Timing chain revision exact date - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 08-13-2017, 04:04 PM   #1
kevin8nine
For a long time in the EVO X forums we were unsure of the exact date of the timing chain revision. We all just knew it was "Sometime in 2011".
The old timing chain part number MN183891 is known to stretch and cause issues in the 2008-2010 model years.
The new timing chain part number 1140A073 was upgraded in 2011 which included a revised chain and few other timing chain system upgrades.
My Evo was built in July/2011 so I did some research to see which chain mine has and came across this Mitsubishi Technical service bulletin.
http://tagore.drivingforceauto.com/s...tsb1213006.pdf
The document states effected vehicles are....
2008−2011 Lancer Evolution built before January 27, 2011
2009−2011 Lancer Ralliart built before January 27, 2011
2009−2011 Lancer Sportback Ralliart built before January 27, 2011
I will be upgrading my cams soon. And I will CONFIRM these findings soon. According to this document I should have the revised chain.
kevin8nine is offline   Reply With Quote Quick reply to this message
Old 08-14-2017, 03:26 AM   #2
Napalm_Enema
Easy to spot I believe they look quite different
Napalm_Enema is offline   Reply With Quote Quick reply to this message
Old 04-14-2018, 12:35 PM   #3
stocker
stocker's Avatar
Good info! Did you confirm that you have the revised chain? Mine is 2011 built in August, so hope mine is done too. Will check soon.
An interesting tidbit is....
"An incorrect parameter in the judgment criteria may cause mis−detection of a fault even though the timing chain elongation rate remains within the specified allowance."
Which means they knew that there was a problem with the timing chains, but did not have to issue a recall because the amount of cars with a problem "were within the specified allowance".
So anyway, onto the good stuff
AMS DP, test pipe, Tomei Ti CBE, UICP
Volk SE37K 18x10.5 +15, Ohlin's coilovers
FIC 1100cc, DW65c, Hotchkis Rr Swaybar & endlinks, Girodisc Fr Rotors, Ferodo & Girodisc Pads, AMS FMIC, Grimmspeed EBC, Zeitronix ECA, Tephra V3, E85, Radium Catch Cans & Surge tank(walbro450)
stocker is offline   Reply With Quote Quick reply to this message
Old 04-17-2018, 09:42 AM   #4
MR. EVO MR
MR. EVO MR's Avatar
My 2010 MR has 176000 with the original timing chain.
Should i be worried?
MR. EVO MR is offline   Reply With Quote Quick reply to this message
Old 11-09-2018, 12:38 AM   #5
kevin8nine
UPDATE:
The document was wrong.
My build date is July 2011, and I had the OLD timing chain. I updated it to the new one for piece of mind.
Maybe someone with a build date later in 2011 can post here, and we can narrow down an EXACT date of timing chain revision.
timing chain help!!! eveten Evo X Engine (4B11T) 2 11-22-2014 05:29 PM
Installing new timing chain ls1car Evo X Engine (4B11T) 15 04-28-2014 02:54 PM
Timing chain quest4566 Evo X Engine (4B11T) 12 03-18-2014 09:12 PM
New Timing chain spikester603 Evo X General 11 03-01-2013 02:57 AM
