasket Overhaul Kit
-Sheppards Center Diff Pins
-OEM Mitsubishi Engine Gasket Kit fits all the 2008-2015 Evolution X models.
Includes:
(1) (MR258477) Gasket, Oil Return Pipe
(1) (MN143034) Gasket, Throttle Body
(1) (MN187246) Gasket, Water Pump
(1) (MR281085) Gasket, Air Outlet Fitting
(1) (MN187247) Gasket, Cooling Water Outlet Hose Fitting
(1) (1305A458) Gasket, Thermostat Housing
(1) (1515A053) Gasket, Air Inlet Fitting
(1) (1540A066) Gasket, Intake Manifold
(1) (1052A0809) Oil Seal, Front
(1) (1052A824) Oil Seal, Case Assy
(1) (1515A184) Gasket, Turbocharger
(1) (1555A417) Gasket , Exhaust Manifold
(1) (1005A966) Gasket, Cylinder Head
(1) (MF660031) Gasket, Oil and Water Drain 6mm Crush Washer
(2) (MF660064) Gasket, Union Nipple
(4) (MF660065) Gasket, 14mm Crush Washer
(1) (MD030764) O-Ring, Water Pipe
(1) (MD050317) Gasket, Oil Drain Plug
(1) (MD075834) O-Ring, Engine Oil Filler
(16) (MN183952) Seal, Valve Steam
(1) (1226A003) Gasket, Oil Outlet Tube Lower Seal
(1) (1310A344) O-Ring, Oil Return Pipe
(1) (1555A289) Gasket, Turbocharger
(1) (1035A583) Gasket, Cylinder Head Cover
We are looking for a safe DD and a Race Tune.
I hope we can get near 400ish on pump gas on a heartbreaking MUSTANG DYNO.
We will be using TephraXMOD - Evoscan.
Is going to be tuned locally by “BOMBER Tune”
EVO X Full Bolt Ons + Engine Build Thread:
SmokeSolid is offline   Reply With Quote Quick reply to this message
Old 12-28-2017, 02:06 AM   #2
SmokeSolid
Member
Old 12-28-2017, 02:07 AM   #3
SmokeSolid
Member
Old 12-28-2017, 02:11 AM   #4
SmokeSolid
Member
Old 01-09-2018, 07:11 PM   #5
SmokeSolid
Member
Is this forum dead? Lol not even one reply.
Your valuable feedback will be disregarded anyway lol...jk
I been using Benvenuto EVO X clutch for some years now. This last clutch saw very light wear on 5k miles on it pushing 415whp(V.Dyno Jet) .*
We used the same clutch with upgraded pads. Im sure it will perform perfectly.
New Clutch: Done.
Flywheel will remain OEM.
Last chromoly one I used was thorn apart from the center lol.
Old 01-09-2018, 07:13 PM   #6
SmokeSolid
Member
Parts keep arriving.
Includes:
Old 01-09-2018, 10:07 PM   #7
SmokeSolid
Member
We went for Mild Cams.
After all this is aimed to be an aggressive Daily Driven car.
So camshaft choice was to one of the mildest.
Idle will be different but nothing it would bother my family or me.
OEM Intake/Exhaust: 252 - 224 Lift: 9.7 - 8.58
Tomei Intake/Exhaust: 260 - 250 Lift: 10.3 - 9.5
Arriving this month : Tomei Poncams
Sheps Center Differential Pins
I said why not since we are already here?
Seems stronger pins doesn't insure you totally agains catastrophe but at least they should be stronger than my 2008 ones which have hold some launches and hard driving.
Old 01-10-2018, 12:43 PM   #8
D.g318
Member
D.g318's Avatar
No one replied to you but his shit is sick for sure man nice ?
D.g318 is offline   Reply With Quote Quick reply to this message
Old 01-10-2018, 08:46 PM   #9
SmokeSolid
Member
Thanks bro...
Old 01-10-2018, 08:47 PM   #10
turismolover22
turismolover22's Avatar
I love seeing builds come together keep it up dude
What engine boltons jonathanryaaan Evo X Performance 2 10-28-2013 11:24 PM
Turbo set up or build engine koa257 Evo X Turbo 6 11-20-2012 08:53 AM
EF3 turbo with engine internals antanas44 Evo X Turbo 14 10-29-2012 11:31 AM
