Alignment Specs Thread - Page 52 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Sponsored by:
Old 02-22-2017, 01:44 PM   #511
MR. EVO MR
MR. EVO MR's Avatar
I had a bad experiance with LCA's in my EVO 8. I couldnt get them dialed in.
MR. EVO MR is offline   Reply With Quote Quick reply to this message
Old 03-23-2017, 01:01 PM   #512
Faulko
Member
Originally Posted by MR. EVO MR View Post
Can someone that is knowledgeable PLEASE recommend me a setup so i dont eat the inside of my back tires anymore? I just ordered new rear bolt kit too.
But im still looking for my car to handle as aggressive as she can without expensive tire wear :-)
MY DD X MR LOWERED ON KW V3 there's about a finger space between top of tire and fender.
Dunlop ZII's 265/35-18
Bring your rear camber back to 1deg or just over.
Should read like:
Front Camber -1.5>2.0
Rear Camber - 1.0>1.5
Toe Front -0.5 or +0.5
Rear Toe - As per front or zero.
Faulko is offline   Reply With Quote Quick reply to this message
Old 03-23-2017, 03:23 PM   #513
micjester
You can have either or, but not both!
micjester is offline   Reply With Quote Quick reply to this message
Old 03-23-2017, 03:24 PM   #514
micjester
Should read like:
That's a good street car set up. Race specs are basically the same, 0 toe and more camber at all the corners
Old 04-27-2017, 04:30 AM   #515
stocker
Member
stocker's Avatar
2011 Evo X
Coilovers: Ohlins R/T
Spring Rates: Fr/Rr 10k/10k
Wheels: 18x10.5 +15
Tires: Toyo R888r
Alignment:
Camber - Front: -2.7 Rear -1.5
Toe - Front: 1/32 out Rear: 0
Seems to work pretty good for track days.
Will go a little more aggressive on camber in the future.
stocker is offline   Reply With Quote Quick reply to this message
Old 02-18-2018, 07:02 PM   #516
BlueX702
BlueX702's Avatar
2008 Evo X
Coilovers: KW Clubsports
Wheels: 18x11 -5
Tires: BFG Rivals
Alignment:
Camber- Front: -2.9 Rear: -1.8
Toe- Front:0 Rear:0
BlueX702 is offline   Reply With Quote Quick reply to this message
Old 03-11-2018, 01:57 PM   #517
AF13_Evo
Member
AF13_Evo's Avatar
Should I adjust these settings at all? Worried about the big difference between the front right/left Camber.
Eibach Pro Kit/Bilsteins
LF Camber -1.3
RF Camber -2.1
Caster 3.9/4.1
Toe 0.06/0.02
LR Camber -1.7
RR Camber -1.6
Toe 0.16/0.13
2013 Evo MR SSL
AF13_Evo is offline   Reply With Quote Quick reply to this message
Old 03-27-2018, 05:34 PM   #518
roger-alan
Member
Generally true, but I've found the best balance by doing as much negative camber on the front and zero toe all around
roger-alan is offline   Reply With Quote Quick reply to this message
Old 01-14-2019, 11:03 PM   #519
Edwinrt19
Member
Great Alignment Specs To Align My Car Came Out Perfect Didn't Trust Hunter Specs
Edwinrt19 is offline   Reply With Quote Quick reply to this message
Stock Tires - Factory Alignment olsookie Evo X Wheels, Suspension & Brakes 20 07-20-2009 11:03 PM
alignment neng1987 Evo X General 4 04-15-2009 05:41 PM
Alignment questions Dwreck Evo X Wheels, Suspension & Brakes 6 03-25-2009 04:33 PM
SST manufacturer specs: FLK Evo X News 17 12-19-2007 09:16 PM
When do the Offical Specs Come Out Tvall13 Evo X News 5 10-30-2007 11:33 AM
