MAP cast manifold - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 05-23-2019, 05:00 AM   #1
LaughingCow
MAP cast manifold
I found a blemished cast manifold on MAP’s site and wondered if anyone has experience with it. Its a whole lot cheaper and still has the same warranty as the non blemished one.
https://www.maperformance.com/produc...evox-icem-blem
LaughingCow is offline   Reply With Quote Quick reply to this message
Old 05-23-2019, 01:20 PM   #2
This is the first time I've see them selling seconds.....
"For these blemished manifolds, we cut out the section that is blocked by casting defects, port out the area and weld it back together."
So, the main reason most people like the cast manifold is that it's a monolithic piece vs. a collection of pipe welded together, reducing the risk of cracking. I'd imagine there's a slightly higher chance of the manifold having cracks at the welds than the non-blem pieces but the manifold in the pic looks like it has quality welds going for it so it's probably a great option if the price makes it work for your budget.
Old 05-23-2019, 08:54 PM   #3
It's a MAP Cast Manifold, talk to the MAP rep and make sure it falls under the lifetime warranty just as the others would. If it does, send it.
Old 06-07-2019, 01:30 AM   #4
gintense
gintense's Avatar
As long as the refurbishment can't cause FOD to the turbo, it'll be ok with a warranty.
Unless you're pushing it to the limit on non ethanol fuels EGT's shouldn't be an issue anyway.
* Full complement angular contact ceramic ball bearing
* Point milled 3D geometry compressor wheels
* Ultralight mixed flow turbine wheels
* Low rotational inertia design
Evolution 1-3 RS-series (500-650hp)
Evolution 4-9 RS-series (550-725hp)
Evolution X RS-series (575-750hp)
gintense is offline   Reply With Quote Quick reply to this message
Old Yesterday, 04:27 AM   #5
LaughingCow
I finally got the manifold exactly a month after ordering. I inspected the manifold and there didn't seem to be any parts that were cut off and re welded. All I found was the words "BLEM" tig welded on the turbo flange.
ID:	280014   Click image for larger version
Old Yesterday, 02:17 PM   #6
INTIMAZY
Solid purchase then! If the entire runner structure and merge are cast in one piece you should have a solid and reliable manifold. The weight of a turbo exerts quite a bit of stress in those areas.
Octane Blue EvoX (4B11T) GTX3576R GenII
Daytona Blue 350Z (VQ-35DERevup) HKS GTS8555
Imperial Blue Trailblazer SS (LS2)
Royal Jade Pearl SC300 (2JZ-GE+W58 --> 1JZ-GTE+R154+EFR9180)
Redline Red Trackhawk (Hellcat)
INTIMAZY is offline   Reply With Quote Quick reply to this message
Old Yesterday, 11:42 PM   #7
There may have been some other issue. Sometimes the Blemish in the casting is in the runner, but I could see one of the flanges getting a bit lost with the sand cast and need some extra material welded in to shore it back up.
Map kit trade whatever210 For Sale (car parts) 0 05-13-2019 01:57 AM
Cobb OTS Map vs AMS Tune Haan Evo X General 3 05-01-2019 01:48 AM
Exhaust manifold washers Mnavares Evo X General 4 04-10-2019 05:38 PM
Map Downpipe Poko19 Evo X Performance 0 04-01-2019 09:27 PM
(Innovate) 4-Bar Map Sensor mounting locations Cflo23 Evo X Engine (4B11T) 0 02-17-2019 03:36 AM
