Openport2 logging - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 02-13-2016, 02:40 PM   #1
Lexa609
n00b
Openport2 logging
Write log to SD card openport2.
use logcfg.txt
How to make so that after the ignition is turned off the log continued to record in the same file ?
Now I switch the log to a new file.
I write through the translator(
Lexa609 is offline   Reply With Quote Quick reply to this message
Old 05-12-2016, 07:46 PM   #2
Lexa609
n00b
Tell me what's the problem ?
Not recorded log on SD card.
if you connect to the computer and then disable the created logcfg.out (in the attachment)
If USB is not connected then the file logcfg.weighs out empty and 0 bytes.
The log file is not written to the card.
Old 05-12-2016, 11:58 PM   #3
razorlab
turn on debug, try to use the logging, then read the debug file
Bryan
2014 Evo GSR - E85 powered - 640whp
2018 Golf Alltrack - E35 powered
razorlab is offline   Reply With Quote Quick reply to this message
Old 05-13-2016, 04:37 AM   #4
Lexa609
n00b
The debug file is in the archive. logcfg.out But it is created only after reconnecting the USB. if you just connect openport in обд2 the file is created but it is empty, the weight 0 buy. on the forum tactrix can't log.
Old 06-01-2016, 09:31 PM   #5
Lexa609
n00b
Understood!
The problem was in the incorrect firmware openport2, the problem was solved by installing the new ecuflash.
Old 04-11-2019, 01:03 PM   #6
tricky1024
n00b
hi guys I have been trying to get logging to work with no guy, I have the most simple logcfg.txt created from the example and checked the EU ROM values against those in EVOScan.
When I connect the OP2 to the CAR I get no lights on it at all, yet I know the ODB2 port works as I have a BT module I also use for Torque. I have also programmed the ECU using the OP2 and USB so I am so confused to what is happening, I don't get an .out file?
Firmware on the OP2 is 1.17.4877
tricky1024 is offline   Reply With Quote Quick reply to this message
Old 04-11-2019, 05:01 PM   #7
chuche831
Member
chuche831's Avatar
If youre not getting lights when connecting to OBD and youre certain your obd is fine then possibly the pins on your OP2 are damaged, assuming the OP2 works when connecting it to the laptop etc.
chuche831 is offline   Reply With Quote Quick reply to this message
Old 04-15-2019, 01:06 PM   #8
tricky1024
n00b
so turns out its a fake OP2.! bloody Chinese, but on a side not i have found the issue with the circuit and fixed it. works now.
i will place a link to the youtube fix once its edited.
Old 04-16-2019, 09:52 AM   #9
tricky1024
n00b
In the event that anyone is actually interested in what we did to fix the clone here is a link: https://youtu.be/N4XJSuh10Xs
Obviously i dont support buying clone devices and would strongly advise only buying a genuine item direct from the supplier https://www.tactrix.com/
HowTo: Logging Wideband AFR via Rear O2 ECU ADC Input (Logging AFR without serial) xPRimNT Evo X Tuning 395 10-11-2018 11:41 PM
HKS filter, Blox shift knob, SRPracing pedal, OpenPort2.0, stocki injectors felixfeng Completed Transactions 10 12-14-2011 03:06 AM
Logging Help Mazzab ECUFlash / OpenECU 1 11-16-2011 04:53 AM
Logging with lc-1 FFRGTM ECUFlash / OpenECU 7 11-06-2010 04:17 AM
How To: Logging Wideband AFR via Rear O2 ECU ADC Input (Logging AFR without serial) TRUSTcompany9000 Evo X How-To 0 09-04-2009 05:58 PM
