Spring and Coilover Chart - Page 3 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Sponsored by:
Old 12-22-2010, 08:45 AM   #21
greekmark1234
n00b
COIL OVER SPRING RATE CHART FRONT INDEPENDENT SUSPENSION SHOCK 350SR 450SR MOUNTED
LENGTH 10.5" 11.5" COIL-OVER
KIT C351 C351 SPRING (Front Weight) 1350# 7/350 10/350 1475# 7/400 7/400 1550# 7/450 7/450 1600# 7/500 7/475 1750# 7/550 7/500 STRAIGHT AXLE,
4-LINK and CROSSOVER-SPRING
SHOCK 350SR 450SR 550SR MOUNTED LENGTH 10.5" 11.5" 13.3" COIL-OVER KIT C351 C351 C351 SPRING (Front Weight) 1150# 8/250 10/200 12/200 11350# 8/325 10/275 12/275 1550# 8/450 10/375 12/375 1600# 8/475 10/475 12/450 1750# 8/550 10/400 12/400 REAR INDEPENDENT SUSPENSION JAGUAR CORVETTE SHOCK 430SR 530SR 630SR MOUNTED LENGTH 11.5" 13.3" 15" COIL-OVER KIT C351 C351 C351 SPRING (Rear Wt.) 1150# 9/130 11/150 11/150 1350# 9/175 11/175 11/175 1450# 9/200 11/200 11/200 1550# 9/225 11/200 11/175 1600# 9/250 11/250 11/225 1750# 9/275 11/250 11/225 1800# 9/300 11/300 11/300 SOLID AXLE, PRO STREET
and CROSS-OVER SPRING
SHOCK 430SR 530SR 630SR MOUNTED LENGTH 11.5" 13.3" 15" COIL-OVER KIT C351 C351 C351 SPRING (Rear Wt.) 1000# 9/125 11/125 11/100 1150# 9/150 11/150 11/125 1350# 9/175 11/175 11/150 1550# 9/225 11/225 11/200 1600# 9/275 11/275 11/250 1750# 9/300 11/300 11/275
greekmark1234 is offline   Reply With Quote Quick reply to this message
Old 12-22-2010, 11:42 AM   #22
GO ON 3
Banned
Nice job!!
You should add HSD coilovers
GO ON 3 is offline   Reply With Quote Quick reply to this message
Old 12-22-2010, 12:44 PM   #23
Hiboost
Hiboost's Avatar
I'll try and get some more updates here shortly, possibly doing a JPG image of a chart might work out better.
Chris Wirth
Build:
2011 Octane Blue Evo X MR
Best 1/4 Mile ET & Speed: 11.677 @ 119.06
STM Mustang Dyno: 390 whp / 360 wtq
2017 Global Time Attack - Limited AWD Class
2nd - Road Atlanta
2017 CSCS Time Attack - Street AWD Class
1st - Mosport DDT 1:38.391 (Record)
1st - TMP 1:17.644 (Record)
1st - TMP Reverse 1:23.944 (Record)
1st - Shannonville 1:59.748 (Record)
Hiboost is offline   Reply With Quote Quick reply to this message
Old 01-03-2011, 12:27 AM   #24
dave
H&R 8k front 7k rear $1495
2008 Octane Blue GSR - Aero Kit / SSS Package / Navigation
PERRIN Air Filter / Turbo Inlet Hose / Turboback Exhaust / PSRS / Rear Swaybar / Rear Endlinks / Stage 3 "Aggressive" Map / EBCS V2 / Antenna
H&R Coilovers
AGP Front Mount Intercooler / Upper Intercooler Pipe
WORKS Short Shift Kit / Grab Shift Knob
T1R Shift Boot
COBB Accessport w/ AccessTuner Race
dave is offline   Reply With Quote Quick reply to this message
Old 03-09-2011, 10:15 PM   #25
Stark Industries
aka DolEvoX
Stark Industries's Avatar
(asking genuine opinions with facts here gents)
Is it even worth getting springs without the dampeners too? I know eibach, h&r and tein make great stuff and the car might look better with less fender-wheel gap but seriously, is there any performance appeal?
Stark Industries is offline   Reply With Quote Quick reply to this message
Old 05-03-2011, 05:56 AM   #26
X-Factor
X-Factor's Avatar
My SE has the MR Bilsteins, correct? What are my options for suspension STIFFENING but retaining stock ride height?
-2006 EB Evo IX GSR/SSL -
-2010 OBP Evo X SE #297 - 382/387 SOLD
X-Factor is offline   Reply With Quote Quick reply to this message
Old 09-30-2011, 05:36 PM   #27
Ckimjr
n00b
Dont understand....
Ckimjr is offline   Reply With Quote Quick reply to this message
Old 10-01-2011, 03:16 AM   #28
Hiboost
Hiboost's Avatar
Springs alone are mostly for looks, although if not made overly stiff for the amount of drop they can be a slight help in some areas. I found that the Eibach were slightly to big of a drop and for larger bumps and dips they progressive spring rate would overpower the stock shocks. So for smooth roads it was a slight handling upgrade, a wash on moderate roads, and on bumpy roads handling got worse for sure.
Chris Wirth
Build:
2nd - Road Atlanta
Old 10-01-2011, 03:21 AM   #29
Hiboost
Hiboost's Avatar
Yes, the Evo X SE has the MR Bilsteins which are decent shocks. You could get stiffer springs that have a minimal drop, then send the shocks out to Bilstein to get them revalved to match the higher spring rate.
If you want some adjustability you could also go with a moderately priced coilover setup and keep ride height at stock levels or maybe .5" lowered for a better handling stiffer setup. Probably 8k front/8k rear spring rates with appropriately matched valving on the shocks would work well. I'm just assuming that you are looking at street use here.
Chris Wirth
Build:
2nd - Road Atlanta
Old 10-01-2011, 04:27 AM   #30
achinaghost52
achinaghost52's Avatar
there seems to be no difference in the jic ftl tar hard and the jic ftl rs as far as spring rates or adjustability. are the rs lighter? or are the changes more repeatable?
one of the problems i know of with cheap coilovers is that they are not repeatable. as in if it is at full soft, you adjust to full hard, then back to full soft. the full soft points will be two different rates but the same position on the dial. thats the reason real racing coilovers are so expensive is because of the repeatability.
2008 PB GSR 69k Miles VIN: 666
Tune in progress by Chet Rickerman, 335 whp/wtq
K&N Typhoon Kit+ Full Megan Turboback
Thermal Intake Manifold and Throttle Body Spacers
Depo 3.5" Intercooler + Hard Pipes
Magnus CMC + Braided Clutch Line
Competition Clutch Stg 4 + 9lb Fidanza Flywheel
BC BR Coilovers
AMS SS Brake Lines and Hawk HP+ Pads
18x9.5 +25 Rota Torques, Bronze
55w HID's +Custom 6000 lumen LED Light Rack
(30,000 Lumens total)
achinaghost52 is offline   Reply With Quote Quick reply to this message
Tags
konig, rennform
Note to dyno chart posters - Dyno post rules on2it Evo X Dyno 68 08-26-2010 08:05 PM
Coilover SALE____TEIN and KW!!! Works Concepts Merchant Marketplace 49 02-08-2010 09:59 PM
coilover advice jimmi Evo X Wheels, Suspension & Brakes 35 04-24-2009 03:48 PM
any JDM coilover come out yet? stiboy Evo X Wheels, Suspension & Brakes 2 02-27-2008 11:44 PM
GT-R dyno chart! Jackygor Other Automobiles 5 12-15-2007 05:47 PM
