BluEvo 2014 EVO X GSR cosmic blue AMS 2.0 CRATE ENGINE - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Evo X > Evo X Build Journals
Evo X Build Journals Build journals specifically for the Evo X. One thread per build. Be sure to read the sticky.
Old 08-20-2019, 03:08 AM   #1
BluEvo
n00b
Purchased the car with 20,000 miles in 2015. All it had done was H&R lowering springs.
Immediately installed:
-K&N intake and UICP
-accessport with OTS map for K&N intake kit
In 2016:
-TBE (AMS DP, Cobb HFC, CNT catback)
-Cobb EBCS
-AEM wideband failsafe
-ACT HDSS
-Dyno Tune on 91 oct (~320whp/375wtq on mustang dyno)
-Stop tech slotted rotors w/ hawk pads and stainless lines
Ran the car like this up to now and absolutely love it.
Now I'm at 65,000 miles and looking for more power and have saved up some paper. So i decided on a stage 1 AMS 2.0 liter crate engine, along with a stock frame turbo, fueling etc.
Parts:
MAP Rev 2 short ram intake
Ported Blouch Dom 3.0xtr
ETS 3.5 inch FMIC w/ piping
ID 1300 w/ PnP adapters
Radium double pump fuel delivery system
Radium Dual Catch Cans
OS Giken TR2C clutch w/pull to push conversion kit
Gauges (innovate oil temp/pressure, zeitronix ethanol content)
Torque Solutions Engine Mounts
UR resonated test pipe
Omni 4 bar MAP sensor
HKS SSQV IV w/ recirc kit
AMS 2.0 4B11T 'stage 1' crate engine:
-Manley Pistons 9310 alloy wrist pin
-Manley “Turbo Tuff” I-Beam
-rod & main bearings
-ARP head studs
-AMS TMP camshafts
It will be tuned for 91 oct and straight E85. No flex fuel or mixing etc.
I'm looking for around 400whp on 91oct and 500whp on e85 (mustang dyno)
The car is currently at the tuners shop, while the engine is at AMS.
I've found build threads really helpful in terms of finding parts/specs/info so i figured I'd share this cars adventure.
I'm going to add to this build journal as things progress. Any questions/comments/criticisms are welcomed.
BluEvo is offline   Reply With Quote Quick reply to this message
Old 08-21-2019, 07:48 AM   #2
BluEvo
n00b
wheels/exterior
-XXR 527 18x9.75/+20mm (i call em cost effective)
-Sumitomo HTR Z II 265/35R18 (they're aight)
-ViS SS carbon trunk
-painted vortex generators cuz evo
-removed the spare/jack and trunk lining - apart from the subwoofer and the little 'tool kit' thing on the right side
- I removed the spare and lining from the trunk and installed the ViS trunk at the same time(with a friend to help line up the trunk right), did some pulls, turns, etc. the car felt noticeably lighter and handled better ...and i think it looks better
Name:	Close evo side shot.jpg
ID:	280188   Click image for larger version
ID:	280190   Click image for larger version
2014 CB Evo X GSR SSS 319whp/374wtq
Old 08-21-2019, 08:26 AM   #3
BluEvo
n00b
interior
-SYGAV 10.2 inch android- stuck the GPS antenna up under the dash towards the windshield, easy install and works pretty well
-wideband AFR/boost in a carbon A pillar mount
ID:	280218   Click image for larger version
ID:	280220   Click image for larger version
ID:	280222   Click image for larger version
Old 08-22-2019, 11:57 PM   #4
turismolover22
X-phile
turismolover22's Avatar
Even if you don't go fully built head, I would still throw some GSC beehives in the head for lower mass and a higher ceiling for RPM in case you forget and bounce it off the limiter.
Old 08-25-2019, 06:52 AM   #5
BluEvo
n00b
Do you think the stock valvetrain would be alright with the rev limit around 7500?
With the stock turbo I would usually shift around 7000 anyway so I was thinkin this Blouch would have similar characteristics given its a stock frame.
Old 08-25-2019, 07:01 AM   #6
BluEvo
n00b
turbo/fmic
some pics of the Blouch turbo and ETS fmic
-anodized 3.5" fmic
-ported blouch dominator 3.0xtr:
DOM 3.0XTR Flows 65-66lbs per min
Inducer Wheel Size: 62.5mm
Exducer Wheel Size: 54.3mm
ball bearing
ID:	280256   Click image for larger version
ID:	280258   Click image for larger version
Old 08-29-2019, 05:03 PM   #7
BluEvo
n00b
HKS SSQV IV / Omni 4 Bar MAP sensor
I got the HKS bov yesterday!
The HKS SSQV kit for the Evo X includes the recirculation kit. It ain't cheap compared to other BOVs but, now that I've had a chance to actually check it out it looks cool, has everything you need to install, and its well made.
ID:	280274   Click image for larger version
Old 10-01-2019, 02:35 AM   #8
BluEvo
n00b
build update
My K&N typhoon intake uses the stock size MAF housing, and since I'm trying to go for relatively more power - I ordered the MAP Rev 2 short ram (3.5" MAF housing) with the wrinkle black finish, and was happy to see that the heat shield received the same finish. It looks cool with the black coating and the big green filter, but I'm more interested in how it will perform/sound.
Old 10-01-2019, 02:47 AM   #9
BluEvo
n00b
I was looking into this and I was mistaken on the original post.
I basically just opted out of the CnC ported head. The engine is getting the TMP cams and appropriate valve/spring components.
Old 10-01-2019, 11:41 PM   #10
turismolover22
X-phile
Good deal.
Yeah, on the stock turbo its about pointless to run it much past 6k, 6500 max. There just isn't any air being moved due to turbo size. It's out of its efficiency range at that point. I shift around 6200 since that usually puts me into the right range in the next gear for max power.
