For Sale: Full Turbo Kit with ATP Gen 2 GTX 3576 w/custom 4" V-Band Garret Surge-Ported Inlet
Only 1500 miles on this turbo, recently checked by ATP and in perfect condition
Asking $2,750 shipped
- The 4" V-band inlet was welded to the GTX, with custom 4" elbow by AC Fab designed to fit the SST trans of my Evo X SE without using silicon elbow at intake
- Avoids SST contact with elbow and collapsing elbow under vacuum--it's one of a kind as far as I know and provides more intake flow volume than any other stock location ATP GTX 3576 setup
- This kit has everything needed to install with stock manifold and start tuning for up to 500+ WHP on E85
- Extremely quick spool up
- ATP Gen 2 GTX 3576 with Garret 4" Ported Compressor Housing
- Custom V-band inlet and elbow by AC Fab
- Custom black powder-coated UICP that aligns perfectly with Garret compressor outlet
- Moore Automotive 3.5" MAF intake with 1 extra new filter
- Turbosmart WGA
- WTF -10AN turbo oil drain
- SS oil feed line with banjo bolt restricter fittings, banjo bolt heads drilled for safety wire
- WTF UICP Heat Shield
- All silicon couplers and t-bolt clamps needed for install
