SST OBDII Codes & Info - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Evo X > Evo X Transmission & S-AWC System > SST
SST Post all topics about the SST transmission here.
Old 12-23-2009, 02:01 AM   #1
saytheb
I found this in the workshop manual..
SPECIFIC CODES AND DEFINITIONS
  • P0630: VIN not recorded
  • P0701: EEPROM system (Malfunction)
  • P0702: Internal control module, monitoring processor system (Malfunction)
  • P0711: TC-SST-ECU temperature sensor system (Gradient error)
  • P0712: TC-SST-ECU temperature sensor system (Output low range out)
  • P0713: TC-SST-ECU temperature sensor system (Output high range out)
  • P0715: Input shaft 1 (odd number gear axle) speed sensor system (Output high range out)
  • P0716: Input shaft 1 (odd number gear axle) speed sensor system (Poor performance)
  • P0717: Input shaft 1 (odd number gear axle) speed sensor system (Output low range out)
  • P0725: Engine speed signal abnormality
  • P0746: Line pressure solenoid system (Drive current range out)
  • P0753: Shift select solenoid 1 system (Open circuit)
  • P0758: Shift select solenoid 2 system (Open circuit)
  • P0776: Clutch cooling flow solenoid system (Drive current range out)
  • P0777: Clutch cooling flow solenoid system (Stuck)
  • P0841: Clutch 1 pressure sensor system (Poor performance)
  • P0842: Clutch 1 pressure sensor system (Output low range out)
  • P0843: Clutch 1 pressure sensor system (Output high range out)
  • P0846: Clutch 2 pressure sensor system (Poor performance)
  • P0847: Clutch 2 pressure sensor system (Output low range out)
  • P0848: Clutch 2 pressure sensor system (Output high range out)
  • P0960: Line pressure solenoid system (Open circuit)
  • P0961: Line pressure solenoid system (Overcurrent)
  • P0962: Line pressure solenoid system (Short to ground)
  • P0963: Line pressure solenoid system (Short to power supply)
  • P0964: Clutch cooling flow solenoid system (Open circuit)
  • P0965: Clutch cooling flow solenoid system (Overcurrent)
  • P0966: Clutch cooling flow solenoid system (Short to ground)
  • P0967: Clutch cooling flow solenoid system (Short to power supply)
  • P0968: Shift/cooling switching solenoid system (Open circuit)
  • P0970: Shift/cooling switching solenoid system (Short to ground)
  • P0971: Shift/cooling switching solenoid system (Short to power supply)
  • P0973: Shift select solenoid 1 system (Short to ground)
  • P0974: Shift select solenoid 1 system (Short to power supply)
  • P0976: Shift select solenoid 2 system (Short to ground)
  • P0977: Shift select solenoid 2 system (Short to power supply)
  • P1637: EEPROM system (DTC storing malfunction)
  • P1676: Coding incomplete
  • P1802: Shift lever system (LIN communication malfunction)
  • P1803: Shift lever system (CAN or LIN time-out error)
  • P1804: Shift fork position sensor 1 and 2 system (Power supply voltage low range out)
  • P1805: Shift fork position sensor 1 and 2 system (Power supply voltage high range out)
  • P1806: Shift fork position sensor 3 and 4 system (Power supply voltage low range out)
  • P1807: Shift fork position sensor 3 and 4 system (Power supply voltage high range out)
  • P1808: TC-SST-ECU temperature, fluid temperature sensor system (Correlation error)
  • P180C: Clutch pressure cut spool sticking
  • P181B: Clutch 1 (Pressure low range out)
  • P181C: Clutch 1 (Pressure high range out)
  • P181E: Clutch 2 (Pressure low range out)
  • P181F: Clutch 2 (Pressure high range out)
  • P1820: Shift fork position sensor 1 system (Voltage low range out)
  • P1821: Shift fork position sensor 1 system (Voltage high range out)
  • P1822: Shift fork position sensor 1 system (Output range out)
  • P1823: Shift fork position sensor 1 system (Neutral)
  • P1824: Shift fork position sensor 1 system (Poor performance)
  • P1825: Shift fork position sensor 2 system (Voltage low range out)
  • P1826: Shift fork position sensor 2 system (Voltage high range out)
  • P1827: Shift fork position sensor 2 system (Output range out)
  • P1828: Shift fork position sensor 2 system (Neutral)
  • P1829: Shift fork position sensor 2 system (Poor performance)
  • P182A: Shift fork position sensor 3 system (Voltage low range out)
  • P182B: Shift fork position sensor 3 system (Voltage high range out)
  • P182C: Shift fork position sensor 3 system (Output range out)
  • P182D: Shift fork position sensor 3 system (Neutral)
  • P182E: Shift fork position sensor 3 system (Poor performance)
  • P1831: Shift fork position sensor 4 system (Voltage low range out)
  • P1832: Shift fork position sensor 4 system (Voltage high range out)
  • P1833: Shift fork position sensor 4 system (Output range out)
  • P1834: Shift fork position sensor 4 system (Neutral)
  • P1835: Shift fork position sensor 4 system (Poor performance)
  • P1836: Shift fork 1 malfunction
  • P183D: Shift fork 2 malfunction
  • P1844: Shift fork 3 malfunction
  • P184B: Shift fork 4 malfunction
  • P1852: Shift fork 1 or 2 opposite direction movement
  • P1855: Shift fork 3 or 4 opposite direction movement
  • P1857: Odd number gear axle interlock
  • P1858: Even number gear axle interlock
  • P1859: Disengagement too late with clutch 1
  • P185A: Engagement too late with clutch 1
  • P185B: Disengagement too late with clutch 2
  • P185C: Engagement too late with clutch 2
  • P185D: Clutch open not possible
  • P1862: High side 1 system (Overcurrent)
  • P1863: High side 1 system (Open circuit)
  • P1864: High side 1 system (Short to power supply)
  • P1866: High side 2 system (Overcurrent)
  • P1867: High side 2 system (Open circuit)
  • P1868: High side 2 system (Short to power supply)
  • P186A: High side 3 system (Overcurrent)
  • P186B: High side 3 system (Open circuit)
  • P186C: High side 3 system (Short to power supply)
  • P186D: High side 1 system (Voltage low range out)
  • P186E: High side 2 system (Voltage low range out)
  • P186F: High side 3 system (Voltage low range out)
  • P1870: Engine torque signal abnormality
  • P1871: APS system (Signal abnormality)
  • P1872: Between shift lever and TC-SST system (Q-A function abnormality)
  • P1873: Clutch 1 system (Pressure abnormality)
  • P1874: Clutch 2 system (Pressure abnormality)
  • P1875: Damper speed sensor system (Poor performance)
  • P1876: Gear block 1st
  • P1877: Gear block 2nd
  • P1878: Gear block 3rd
  • P1879: Gear block 4th
  • P187A: Gear block 5th
  • P187B: Gear block 6th
  • P187C: Gear block reverse
  • P1880: EOL Mode Active
  • P1881: Twin clutch SST control mode switch system (Malfunction)
Hope this helps!
Last edited by TheSin; 01-04-2010 at 01:22 AM. Reason: Formated to become Sticky, Thanks for the Great Post!
saytheb is offline   Reply With Quote Quick reply to this message
Old 12-24-2009, 08:28 AM   #2
Ray Knight
Ray Knight's Avatar
**START** edited by kidneythief13 for picture overflow, from first post**
  • P2718: Clutch/shift pressure solenoid 1 system (Open circuit)
  • P2719: Clutch/shift pressure solenoid 1 system (Overcurrent)
  • P2720: Clutch/shift pressure solenoid 1 system (Short to ground)
  • P2721: Clutch/shift pressure solenoid 1 system (Short to power supply)
  • P2727: Clutch/shift pressure solenoid 2 system (Open circuit)
  • P2728: Clutch/shift pressure solenoid 2 system (Overcurrent)
  • P2729: Clutch/shift pressure solenoid 2 system (Short to ground)
  • P2730: Clutch/shift pressure solenoid 2 system (Short to power supply)
  • P2733: Clutch/shift switching solenoid 1, spool stuck
  • P2736: Clutch/shift switching solenoid 1 system (Open circuit)
  • P2738: Clutch/shift switching solenoid 1 system (Short to ground)
  • P2739: Clutch/shift switching solenoid 1 system (Short to power supply)
  • P2741: Fluid temperature sensor system (Gradient error)
  • P2742: Fluid temperature sensor system (Output low range out)
  • P2743: Fluid temperature sensor system (Output high range out)
  • P2766: Input shaft 2 (even number gear axle) speed sensor system (Poor performance)
  • P2809: Clutch/shift switching solenoid 2, spool stuck
  • P2812: Clutch/shift switching solenoid 2 system (Open circuit)
  • P2814: Clutch/shift switching solenoid 2 system (Short to ground)
  • P2815: Clutch/shift switching solenoid 2 system (Short to power supply)
  • U0001: Bus off
  • U0100: Engine time-out error
  • U0103: Shift lever time-out error
  • U0121: ASC time-out error
  • U0136: AWC time-out error
  • U0141: ETACS time-out error
FAIL-SAFE REFERENCE TABLE
Clutch open prohibits the vehicle from driving, and displays an occurrence of trouble to the multi information display to warn the driver.
P0702, P1803, P1804, P1805, P1806, P1807, P1857, P1858, P185D, P1866, P1868, P1872
Continues driving with the current gear fixed, and an occurrence of trouble is displayed to the multi information display to warn the driver.
P0776, P0777, P0964, P0965, P0966, P0968, P0970, P0971, P1852, P2733, P2736, P2738, P2739
Drives with the odd number gear axle (1st, 3rd, 5th gear) or with the even gear axle (2nd, 4th, 6th gear), and an occurrence of trouble is displayed to the multi information display to warn the driver.
P0715, P0716, P0753, P0758, P0841, P0842, P0843, P0846, P0847, P0848, P0973, P0974, P0976, P181B, P181C, P181E, P181F, P1820, P1821, P1822, P1824, P1825, P1826, P1827, P1829, P182A, P182B, P182C, P182E, P1831, P1832, P1833, P1835, P1836, P183D, P1844, P184B, P1855, P1859, P185B, P2718, P2719, P2720, P2721, P2728, P2729, P2730, P2766, P2809, P2812, P2814, P2815
Drives with the gears other than the gears related to the part in trouble, and an occurrence of trouble is displayed to the multi information display to warn the driver.
P1862, P1863, P186A, P186B, P1876, P1877, P1878, P1879, P187A, P187B, P187C
The creep driving cannot be performed, and displays an occurrence of trouble to the multi information display to warn the driver.
P1871, U0001, U0100
Shift shock or shift response deterioration occurs, and displays an occurrence of trouble to the multi information display to warn the driver.
P0746, P0963, P1870, P1871
Normal driving can be performed, and displays an occurrence of trouble to the multi information display to warn the driver.
P0630, P0701, P0711, P0712, P0713, P0960, P0961, P0962, P0967, P1637, P1676, P180C, P1864, P1867, P186C, P186D, P186E, P186F, P1873, P1874
P1875
**END** edited by kidneythief13 for picture overflow, from first post**
Awesome info!!! Thanks for posting this!
'08 EVO X MR BR350
Phantom Black with navi
MODS:
Buschur BR350 package
Buschur race 4.5" FMIC
Buschur 2.5" polished UICP
Buschur 2.5" polishd LICP
Buschur 3" dual cat-back (straight pipes no muffler)
Buscur intake + CF sheild
Buschur dyno tune with Gunzo sst mods.
Buschur custom resonated 3" test pipe
AEM boost guage
AEM wideband guage
ETS new O2 downpipe with recirculating dump.
Mustang dyno 287whp / 308ft/lbs with old tune (bad ROM) and slipping SS-T
Ray Knight is offline   Reply With Quote Quick reply to this message
Old 12-24-2009, 12:01 PM   #3
E6-X
E6-X's Avatar
awesome posts ! thumbs uppppp
E6-X is offline   Reply With Quote Quick reply to this message
Old 12-24-2009, 03:24 PM   #4
weebles
weebles's Avatar
Sticky.
BMW 135i - 3'' Vrsf catless downpipes - Agency Power resonated midpipes - ETS intercooler - BMS Dual cone intake - BMS charge pipe - BMS Meth kit - JB4 G5 ISO + Opensource backend flash - 437whp 496wtq
weebles is offline   Reply With Quote Quick reply to this message
Old 12-24-2009, 03:26 PM   #5
Scooter
Scooter's Avatar
Scott - Tallahassee - Dragonslayer - Husband of Lady X
Our little Swiss Army Knives on 4 wheels...
"Understeer is when you hit the wall with the front of the car
and oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall,
torque is how far you take the wall with you." --Anonymous
Scooter is offline   Reply With Quote Quick reply to this message
Old 12-26-2009, 06:47 AM   #6
livevil
Palindrome
livevil's Avatar
the goods !
Bent valve cylinder 3 / AMS licp / uicp
AMS SRI & Twin tip Exhaust
Agency Power Test Pipe & Motor Mount
Perrin Black Stealth Intercooler / ETS O2 Downpipe
COBB AP Stage 2 / xMR Catch cans
AEM Boost & UEGO AFR gauges
Mishimoto rad cap / Synapse BOV
Rota Wheels P45R 18 x 9.5 with Nitto NT05
EIBACH Springs Pro kit / Whiteline RCK & Rear Sway Bar
SNOW Performance H2O/Meth Kit
GT Spec Strut bar & Ladder brace
livevil is offline   Reply With Quote Quick reply to this message
Old 12-26-2009, 09:17 AM   #7
saytheb
There are a LOT more codes buried, I'll try to dig up the rest and get them posted if these are useful.
Old 01-03-2010, 08:06 PM   #8
TheSin
TheSin's Avatar
Thanks for the great post, it is now a Sticky and I reformatted it a bit, as you get new codes let me know and I'll add them.
My
and
TheSin is offline   Reply With Quote Quick reply to this message
Old 01-03-2010, 11:51 PM   #9
saytheb
I have a post to make my original look pitiful.
Here are a massive amount of the SST codes, and what they relate to. I have more information available to explain what some things are, and will also post that at some point.
Enjoy!
**** it all. I've tried to color this list 4 times and something goes wrong every time, TheSin, work your magic.
DTC No: Diagnostic item
U0001: Bus off
Old 01-04-2010, 12:42 AM   #10
TheSin
TheSin's Avatar
Going to have to figure out how to insert a post in the #2 slot the list is too long but I have a copy ready to go once I figure it out Thanks again this is a great list.
My
and
EVO X OBD-II Codes jmayevox Evo X Tuning 63 10-20-2015 06:20 PM
ACD codes livevil S-AWC System 12 11-26-2010 01:38 AM
2 codes P0137 BluesunsXIV Evo X Performance 6 07-24-2010 08:04 PM
Clearing codes on the Accessport Lesterh Evo X Tuning 2 10-20-2009 03:40 AM
~ Anyone Have the Evo X Color Codes? ~ DirectorSe7en Evo X Vanity 10 08-21-2008 07:16 PM
