Wire tuck codes p0010 and p0013 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 09-27-2018, 03:42 AM   #1
RjR
n00b
Hello all,
After tackling the wire tuck I am getting codes p0010 and p0013 which loooks to be the camshaft position sensor. I freaked out thinking it was because I had extended the rear passenger sensor wire so I put everything back the way it was but I am still getting those codes. Please help, any input is appreciated. My AFRs are all over the place and I have put off driving the car until this gets sorted out. Could it be a blown fuse, if so, which one? Thanks.
RjR is offline   Reply With Quote Quick reply to this message
Old 09-28-2018, 12:57 AM   #2
RjR
n00b
TTT
Old 09-29-2018, 07:02 AM   #3
RjR
n00b
Bump
Old 09-30-2018, 01:07 PM   #4
RjR
n00b
TTT
Old 10-02-2018, 12:17 AM   #5
RjR
n00b
Anybody?
Old 10-02-2018, 06:21 PM   #6
Metal_AF
Member
Per the EvoX Service Manual:
DTC P0010: Intake Engine Oil Control Valve Circuit (Page 13A-56)
TROUBLESHOOTING HINTS (The most likely causes for this code to be set are)
•Intake engine oil control valve failed.
•Open or shorted intake engine oil control valve circuit, or harness damage, or connector damage.
•ECM failed.
DTC P0013: Exhaust Engine Oil Control Valve Circuit (Page 13A-67)
•Exhaust engine oil control valve failed.
•Open or shorted exhaust engine oil control valve circuit, or harness damage, or connector damage.
•ECM failed.
Do you have a copy? It explains the troubleshooting steps in detail.
Also - "Camshaft Position − Timing Over-Retarded" would be DTC P0012.
You have most likely damaged the harness or connector while doing the tuck. It would explain why the code didn't clear once everything was moved back.
Metal_AF is online now   Reply With Quote Quick reply to this message
Old 10-08-2018, 01:44 PM   #7
blaze2682
Member
Did you ever find out what was causing the code to show up? I am getting the same thing.
blaze2682 is offline   Reply With Quote Quick reply to this message
Old 10-09-2018, 02:30 AM   #8
RjR
n00b
Nope. I ordered a new MIVEC Oil Feeder Control Valve hoping I screwed it up by wrongfully rewiring it. Otherwise I might have screwed something electrical.
Old 10-09-2018, 06:46 PM   #9
blaze2682
Member
I got the code after a turbo install and gauges installed. Going to get diagnostics from my tuner Friday will fill you in with what they find hopefully it helps.
Old 04-26-2019, 06:13 PM   #10
smash493
Member
smash493's Avatar
Any info on the p0013 code you were getting? I'm getting the same code.
smash493 is offline   Reply With Quote Quick reply to this message
P0010 Help bhos Evo X Engine (4B11T) 1 10-05-2016 06:53 PM
HOW TO: Easy Wire Tuck Frankiago Evo X Vanity 66 07-21-2016 04:43 AM
Looking for help with Wire Tuck dragon831 Evo X General 24 08-03-2011 02:42 AM
wire tuck how to? rrkpitt15 Evo X General 11 05-10-2011 09:02 PM
"Mag blue" valve cover and a quick wire tuck TitaniumEvo Evo X Vanity 24 11-02-2009 01:06 AM
