SST won't go into D or R - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Evo X > Evo X Transmission & S-AWC System > SST
SST Post all topics about the SST transmission here.
Old 04-10-2019, 07:38 PM   #1
Seafarer
Seafarer's Avatar
Hi there,
Performing a swap from 5MT to SST, just assembled everything into one piece.
An issue is that TCU in R mode sees shifter position as R, requested demand also in R, but actual is N. In D mode - same story, TCU sees shifter in D, but demand is N and actual is N.
All configs were swapped from SST car, not DTC faults come up, all is totally clear. Teach in is also succesful - no pending or failures. Checked with MUT - forks are moving during teaching in, but "dead" during D or R. External picture is like moving a shifter into any drive mode but the wheels are not spinning.
SST has new clutch assembly, properly re-built, vacuum checked mechatronic and stand tested solenoids - all running fine, except not going into gears in any drive mode.
Sleeved 2.0; Wiseco pistons & Manley rods; EFR7163; ETS UICP&LICP; ETS 3,5" FMIC; PD SGC St2 cams + springs; Aeromotive 340; Radium Surge + Kit; Radium breathers; ID1000; AMS/AEM/Radium fueling; custom 2,5" intake; Custom downpipe; TiaL Q50; Full-Race T4 manifold;Ultimate Racing resonated test pipe; Tomei expreme Ti; Torque Solutions hangers; 4-port solenoid; swapped to SST; Braided brake hoses; Defi Gauges + podding; Alcantara interior; 10.2' Media + Rockford Fosgate
Seafarer is offline   Reply With Quote Quick reply to this message
Old 04-13-2019, 11:44 PM   #2
Is the shifter programmed to the car? I thought I read the shifter had its own logic and you cant just "swap" them out as there it does not rely on a physical deman (like a cable) to shift, but an electronic command from the shifter.
I thought I had read of someone with the same issues, after they had swapped a shifter out after breaking theirs, or some other similar repair.
Old 05-03-2019, 11:19 PM   #3
Seafarer
Seafarer's Avatar
Can anyone explain what's meant under programming shifter to the car, except VIN writing? One of Mitsu techs have told me that shifter's ecu is so basic, that there is nothing to be learned, except the VIN. The other fellow has told - SST has to be taught about shifter's positions. The question is that my car was originally 5MT and I was not taking parts for the swap from one single car. SST itself from one car, engine's ECM is from mine's, we've just made a tick, that this is an SST car from now on.
Shifter came from Japan, it's VIN has been re-written and all DTC gone.
Have started swapping parts from other cars to trace an issue, first ABS, but nothing has happened ( weird - without DTC, when changing ABS module ). We've also changed mechatronic from a working config, thought that mine TCU is faulty, but same as before - no wheels spinning.
Can someone confirm - does engine ECU ROM matters for running 5MT or SST?
What exactly shift lever on the tranny does? I mean, when we move the shifter, the cable is pulling the lever on the tranny from in ex. P to D, what process is affected by the shift lever? As far as I know, this mech link is only to get tranny hydraulics from P position. I'm running out of ideas///
Old 05-05-2019, 02:03 AM   #4
Check these threads out
SS-T Shifter Assembly
SS-T won't shift out of park
Issues with my 2008 MR SST Eagle1903 SST 11 04-22-2019 03:31 PM
EVOX GTX3576R GEN2 SST YEAR 2011 440whp dj2004 Evo X Dyno 5 02-08-2019 06:41 PM
GTX 3076r turbo fitment on SST gearbox? KARo7 SST 0 02-08-2019 11:32 AM
SST and annoying 500rpm rev jump evoting Evo X Tuning 3 02-06-2019 07:47 PM
SST Specialist in Malaysia/Singapore Cocoloco SST 1 12-03-2018 02:01 PM
