Serpentine Belt Off Center on Tensioner Idler Pulley - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 09-09-2019, 02:12 PM   #1
dalastcwood
n00b
dalastcwood's Avatar
Hey guys, I'm having an issue where my serpentine belt is riding off-center (closer to the wheel) on the tensioner idler pulley. It's pretty bad, as in almost half way off the pulley. When I go under and readjust it to the proper position, it goes right back to the bad position the moment I crank it. I haven't noticed any symptoms/strange sounds as a result of it, but it's driving me crazy, as I feel like the belt can go at any moment. I suspected the pulley itself may have been bad, so I replaced it and it does the exact same thing.
A few months back, the belt broke and I installed a new one. I suspect this misalignment may have been the reason it broke back then. Do you guys think the tensioner itself could be bad and causing the problem? I noticed a little lateral movement (towards the wheel) from the pulley when I relieved the tension. Maybe something else is out of whack? Any advice on how to check proper alignment of other pullies? I've searched and found nothing specific to this, and I'm hoping that maybe someone else has had this issue and can help.
dalastcwood is offline   Reply With Quote Quick reply to this message
Old 09-09-2019, 03:44 PM   #2
Kento240
Kento240's Avatar
Replace the tensioner. BE CAREFUL of the car overheating. Once the belt comes off then the waterpump ceases to work and temps rise very fast. If you have already overheated the motor then I highly suggest pulling the head off and resurface the head and inspect the exhaust valves.
2011 GG EVO X, SSL, Aero, Sunroof
117K miles
2.2L Stroked and sleeved- Wiseco 10:1- Carrillo Pro H Beam Rods- GSC S2- ID1700- Walbaro 525LPH- Radium -8an Fuel Feed and Filter-Cosworth Rail- Aeromotive FPR- Driven Fab T4 EFR 8474 EWG Turbo Kit- MAP test pipe- HKS Hi Power CBE- OS Giken Twin Clutch- MAP CMC
Previous Cars:
2002 Eclipse GT (still own)
2009 Lancer GTS
2010 Evo X MR
2011 Evo X GSR (current)
Kento240 is offline   Reply With Quote Quick reply to this message
Old 09-09-2019, 04:19 PM   #3
W1bowo
n00b
+1
W1bowo is offline   Reply With Quote Quick reply to this message
Old 09-10-2019, 09:16 PM   #4
turismolover22
X-phile
turismolover22's Avatar
The three idler pulleys that mitsu used are all made of plastic, and are known to fail from wear. I would suggest replacing them with the metal Hyundai pulleys and your issue should go away.
The belt could of broken/bent something, but its more likely a bolt got bent if there is an issue of misalignment. Cast aluminum just tends to break.
There are plenty of write ups on the Hyundai pulley mod, I will suggest that you get the Hyundai tensioner pulley bolt as it has a larger shoulder and a longer head to accommodate for the difference in pulley design. There are other little nuances like having to shim the pulley but you'll see that in the write-ups.
