Read this before getting into E-Tuning - Page 2 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Merchant Marketplace > E-Tuning Services
E-Tuning Services A place for our Approved Merchants and E-Tuners to start threads and discuss services. Please do not post results in this section.
Old 09-03-2013, 01:43 AM   #11
InfantryMP
[Administrator]
[Local Team Member]
[Powder Coating Guru]
InfantryMP's Avatar
Let me know what you thought of it.
New to the Evo X platform? Check out our "Noob Help Center"
InfantryMP is offline   Reply With Quote Quick reply to this message
Old 09-03-2013, 01:45 AM   #12
UT_EvoX
Banned
I'll pm you after dinner.
UT_EvoX is offline   Reply With Quote Quick reply to this message
Old 09-03-2013, 01:50 AM   #13
InfantryMP
[Administrator]
[Local Team Member]
InfantryMP's Avatar
Old 09-03-2013, 02:05 AM   #14
surensm
surensm's Avatar
I just like the process of e tuning, I learn quite a lot through it and my driving style improves as the tune improves or changes. My absolute threshold for little changes in the car lowers as well.
2013 Mitsubishi Evolution X MR - SOLD
1990 Mazda Miata NA - Racecar
2001 Mazda Miata NB - SOLD
2002 Porsche 911 996 Carrera - Daily
surensm is offline   Reply With Quote Quick reply to this message
Old 09-03-2013, 02:15 AM   #15
kakasensei
kakasensei's Avatar
what should you do before a tune? like spark plugs,etc?
08 GG X
DEFI white boost gauge
AMS UICP
AMS intake w/ breather
fftec ebs
fftec tune
kakasensei is offline   Reply With Quote Quick reply to this message
Old 09-03-2013, 02:38 AM   #16
UT_EvoX
Banned
If it isn't included in a "pre dyno" package with an e-tune, doing a compression test and a boost leak test are essential. I would also suggest cleaning your MAF as I always see them produce better readings after a good cleaning (only use MAF or electronics cleaner).
If you have a boost leak, the whole tune will be influenced and you'll likely need a full retune after the leak is fixed. In addition, boost leaks are very bad for turbocharger health as they lead to you overspinning the compressor/turbine wheel which causes undue stress and extra wear on the whole turbocharger unit.
Compression imbalances in the motor can also lead to similar tuning inaccuracies. Even worse, if you have an unhealthy motor, the additional power from the tune can cause things to go south very quick.
I would recommend changing plugs during the compression test, and making sure you have oil that's got plenty of life left before starting the tune (fresh preferred).
Old 09-03-2013, 03:12 AM   #17
Englando
Englando's Avatar
This is all good reading!!
So I see mainly suggestions for up and running motors, but what about those that have a newly built motor? Obviously to start you get a basic map from the info that is provided to the etuner, but my main concern is this...
Some say (and have proven to be successful) that giving the motor some stick for the first 20 miles is best, seats the rings and completes the final finishing process on the cylinder walls...some say its not the best and to take it very easy, then there comes the other part to that which I hear...don't go into boost for the first few hundred miles on a new turbocharged motor...kind of hard to do the first part if that's the case.
So what is the real solution on a new motor while being etuned?
Sent from AutoGuide.com App
Englando is offline   Reply With Quote Quick reply to this message
Old 09-03-2013, 03:24 AM   #18
UT_EvoX
Banned
1.) Don't run too rich as it can bore wash the cylinders.
2.) Don't let it idle at the same RPM and don't cruise at the same RPM or speed for more than a few seconds.
3.) Run a decent amount of boost. The more BMEP the better, for seating in the rings initially.
4.) Lots of engine braking is generally regarded as beneficial for break in as well.
Make sure to let your tuner know you're not afraid to run it at a nice optimal AFR initially. Let him know that you want to maximize burn efficiency in fueling, which means timing advance can be kept conservative.
Old 07-26-2018, 09:13 PM   #19
UH-60Driver
n00b
Any updates to this list of good e tuners?
UH-60Driver is offline   Reply With Quote Quick reply to this message
Everyone please read JNguyen228 Evo X General 18 03-13-2012 02:37 AM
Speedhunters article about the state of tuning. MUST READ!! XArmy Automotive News, Articles & Pics 11 07-12-2011 06:15 PM
I install AEM tru boost only for read boost but read 10psi what is wrong ? yucel Evo X Turbo 4 09-12-2009 06:03 AM
Interesting read EVOX2nv Evo X General 1 02-21-2009 10:29 PM
Read This People hameedosh Evo X General 46 07-22-2008 05:13 PM
