Need some advice on what turbo to get - Page 9 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Evo X > Evo X Turbo
Evo X Turbo Discussion for turbo systems that are unique to the Evo X. IF THE TOPIC IS COMMON WITH OTHER LANCERS, PLEASE POST IT IN: '08+ Lancer Common.
Old 09-09-2019, 03:08 PM   #81
MannyEvoX
MannyEvoX's Avatar
Originally Posted by Metal_AF View Post
Ahh ok. So you are only seeing the lag out of a dig then right? Otherwise its pretty much in powerband the whole time through shifts? Between 5000ish-8500?
Oh yeah there's no lag in that rpm. So what I'm really saying is the boost threshold is like 5000rpm not 4200-4500 rpm as other posts led me to believe
2014 Evo X GSR PB
EFR 8374 + Build in progres. . .
ETS Intake
AGP Dual Exhaust
MAP UICP
QTP Test Pipe (w/cut out)
Depo 4' IC
Grimmspeed EBCS
HKS BOV
Comp stage 3 clutch
MannyEvoX is offline   Reply With Quote Quick reply to this message
Old 09-09-2019, 03:39 PM   #82
Kento240
Kento240's Avatar
I wouldn't consider an 8374 laggy. The turbo rips above 4K rpm, 4.2k rpm on some setups. Really depends on fueling and tuning. Going from stock turbo to 8374 will feel a little laggy, but so will pretty much any turbo capable of making 600whp+. Just the nature of the beast.
2011 GG EVO X, SSL, Aero, Sunroof
117K miles
2.2L Stroked and sleeved- Wiseco 10:1- Carrillo Pro H Beam Rods- GSC S2- ID1700- Walbaro 525LPH- Radium -8an Fuel Feed and Filter-Cosworth Rail- Aeromotive FPR- Driven Fab T4 EFR 8474 EWG Turbo Kit- MAP test pipe- HKS Hi Power CBE- OS Giken Twin Clutch- MAP CMC
Previous Cars:
2002 Eclipse GT (still own)
2009 Lancer GTS
2010 Evo X MR
2011 Evo X GSR (current)
Kento240 is offline   Reply With Quote Quick reply to this message
Old 09-09-2019, 03:45 PM   #83
MannyEvoX
MannyEvoX's Avatar
Yes I agree with you, all I was saying is that I don't have any power until like 5000 rpm. There is no way I'd race anyone below that, I make peak tq @ 5500 so that's when I'd really prefer to start. I do understand that it's a 700whp + turbo so I realize what I got myself into but I'm just saying at 4000 rpm I have no real power lol enough to get around town and all tho but it doesn't "rip" until at least 5k
2014 Evo X GSR PB
ETS Intake
AGP Dual Exhaust
MAP UICP
Depo 4' IC
Grimmspeed EBCS
HKS BOV
Comp stage 3 clutch
Old 09-09-2019, 03:52 PM   #84
Dj Eclipse
I got the 8374 kit from driven FAB. I'll let you know about fitment once I get to the turbo install. The manifold was tight but it got in there ok.
I went with Driven Fab as they make a 3.5" down pipe which I am told will help it spool a little quicker. I am expecting full boost by 4500rpm but after reading your post I don't know.
If I don't like it I can always get a 7670 and slap it on there if I am not happy with the 8374.
I hope to have time to work on the car again later this week and get the clutch in there.
Dj Eclipse is offline   Reply With Quote Quick reply to this message
Old 09-09-2019, 03:54 PM   #85
Kento240
Kento240's Avatar
Are you on E85 and do you have cams?
Look at both charts down below. Check out when both setups achieve 300wtq. One is bolt on stock turbo tuned and the other is an 8374 setup. The lower in the rpm band that you can achieve that kind of wtq then the better the car feels as a daily or street car.
https://www.evoxforums.com/forums/at...1&d=1305597761
http://i352.photobucket.com/albums/r...psf093fab6.jpg
117K miles
Previous Cars:
2009 Lancer GTS
2010 Evo X MR
Old 09-09-2019, 03:59 PM   #86
Kento240
Kento240's Avatar
The 7670 was already ruled as a pointless turbo as it spool close to the 8374 but lacked the top end punch. There's a reason why there are a lot of 8374 setup as oppose to the 7670.
117K miles
Previous Cars:
2009 Lancer GTS
2010 Evo X MR
Old 09-09-2019, 04:28 PM   #87
MannyEvoX
MannyEvoX's Avatar
Is that "BlackE's" graph cause I think he just had something special going on lol. I'm on e85 (65% according to my flexfuel sensor) and I have GSC 2 cams and MAP titanium springs and retainers. My engine is fully built, darton sleeved running on twin walboro 450's & ID700x injectors. I will be adding a radium fuel rail and regulator and 4 bar map sensor to turn up the boost to hit 700whp and I'm capping it at that I think.
I'm just being honest with how my car drives, this is my personal experience. Like I said, I've never owned a big turbo car before and I expected a higher boost threshold but I was hopping anywhere from 4200-4500 just as DJ is expecting and from the seat of my pants I haven't felt that so far. We will know once we have a dyno graph tho and like I said I never got the final kill tune, I was on a conservative tune until my parts came in but my motor went between that time
PS: I also haven't driven my car in over 2 months now so I can't even go out for a drive to revisit this topic
2014 Evo X GSR PB
ETS Intake
AGP Dual Exhaust
MAP UICP
Depo 4' IC
Grimmspeed EBCS
HKS BOV
Comp stage 3 clutch
Kept missing 3rd..need some advice. DYKAST Drag Racing 25 03-10-2010 10:31 PM
Need some advice. genes81 Evo X General 11 01-07-2010 04:25 AM
Axle problem.... need some advice. proracer718 Evo X Transmission & S-AWC System 11 08-02-2009 11:21 PM
Drag Racing: Need some advice!! GO ON 3 Drag Racing 39 06-01-2009 01:51 AM
I REALLY really need some help/advice Riz5 Off topic 6 10-15-2008 03:05 AM
